BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Retrofit ICM High
      05-18-2024, 11:27 AM   #1
JaysonGoh
JaysonGoh's Avatar
Drives: 330i
Retrofit ICM High
Hey guys, I’m slowly hunting parts by parts to retrofit the Adaptive Cruise Control on my F30 LCI 330i. I currently have DSC MK100 ACC and ICM High on hand, so can I just install the ICM and DSC first before I got my hand on the FRR Module and the car work like it should before?
I already have the ICM installed, flashed, and coded it did not throw faults in iDrive however I could see the FRR appear red in ISTA which obvious reason I don’t have the FRR install. My question is this normal I should just ignore the red FRR Module or there's any other way I can code it so that it won’t try to look for or show up red FRR in ISTA?
      05-19-2024, 02:18 AM   #2
Siki78
Siki78's Avatar
168
Drives: F30,G30
Depends what you have in fa. If you have 5DF written in fa and code some module then FRR will be red because it is not there
Successfully retrofit on BMW F30 335xi 248,302,3AG,430,5AG,5AS,6NS,8TH and IHKA3
