BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Little warning to all
      07-14-2018, 04:22 PM   #1
magic77
magic77's Avatar
Drives: ex- 335i
So today car went into for interim oil change and few other bits.
While inspecting the car we noticed the rear subframes vibration damper to be badly loose.
The unit is mounted through the rear subframe direct into rear diff. Huge chuck of steel with a rubber grommet and then metal nut. The rubber bush has totally perished and the unit while tight to the car was rattling like something crazy.
Car is a 2014 plate with 23,000 miles on clock. :
Expected things as simple as this to last longer.
Item 7 in the link below
https://www.realoem.com/bmw/enUS/sho...31#33176856504
Seems nothing major but the way the rubber has come loose I woudl not trust the part to stay on the car any longer and hate to think the damage it coudl do do to the car or another vehicle if it came off.
F30 335i M Sport - now departed
muffking224.00
      07-14-2018, 05:25 PM   #2
NanasBack
Drives: EB 335 oil burner
Another potential recall safety issue?
335d xDrive
      07-15-2018, 03:51 AM   #3
magic77
magic77's Avatar
Drives: ex- 335i
I suspect not , takes someone to have major accident like the e90 fire recall before they do anything it seems. Joy of cars made to last only few years unlike before
      07-15-2018, 04:47 AM   #4
RobUK
RobUK's Avatar
Drives: 340i MPPSK
Yeah, you'd hope something like that would survive normal wear & tear a lot longer than 3½years. What's it going to cost to fix?
Life is a state of mind
      07-15-2018, 05:00 AM   #5
NISFAN
NISFAN's Avatar
Drives: BMW M2
Nothing, take it off and throw it away like I did
Lorcan3609.00
      07-15-2018, 02:15 PM   #6
magic77
magic77's Avatar
Drives: ex- 335i
Did yours also wear out. Its the vibrations that could be issue post removal especially at higher speeds.
Will find out tommorow how much the part is
      07-16-2018, 03:28 AM   #7
NISFAN
NISFAN's Avatar
Drives: BMW M2
No, but it's a 1.2kg weight that doesn't belong on the car. I have 2 or 3 of them in the garage
      07-16-2018, 01:56 PM   #8
ZHP076
ZHP076's Avatar
145
Drives: 2016 435i ZHP 076
2016 435i ZHP  [0.00]
And the diff will cool faster without that hunk of thick rubber and steel insulating it. It would take an factory expert at NVH to tell it was missing.
R T Whitfield
2016 435i ZHP #76
RACE CAR
spelled backwards is
RACE CAR
      07-17-2018, 11:08 AM   #9
Mr Whippy
Drives: F30 335Xd, E81 130i
Until you hit the perfect combo of oscillation and your diff cog wheels go crunch.
Chances are it’s not for nvh when pootling around, but in high slip conditions and the drivetrain is loading/unloading, and making sure the natural frequency is pushed to one unlikely to be reached.
      07-18-2018, 03:42 AM   #10
Sasquartch
Drives: 520i G30
I'd have to agree with this
No way BMW would fit a part that was unnecessary, for cost or weight reasons.
I'd make sure the correct part is refitted.
      07-18-2018, 02:44 PM   #11
NISFAN
NISFAN's Avatar
Drives: BMW M2
Perhaps, but I've done over 100k miles now without it. Including fastest lap time for a diesel in the "howfast" event, so I don't think you could consider the car not pushed to the extremes.
I've not felt any kind of increased NVH or any other ill effects like worn out diff bearing or exploding gears.
      08-12-2018, 03:07 PM   #12
magic77
magic77's Avatar
Drives: ex- 335i
The device is a 80hz rated so more likely its for idle speeds to reduce vibrations coming through the car. A bit like on the 320D on the exhaust on the e90 there use to be a huge rubber version similar to this to reduce the exhaust shake on idle.
I certainly noticed a new noise with it off. Was so tempted to reach over on the production line in munic and borrow one during recent visist (if only)
