07-16-2018, 02:34 PM | #1101 |
Rep 1,445
Evening all
Has anyone come across the following error when trying to code using e-sys? I can't see I'm doing anything differently from normal, but when I try and read from VCM (was hoping to code the start-stop) I get this pop up:
Gone: G05 X5 40d M Sport, F15 X5 30d M Sport, F30 330d xDrive, F21 M135i, E87 123d
07-18-2018, 02:40 AM | #1102 | |
Rep 1,445
07-18-2018, 06:40 AM | #1103 |
Rep 40,668
08-05-2018, 10:40 AM | #1105 |
Rep 276
Maybe someone here can help me. I have a bmw f34 328i from 2014 with nbt from factory, i did a retrofit of base plate (with option antenna, usb, and video) for snap-in(connect version for iphone 5). I connected everything according to bmw wiring diagram, coded 6nh to 6ns to have EBT. Do you need to add other optioncodes then 6ns?
But when i connect phone to the snap-in it only charges and does nothing further, in the i drive it say not connected. Further i disconnected the usb cable from snap-in and connect just an usb connector and once i do this my usb1 disconnects to so i have none. This make me think its just a coding problem but what is it or is it something else |
08-06-2018, 09:55 AM | #1106 | |
Rep 276
08-06-2018, 01:04 PM | #1107 | ||
Rep 40,668
https://www.bimmerfest.com/forums/sh...0&postcount=78
teaston10993.50 |
09-06-2018, 12:25 AM | #1108 |
Rep 214
Alright friends - Help is appreciated here. Looking for EBT, but mainly activating the 2nd USB port in the glovebox.
I have a '15 Pre-LCI NBT HU w ProNav, 6AC, 6AE, 6NH. Do I just follow Post #1? If not post #1, could someone point me in the right direction? Thank you very much! |
09-06-2018, 12:56 AM | #1109 | |
Rep 40,668
09-06-2018, 01:12 AM | #1110 | |
Rep 214
It charges an iPhone fine but doesn’t show up as selectable in the External Media options. Can it be used/activated/etc? Thank you kindly. |
09-06-2018, 02:37 AM | #1111 |
Rep 40,668
No sure.
09-06-2018, 02:49 AM | #1112 | ||
Rep 32,881
So just follow the first post and change 6NH to 6NS |
09-06-2018, 10:53 AM | #1113 |
Rep 214
Thank you both, I'll code to 6NS and hopefully the option becomes available. I checked and the cable definitely runs from the USB port to the back of the unit.
09-06-2018, 11:44 AM | #1114 | |
Rep 32,881
https://f30.bimmerpost.com/forums/sh....php?t=1228584 |
09-06-2018, 11:47 AM | #1115 | |
Rep 214
09-06-2018, 11:49 AM | #1116 | ||
Rep 32,881
09-06-2018, 12:03 PM | #1117 |
Rep 214
09-07-2018, 09:31 AM | #1119 |
Rep 32,881
10-12-2018, 08:04 AM | #1120 |
Rep 11
Hi guys
I'm new here and would like to enable office menu in Idrive. Car is F34 2015 with business navigation and black plastic combox in the boot. First, I need e-net cable (have one old OBD connector and will solder the cable) Can somebody please send me a link for needed SW More I’m reading this thread less I understand. Which manual should I follow, Is there any thread where steps for this combination of navigation and combox is written? |
10-31-2018, 04:01 AM | #1121 |
Rep 50
Very simple question and I hope a very simple answer.
In the past I have always had X5 and done my own coding, Now I have an F31 with quite a decent spec but want to put my own stamp on it, I have been reading quite a lot of what is available etc, BUT when starting E-Sys launcher (Which is new to me) It ask me to select Car series So here goes I assume I need to select F031 yet I have seen posts where F020 is instructed to be selected? Am I correct in assuming that the F031 is selected in "Launcher" but if not using launcher ie in E-Sys then F020 is selected? Many Thanks Guys
Mine 2012 X3 F25
The Wifes 2007 325i Convertible Hard Top (electric roof) Full Package |
10-31-2018, 04:46 AM | #1122 | |
Rep 32,881
