08-18-2018, 06:23 AM | #89 |
Rep 32,881
08-18-2018, 06:43 AM | #90 |
Rep 832
Drives: 2019 G01 X3
Overall, sounds promising. Can’t wait to see the the new G80 M3 next year.
08-18-2018, 08:12 AM | #91 |
Rep 15,858
Yes harder to mix simple mechanical devices with advanced electronically controlled systems. Make sense to integrate any LSD function within the DSC suite.
08-18-2018, 08:15 AM | #92 |
Rep 1,066
Like the look of it, but im not a regular four door user and I have dogs, so for me I need to wait for the new GC - style wise nice - lets just how they get the petrol options right...
08-18-2018, 09:35 AM | #93 |
Barge driver
8656
Rep 12,425
I'll wager it'll be a £1500 option so I doubt many will spec it, plus you won't be able to tell the difference unless you're on a track.
730d/Z4C
hudson012003168.50 |
08-18-2018, 10:14 AM | #94 |
Rep 2,113
08-18-2018, 11:03 AM | #95 | |
Rep 9,709
You have to be pedalling very hard on track to even know it's there, unless you like purposely drifting. |
08-18-2018, 11:07 AM | #96 | |
Rep 9,709
08-18-2018, 11:15 AM | #97 | ||
Barge driver
8656
Rep 12,425
And then comparing that to my old 911 which didn't have an LSD, I know which one drove better and all the boxsters/caymans that they gave you as loaners when it was in for work they didn't have them either and yet were often described as the best handling cars you can buy. If there is a myth it's that a car needs one to handle and go well on the road, in fact in low speed corners they can and often do induce understeer.
730d/Z4C
08-18-2018, 11:36 AM | #98 | |
Rep 9,709
There is a reason why all M cars and top AMG cars come with LSD. Appreciate you have experience, but comparing a mid or rear engined 'sports' car with an M saloon is not exactly apples with apples. You comment on which is better is fairly obvious to many. As for your last paragraph, that is a problem with 1.5 or 2.0 LSD types, that have an effect during deceleration. Road friendly quaife and drexler diffs are one way type diffs, that only work during acceleration, and only when torque slip is present. I.e. the rear end has broken loose. So the understeer is not an issue on a RWD car. |
08-18-2018, 11:54 AM | #99 | |
Fool
1857
Rep 3,542
I had a 420D GC for a week recently and even that would have definitely benefited from a LSD, I'd never have another RWD without one IMO.
08-18-2018, 12:03 PM | #100 |
Rep 32,881
08-18-2018, 12:22 PM | #101 |
Rep 832
Drives: 2019 G01 X3
08-18-2018, 12:24 PM | #102 |
Rep 32,881
Well the new 3 series won't be available to order until early next year and it's always at least another year until the M3 comes out.
08-18-2018, 01:05 PM | #103 |
Eh? Team member
514
Rep 1,190
Drives: F31 335i
Wonder when the hearse will appear.
08-18-2018, 02:04 PM | #104 | |
Barge driver
8656
Rep 12,425
Porsche only really fit them as standard to their track oriented cars for obvious reasons and therefore M and AMG also do the same (although again the latter c63 never had one as standard until the current gen car so clearly not that vital apart from the track based black series can you see a pattern here?) after all the journalists take them to a track and test them, and as I said previously the lack of an LSD on a track would be telling you've got to keep the journos happy you see, but on the morning commute from Kidlington to Oxford centre I very much doubt it. If you want to pull out of that tight turn with the DSC off smashing it through 1st and 2nd whilst the diff holds the car at a lovely little angle as the rear wheels spin up then yes it's great fun but this isn't really what a cooking G20 will be doing hence my comments about it not being optioned and a waste of money as 99.9% of drivers won't be able to tell as that's not how they drive.
730d/Z4C
08-18-2018, 02:11 PM | #105 |
Rep 3,211
I cant see BMW putting the LSD into anything but the M340i
the strategy of the G is/should be the same as the F series theyre not going to up Mercedes in the interior theyre not going double wishbone.. they are simply tweaking the markets a bit by providing better "handling" for the people who care.. soccer moms culd give a sh!t.. college grads dont know the difference I mean anything revolutionary in the G? better dampers maybe if you stiffen the ride up too much, a large segment will whine if you soften up the ride too much enthusiasts will b!tch cant be all things to all people but the 3 has been pretty good at covering most bases now the G80.. now theres somethin moar power AWD with settings for 2 hybrid electric for low torque water injection S58 ... interesting |
08-18-2018, 02:24 PM | #106 | ||
Rep 9,709
08-18-2018, 02:54 PM | #107 | |
Fool
1857
Rep 3,542
I have MPS4S tyres on my 340i, granted, the tyres are harder to reach the limit of than the previous Bridgestones, but I still notice the diff on a daily basis when going around corners. All you need to do is accelerate round a corner and the diff just works. Without the diff you just get the DSC light flashing, with, it just pulls, no need for show boating. Now the 420D GC I had recently ran Bridgestones and I ended up driving it most of the time with DSC fully off to use the 'e-diff' to get traction as it didn't have the LSD mine has. It really struggled for traction despite not being an M or even a high powered model. Had it had the LSD, comfort would have done, sport+ would have been better.
08-18-2018, 03:03 PM | #108 | |
Rep 32,881
08-18-2018, 06:30 PM | #109 | |
Fool
1857
Rep 3,542
Bar the MPPSK, on my 340i it was the single most expensive option and it is absolutely worth it. If I was had a choice, I'd buy the LSD over MPPSK any day.
