08-18-2020, 04:33 AM | #4247 | |
Rep 9
Je l’ai mis sous le boîtier nbt II y a pas mal de place en retirant le cache tout en bas du nbt, tu en profites pour sortir le câble usb par l ouverture qui tient le cache en plastique sous la radio Je n’ai pas pris de photo en reverse mode (marche arrière?) si c’est le cas, ça m affiche le radar de recul oem et re bascule sur CarPlay quand je finis la marche arrière |
08-18-2020, 04:35 AM | #4248 | |
Rep 210
I did however successfully upgrade my MCU to MCU 20.6.18 today - what a difference! My previous version was 20.5.22.18. Steering wheel controls now fully work, even when in maps I can skip tracks, and overall the system is faster. Large podcast files now happily play, I can jump instantly between apps which I couldn't before. I blamed it on my older iPhone 7 but I now realise my Carplay module just needed an update! Thanks for this thread I'll continue to watch for more software upgrades, I'll try again as more as released. I just downloaded the latest flash and MCU from an Ali Express seller and can confirm this thread is up to date with the latest. |
08-18-2020, 05:42 AM | #4249 |
Rep 210
08-18-2020, 09:13 AM | #4250 |
Rep 766
Is a bad picture but see camera view for reference - mine is a third party camera and OEM sensors, the lines there move with the steering wheel and my MMI is from Andream with the most recent mod firmware.
That's the full screen view, ignore that weird black bar from the picture, the image is clear. There is a setting to make it split view but I prefer the full screen option. |
08-18-2020, 09:52 AM | #4251 |
Rep 1,217
GEMINI_PACK.BIN will likely have to be in all caps for the mmi to recognize it on the usb drive.
08-18-2020, 10:08 AM | #4252 |
Rep 16
08-18-2020, 11:01 AM | #4253 |
Rep 1,217
08-18-2020, 11:02 AM | #4254 | |
Rep 37
Did you cut any cable from the rear camera to have the lines moving with the steering wheel? I enabled the option in MMI and lines appear but they don't move. I'm using: - Bimmertech MCU 10.6.18.21 - Custom firmware v2.0.M0.mod |
08-18-2020, 11:43 AM | #4255 |
Rep 280
08-18-2020, 01:32 PM | #4256 |
Rep 59
08-18-2020, 02:21 PM | #4257 | |
Rep 766
Only suggestion would be to check on/off pins, cables pushed properly and the MMI settings. |
eduwinner3.00 |
08-18-2020, 05:08 PM | #4258 | ||
Rep 53
08-18-2020, 05:50 PM | #4259 |
Rep 10
I've been in contact with the aliexpress person I got my B unit from. I asked if there was a widescreen firmware, they sent me this:
https://drive.google.com/file/d/1cPs...ew?usp=sharing Which was no good to me as it's for an A unit. If a mod wants to add to the first page for completeness. I'm assuming this is the same as the andream AA widescreen fix release, only with RoadTop id. Does anyone have a RoadTop firmware for a B unit? As I'd like to know I can successfully flash my unit with a known good working firmware. |
Firefly1337846.00 |
08-18-2020, 08:58 PM | #4260 |
Rep 216
Thanks to all the work done on the custom versions. Loving the most recent version. I’m a wireless Android Auto user. The auto connect is so great. I still have an echo, but life is great other wise. Really makes my M5 feel perfect.
08-18-2020, 10:21 PM | #4261 |
Rep 1,217
Custom v2 uses the oem bluetooth connection so it shouldn't have any echo. Make certain that you are connected to the oem bluetooth.
08-19-2020, 03:10 AM | #4262 | |
Rep 1,247
What's the behaviour when using CarPlay and routing calls through the OEM headunit? Can I still use Siri etc on the unit but the call will flip to the OE BT before coming back to the MMI? |
08-19-2020, 03:22 AM | #4263 | ||
Rep 766
08-19-2020, 04:51 AM | #4265 |
Rep 37
08-19-2020, 05:01 AM | #4266 | |
Rep 37
https://www.android-car-dvd.com/coll...31283405488264 I can turn off the parking lines from MMI configuration but, when I turn the parking lines on, they don't move. Are you able to see the parking lines moving after cutting the green cable? |
08-19-2020, 05:44 AM | #4267 | |
Rep 210
On another note, I wired in my £11.50 (inc P&P) ebay boot handle reversing camera and its all working perfectly! |
x-m4n148.00 |
08-19-2020, 05:45 AM | #4268 | |
Rep 210
eduwinner3.00 |
andream, android, android auto, apple, carplay, mmi, retrofit |
