08-17-2018, 08:40 AM | #67 | |
Rep 15,858
I'll put a flame suit on for this comment... can to a degree make up for less driver precision and to be frank, driver ability. Problem is, some drivers are assuming xDrive (AWD, 4WD) makes them invincible in more difficult conditions and/or push the limits, often more than is safe to do when tyre grip is the limiting factor. |
08-17-2018, 08:44 AM | #68 | |
Rep 487
Yep, xDrive tied to the x35d is a great combo to harness all that low down torque. I can honestly say, my TC light has never even flickered and never had a loss of traction in my current mapped 35d. It requires less skill and concentration to plant the throttle and keep traction and that in itself is a good thing. However, I've decided I want a bit more involvement and predictability in my driving now. Retro-grade to RWD? Probably. Most certainly a period of re-educating my right foot and reading the road a bit closer now. |
08-17-2018, 09:01 AM | #69 |
Rep 109
If the next gen 3/4 series 40i cars have an xdrive option, that’s when I’ll move to the petrol.
I won’t buy a bmw without xdrive now I have lived with it for years. I don’t require the ability to drift round corners. |
teaston10994.50 |
08-17-2018, 09:02 AM | #70 | |
Rep 1,846
Because you've missed the sarcasm in my post - look at what model I own! |
08-17-2018, 09:18 AM | #71 | |
Rep 5,681
08-17-2018, 09:19 AM | #72 |
Rep 25,113
X Drive thread. Guaranteed 10 pager on UK section
I think realistically AWD vehicles will be the norm on all but entry level brands. I'll be pretty surprised if the new M3/4 isn't the same as the F90 now with how well it's been received. Performance S Drive type cars will be becoming collectors items pretty soon.
My car made front page of Bimmerpost
08-17-2018, 09:32 AM | #73 | |
Rep 15,858
There is a big difference in slow speed control, than decelerating from high speed. We've used the descent control (hill assist) in my son's X3, seen its ability on snow, on a steep drive up to the family croft. Clearly a hand's off approach, ABS/DSC is in control, you can clearly see what it's doing, if you stand and watch. What is beyond dispute about xDrive, it is regulating drive torque (forward traction) to the appropriate wheels on acceleration. I've trawled through all the xDrive data I have access to, and never found specifics on how the system works on the over-run, or engine braking. The critical bit will be how the transfer clutch works and is regulated, to balance the grip between the axles during braking, assisting individual wheel grip levels. No mention of this in BMW technical data. If the clutch opens, (as it does in some situations, like slow speed tight cornering), then all bets are off to how xDrive assists deceleration. What we do know ABS takes control under slip conditions during braking. We also know, braking alone can use all the grip available, doesn't require engine braking to stop the vehicle. OK, there are times when engine braking retards the car, but "what axles are doing what?" in xDrive vehicles. With RWD we know it is the rear that is using engine braking, leaves the front tyres for modulating the speed of deceleration using braking, or in other words, under the driver's command and control. An example is in snow. I'm suspicious of how xDrive assists stopping through engine braking. RWD it is clear, engine braking gives control of the rear, separate from the brake pedal. Can allow sensitive modulation of the brakes to retard and control front end slip. You know you have two control systems, either separate, or together, working under the driver's control. If anyone has reference to how xDrive 'transfer' works under braking... if it does... most interested to understand its function. |
08-17-2018, 09:38 AM | #74 | |
Rep 19,982
08-17-2018, 09:39 AM | #75 |
Rep 19,982
Most of us don't have the ability either, but not sure how relevant that is to the discussion!
08-17-2018, 09:42 AM | #76 | |
Rep 15,858
A few years ago we didn't really require xDrive in the UK, (according to BMW) other than X models. How a generation of cars can change the marketplace. Can't even replace my car with a like model now, without going xDrive, isn't an option. Not to say that's a bad thing, well specced G31 540i xDrive on winter tyres will be a excellent all-weather vehicle. |
08-17-2018, 09:48 AM | #77 |
Rep 15,858
Good point, plus with autos, how many drivers will consciously control any engine braking? More likely jab the brakes and be confused as to why the revs have suddenly gone up, and the car is trying to slow on its own.
08-17-2018, 09:48 AM | #78 | |
Rep 5,681
In very high powered cars AWD probably offers a bit of a safety net but, as has been said earlier, in some respects it also perhaps serves to cover-up shortcomings with the driver which gives them a false sense of security and aura of invincibility; net result is the potential accident just happens at a higher speed! |
HighlandPete6658.50 |
08-17-2018, 09:59 AM | #79 | |
Rep 19,982
I had some very good instruction on a track day last year around it and how to use heel/toe braking to maximise it's benefits to help the brakes. Very demanding to do and get right (which I often didn't), but also very rewarding.
08-17-2018, 10:39 AM | #81 | |
Rep 5,681
No doubt makes me a dinosaur in the eyes of some (many?) but each to their own! |
08-17-2018, 11:04 AM | #82 | ||
Rep 32,881
08-17-2018, 11:11 AM | #83 | ||
Rep 32,881
JustChris17487.50 |
08-17-2018, 11:15 AM | #84 |
Rep 1,048
If you live in California and drive to the mountains in the winter, all-wheel drive or 4-wheel drive is a must-have. If you are an idiot, you cannot drive in snow no matter what kind of drive, and if you know how to drive, you can use RWD with a little bit of snow. HOWEVER, if you don't have AWD/4WD, the Highway Patrol will stop you and won't let you go through even if there is just a dusting of snow. There is also a law that during the winter, you cannot drive in the mountains without carrying chains or having AWD/4WD.
MashinBenzin8454.50 |
08-17-2018, 11:22 AM | #85 | |
Rep 5,681
I can't say I've ever had a significant problem in relatively powerful RWD cars (E46 M3, E92 335i, etc) in those sort of conditions, a little more care with the right foot is all that's required! |
08-17-2018, 11:43 AM | #86 | |
Rep 15,858
Arguing that we are protecting or enhancing our own safety, is a bit of a red herring. (Although I don't think anyone is against having a greater safety window). If we are simply moving the performance abilities to a higher risk area, we have to question the benefit. We can still fall foul to accidents, may be even more severe when they happen. This applies to using any 'added' performance, so easy to impinge on the safety of other road users. We still must look for the lowest common denominator. xDrive may enhance our safety in some circumstances, same as better brakes and tyres may do. But as we've mentioned in the topic on motorway driving, we may be able to stop better with high performance brakes, but the next guy has to be allowed for, will he hit us up the rear in the same circumstance? We may have to moderate our driving to really be safer. "Driving to the conditions" is still our greatest safety asset. |
08-17-2018, 11:50 AM | #87 | |
Rep 15,858
As put forward in a previous post, we only have a finite amount of grip on a given set of tyres. If we use more of the available grip for drive torque (traction) there is less for steering, braking and stability. |
08-17-2018, 12:00 PM | #88 | ||
Rep 2,511
xDrive allows unthinking acceleration without challenging the skill of the driver. So, the normal driver could easily find the self traveling beyond the limit of their true skill level... The electrical systems of my car nanny/flatter me massively. However, if I over do it a bit, the back end reminds me. Though, my 330d sDrive stepped out unexpectedly much more often than my present 340i sDrive does. Given my modest skill level the petrol output delivery is less torque based and easier to modulate.
Driving i4 M50 (G26)
Previous 340i Touring MSport (F31) |
HighlandPete6658.50 MashinBenzin8454.50 |
