02-05-2021, 07:17 AM | #6381 |
Rep 19
02-05-2021, 08:40 AM | #6382 | |
Rep 78
The files to save to USB drive should be like this? |
02-05-2021, 09:22 AM | #6383 | |||
Rep 58
https://f30.bimmerpost.com/forums/sh...postcount=6139 And another description slightly earlier from muniz_ri: Quote:
02-05-2021, 10:02 AM | #6384 |
Rep 6
I seem to be stuck on B2R112. Do not see alot of info on the B2R112 software. I managed to get an update from Roadtop but I am running into the burn error everyone is getting. @Firefly1337 Linked Below:
https://mega.nz/file/hZ4DAQRT#YJw2OU...PIIaZZLLBmsJqE |
Firefly1337846.00 |
02-05-2021, 10:38 AM | #6385 |
Rep 128
02-05-2021, 10:41 AM | #6386 | |
Rep 24
When I am in aux, and have Android auto or Carplay on the 8,8 navi screen. I can navigate through it via the scroll wheel on Steering wheel. It occasionally shows msg on HUD, that says something like "you cannot use scroll wheel while using aux". However in reality it operates the Android auto. - I guess the MMI for android auto intercepts these commands from wheel. Thanks, |
02-05-2021, 11:29 AM | #6387 |
Rep 280
New update
New version B2R115 for RoadTop NBT B2-(?)Version available on the 1st page (thx Lagik).
The update is from: Code:
created: 2020-12-22 09:55:10 Honestly I'm starting to loose track of all the different updates... not sure what their strategy is by releasing so many different updates, now even for the same hardware type and seller. |
x-m4n148.00 |
02-05-2021, 02:49 PM | #6388 |
Rep 21
Just updated Andream NBT to 1.2.1. I want to say that the music sounds a little bit lauder now. Haven't tested everything but hoping that wireless Carplay connection is more stable.
Thanks. |
02-05-2021, 03:44 PM | #6389 | |
Rep 7,429
BTW when the phone is plugged in via the usb to the mmi unit, does it charge the phone? if so why does android auto still drain the battery (is this when it is in wireless mode)?
Click on the link below to see a compiled list of every review I have ever written:
https://f87.bimmerpost.com/forums/sh...2#post30368242 |
02-05-2021, 04:06 PM | #6390 |
Rep 12
Hi All,
For what its worth, I initially got my Andream NBT B with 1.0.3, happily upgraded to 1.0.4 but I've been stuck ever since with the infamous 'burn error' and have been constantly checking this thread for details as to why. Gave up waiting as I really wanted automatic android auto connection, so gathered up the months of info and went along. Tried 4 separate USB sticks, all freshly (quick) formatted fat32 on windows (no other settings changed), all different sizes, mostly USB2 but varying in age, whatever I could find in the house got a try. None worked trying to upgrade from 1.0.4 to 1.1.2. Then tried the reported empty 'recovery111#' file with all of them, did this on windows by right clicking on the USB stick root > create a new text document > rename file and remove file extension (.txt) > accept Windows warning about possibly being unable to read. Again all 4 sticks did not work with upgrading. Then I decided to give the sleight of hand hack a try (cheers to mrx3n0n10, noted on post #6070 of this thread). The setup was: 8GB USB 2 Imation with v1.1.2, 16GB USB2 Lexar with v1.0.2. This worked successfully without a hitch, was finally on v.1.1.2! Decided I'll try to upgrade to v1.2.1 (put 1.2.1 on the Imation stick) from here hoping I'll have some more success with the new version, again no luck with the 'burn error'. Tried the recovery file again and still no success. Decided I'll try the sleight of hand hack again but this time will upgrade from 1.0.2 to 1.2.1 (again noting Imation = 1.2.1, Lexar = 1.0.2). Again this worked great and am now on 1.2.1. With all this said I'm getting the feeling it definitely isn't hardware related as I've used the same stick (Imation) to upgrade from 1.0.3 - 1.0.4 - 1.1.2 - 1.2.1. I'm not entirely sure I did the recovery111# file creation correctly, although upon plugging in the USB the Andream would promptly restart, open to any other critiques of my testing. |
02-05-2021, 04:56 PM | #6391 | |
Rep 24
I use pixel 4 and have 10w wireless charger craddle in car, which when playing music & navigation is not exactly able to charge the phone.... However no big issue, I am able to make 3 hrs drives with navigation without loosing the phone... |
F87source7251.50 |
02-05-2021, 11:21 PM | #6392 |
Rep 150
Anyone know where I can pickup some torx t20 screws that hold the screen in? Took them out to check what LVDS cable I had, and dropped one inside the dash somewhere trying to put it back on
02-06-2021, 02:21 AM | #6393 | |
Rep 7,429
But in this case I will try to assist you, If I am not mistaken these are the bolts that hold the idrive display in (they are the same on the nav units and non nav units): 1) Real oem diagram item #2: https://www.realoem.com/bmw/enUS/sho...diagId=65_2356 2) Part number of said torx screw: 07149185673 These are quite cheap and you can either buy them locally at your nearest dealer or you can get them online. Hope this helps you out.
02-06-2021, 04:21 AM | #6394 | |
Rep 79
Issues so far. Long pressing menu button does not bring up the mmi screen after some tries. Mmi plays in the back but cannot get the screen back on. Ignition off and on and it works again. Phone.i use oem setting. I can only hear sound from the phone when i first used the steering wheel connector and little screen in dash... After that i can control in carplay and dial from there perfectly. All rest seems to work. Auto day night works with lights of the car. Suggestions how to fix above issues without losing other functionality? Thx |
02-06-2021, 05:03 AM | #6395 | |
Rep 42
02-06-2021, 05:23 AM | #6396 | ||
Rep 79
02-06-2021, 06:38 AM | #6397 | |
Rep 7
02-06-2021, 07:21 AM | #6398 | ||
Rep 79
No such option like in 1.1.2? Note that in carplay setting itself you also have such option? Mayby both have to be enabled? |
02-06-2021, 07:40 AM | #6400 |
Rep 9
Hi all, just to update on the wheel setting not being persistent. I contacted the seller and gave me the B2R115 version. I updated to that and the problem still exists
Regarding the problems you are facing with the software update let me tell you what I did and worked first time. 8GB usb flash drive. Format under Linux with fdisk, 1 primary partition, type WIN95 FAT32 and then format with mkfs.vfat -F 32. Then copied the update file to the flash drive under linux as well |
02-06-2021, 08:31 AM | #6401 | |
Rep 58
Update: It worked. Now on 1.2.1. Is there an explanation somewhere on what all of the different audio settings do? 😬 First one is main volume it seems (Spotify etc) Alert seems to be Google Assistant. What are "Speech", "Music"? Are they different for AA/Carplay? Last edited by ckarv; 02-06-2021 at 01:09 PM.. |
02-06-2021, 10:11 AM | #6402 |
Rep 1
andream, android, android auto, apple, carplay, mmi, retrofit |
