05-27-2018, 10:45 AM | #45 | ||
Rep 1,541
Here are some of my recent logs. The old original VRSF IC I'm running is good for a few degree drops at the start of WOT pulls, but it can't compete against their new offerings on a FBO+tune car running 16+psi to redline. I'm waiting for their latest offering to drop. My choice is finding the right mix of cooling and added weight over the nose of the car. I'm leaning towards a PS2 or larger upgrade this year hence my renewed interest in a new IC. Quote:
http://www.bootmod3.net/log?id=5b009370d10b4354bbc029fd Oh and here is the road course time as listed on the M3/M4 laptime post. http://f80.bimmerpost.com/forums/sho....php?t=1144972 Willow Springs (Big Willow) 1:30.6 TheKosherStogie M2 (RE71, XP12/10, KWCS) 1:32.4 TheKosherStogie M2 (KWCS) 1:33.976 Anthony235 M235i (RE71R, RS29, KWCS) 1:34.70 atermechi M4 (RS3, Carbotech, TC Kline coilovers) 1:34.90 Colatkitty M3 1:35.010 nlakind M3 (AD08, KW CS) 1:35.1xx Shmelgy M3 6MT (R888,KWCS) 1:35.3 YMB_M3 6MT (NT01,RS29,TCK DA) 1:36.456 Jorgem2009 (R888) 1:37.7 CPWINCH M4 (TC Kline) 1:38.24 krnnerdboy M3 1:39.463 nlakind M3 1:39.764 Brian135i M3 6MT 1:41.08 ZAGA_M3 (NT01, RS29, KW DDC) 1:44.60 nicknaz M3
05-27-2018, 11:16 AM | #46 | |
Rep 1,348
Thanks for this post and actual test. With the new VRSF offerings will be great to see if the denser fin is an overall improvement. Hopefully the quality will be there to match as well.
2k15 335i Msport xdrive 6spd
05-27-2018, 05:48 PM | #47 |
Rep 1,827
Tiago@VRSF I'm willing to offer my car as a test vehicle for fitment and performance. FMIC will complement my VRSF chargepipe and downpipe nicely!
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~ |
05-28-2018, 12:34 AM | #48 | |
Rep 2,639
05-28-2018, 08:14 PM | #49 | |
2093
Rep 43,350
W'ere not interested in creating any sort of conflict and we're not trying to spark up any drama in this thread but I'd be up for a friendly debate about intercoolers via PM if you're interested! As far as the new mid sized option we're releasing, it's designed for the guys interested in upgrading their turbos like the PS2 who need to keep intake temps in check without sacrificing flow. |
Anthony235715.00 |
05-29-2018, 11:30 AM | #50 |
Rep 266
So how does the new higher dense pack street IC compare to the existing street HD IC? Just wondering as I recently purchased a street HD a few weeks back
2013 F30 335i
BM3, MPE, VRSF DP, VRSF Street HD FMIC, VRSF Chargepipe, AFE drop-in filter, Bilstein B14 PSS Coilovers |
05-29-2018, 11:37 AM | #51 | |
Rep 1,541
05-29-2018, 11:57 AM | #52 |
Rep 2,639
If you're doing lapping or circuit, I highly recommend the Race FMIC. The extended time on the track at summer temps, you will absolutely need a fmic like that especially since you're going PS2. If you're running meth, you can gey away with the other fmic, but if just pump, race fmic.
Anthony235715.00 |
05-29-2018, 01:43 PM | #53 | |
Rep 1,541
I think the new VRSF IC that's about to drop will be a good middle ground between cooling/weight/radiator air flow. I could ultimately end up with the race one though. Waiting for more info I think if it can handle my stock turbo @16psi to redline it will handle a PS2 fine. I wonder if a stock maxed out turbo actually runs hotter IAT than a PS2 at the same boost....it probably does?
05-29-2018, 10:46 PM | #56 | |
Rep 2,639
Anthony235715.00 |
05-30-2018, 12:25 PM | #58 | |
Rep 1,541
Or perhaps it's more correct to say that the PS2 runs cooler for the same amount of HP. OEM turbo @400hp is hotter than Ps2 @400hp (less boost=less heat, same HP).
05-30-2018, 03:12 PM | #59 |
Rep 1,348
Explain? PS2 has bigger Turbine wheel and Compressor wheel,moving more air and at same psi will run hotter?
Anthony235715.00 |
05-30-2018, 03:14 PM | #60 |
Rep 1,348
EXACTLY!!!!!!!!!!!!! That is the right answer right there!!
Anthony235715.00 |
06-01-2018, 05:07 AM | #61 |
Rep 9
I got the new VRSF 5" street intercooler and also their charge pipe. The intercooler was easy to install except the fan shroud doesn't seem to fit the tabs. I had to cut off the part I circled in red.
06-01-2018, 01:52 PM | #62 | |
Rep 1,043
Hoping to hear the answer to this if it's a larger scale issue. I'm getting mine installed tomorrow. |
06-01-2018, 01:59 PM | #63 |
Rep 34
VRSF Intercooler FMIC Upgrade Kit 12-18 F20 & F30 228i/M235i/M2/328i/335i/428i/435i N20 N55
Model Number: F30-FMIC This is the one you were talking about? |
06-01-2018, 02:02 PM | #64 | |
Rep 2,700
same thing here. HD model.
Fun/HPDE: 2023 M3 6MT Individual Malachite
Past:2023 M4 CSL, 2022 M4C Vert, 2020 M340i, 2018 M2, 2015 M235i, 2008 135i 550whp Daily: 2023 X5 45e Daily/Family: 2021 Atlas Cross Sport 3.6 |
06-01-2018, 02:32 PM | #65 | |
2093
Rep 43,350
