BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > F30 6MT gear indicator coding?
      02-11-2019, 09:49 AM   #1
6SpeedCrewCab
6SpeedCrewCab's Avatar
Drives: 2015 335i MSport
My 335i has the 6 speed manual so the screen on the gauge cluster only shows what gear the car thinks you should be in. I've never paid any attention to it, however, I do occasionally check that box for which gear I'm currently in(like it shows in the automatic transmission models). Is there any way that I can swap the "shift indicator" function for a simple display of the current gear?
      02-11-2019, 09:53 AM   #2
mbanks21
I doubt it. I have a JB4 and one of the gauge options is what gear you're in
      02-11-2019, 05:51 PM   #3
430inPR
430inPR's Avatar
Puerto Rico
Drives: '19 430i M-Sport 6MT
If you find a way to do this I would be interested in doing it too.
Current: 2019 430i M-Sport | 6MT | Glacier Silver Metallic/Black Dakota Leather | 763M wheels | DAP | HUD. Wife's 2018 Acura MDX
Past: 2013 MB C250 Coupe | 2012 MB C250 Coupe | 2004 BMW 325Ci | 2000 Toyota Celica GT-S | 1990 Miata and a whole bunch of Odysseys
      02-11-2019, 11:28 PM   #4
B58 parts
B58 parts's Avatar
Drives: '17 340ix 6MT
There are two knobs you can code in the kombi module that will change the indicator to
[ 4 ]
and when you should shift it will show
[ 4 > 5 ]
the stock settings always just show
or
[ > 5 ]
I forget the exact names, you can prob google them but something like
SPA_IST_ENABLE -> nicht_aktiv
SPA_IST_GANG_ENABLE -> aktiv
once in esys just search the kombi fdl for "SPA" and you'll see them. Disable the normal one and enable the gang one. It's better, but there's no way to get rid of the "should be in" half.
      02-11-2019, 11:49 PM   #5
neonnblack
Drives: 335i 6MT/e46 330xi
Stay in sport. 😁
      02-12-2019, 07:55 AM   #6
neonnblack
You can completely disable it in idrive also.
      02-12-2019, 11:13 AM   #7
Al Bundy's Dodge
Drives: 2018 M2 6MT
I did this roughly 24 hours after I bought the car when I saw it tell me I should be in 6th gear by 45mph. I knew then we werent ever going to see eye to eye on how to drive this thing.
2009 328i xDrive 6MT (Retired and I miss her)
2015 335i xDrive 6MT (Retired and I dont miss her)
2018 M2 6MT (Never retiring)
      02-12-2019, 11:14 AM   #8
donkey
donkey's Avatar
464
Drives: 6MT M2
How can you not tell what gear you're in?
      02-12-2019, 11:39 AM   #9
B58 parts
B58 parts's Avatar
I don't always know if i'm in 5th or 6th, and instead of the shifter later telling me it's right at a glance. On the track for example plotting a 5>4>3>2 shift, the sooner I know where it is and what I have to do the better. So I actually have found it to a bit useful, but yes I agree it's a weird thing to have ... I should just turn in and buy an auto now.
Some of you probably keep your hand on the shifter all day.
And yes the default setting is a joke. "> 6" .. i'm halfway through 2nd and you want me to drop 6th
      02-12-2019, 12:00 PM   #10
6SpeedCrewCab
[ 4 ]
[ 4 > 5 ]
or
[ > 5 ]
This is just what I was looking for! I'll let you know how it works out when I get it coded
dmaxdmax417.00
      02-12-2019, 12:04 PM   #11
6SpeedCrewCab
If I'm just cruising around town, sure, I can either quickly glance down at my shifter or just feel for where it's at with my hand. But I was looking for a solution for when I'm doing some spirited driving with both hands on the wheel and all I can see is the car telling me I need to be in 6th.
      03-25-2021, 09:06 AM   #12
dmaxdmax
dmaxdmax's Avatar
Drives: 2016 M235i 6-spd
Did it work? Fingers crossed it did and that you're still here!
'92 325i, '99 328i, '16 340i, '16 M235i all manuals
dmax on FB
My last pre-covid standup set
      05-04-2021, 04:41 PM   #13
MSlv
Drives: BMW F30 318i
[ 4 ]
[ 4 > 5 ]
or
[ > 5 ]
This worked just fine on my 6wa but it doesn’t work on 6wb after retrofit, it just removes the gear suggestion altogether… car is 2018 and 6wb manufactured in 2019
      05-04-2021, 05:16 PM   #14
dmaxdmax
dmaxdmax's Avatar
I double checked everything...here's what worked for me.
In bimmercode/instrument cluster/expert mode
FZG Ausstattung
SPA_ENABLE: nicht aktiv
SPA_IST_GANG_ENABLE: aktiv
SPA_KOMBISELECT_DISABLE: nicht aktiv
Let me know if that changes anything and works for you. Did on my 2016 340i
dmax on FB
      05-05-2021, 10:12 AM   #15
MSlv
Thanks for the advice. I coded all 3 like you said but it didn’t work, I got the same result as when I tried only with SPA_ENABLE and SPA_IST_GANG_ENABLE, the gear advice indicator went missing.
I will try later on to only set SPA_IST_GANG_ENABLE to aktiv, maybe try different permutations… I had this function on 6wa just before retrofitting 6wb and I loved it…
      05-05-2021, 11:51 AM   #16
dmaxdmax
dmaxdmax's Avatar
Good luck. I believe kombiselect 'might' be picked up through iDrive directly...as I can turn off the gear indicator entirely too in iDrive.
Just note that two say 'enable,' but the kombi says 'disable'--as in don't code when you've been drinking!
I also wonder if in your new coding bmw put things in to protect you from yourself? They've been stepping up their babysitting game a lot!
dmax on FB
      05-09-2021, 01:59 AM   #17
MSlv
So I tried one more time and anything else than default aktiv/not aktiv settings will cause the gear advice indicator to disappear completely.
      05-09-2021, 05:02 AM   #18
dmaxdmax
dmaxdmax's Avatar
Sorry to hear. Maybe someone with your year's model will have found a workaround.
This was one of the first coding items I wanted to do and glad I got done. Now it's off to try to stop the automatic rev matching...although it has saved me a few times.
dmax on FB
