BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Fitting MICHELIN PILOT SUPER SPORT (245/40-R18 / 97Y) on F30 335 Xdrive
      05-23-2016, 04:12 PM   #1
vincechase
vincechase's Avatar
Drives: G20 330 M Sport
Arrow Fitting MICHELIN PILOT SUPER SPORT (245/40-R18 / 97Y) on F30 335 Xdrive
Hey Guys,
I have a stock 2015 F30 335 Xdrive with stock rims and tires. Sport line.
Wondering if there will be any problems fitting MICHELIN PILOT SUPER SPORT 245/40-R18 tires on 18x8.5 all around square setup wheels.
My car is leased so I don't want to mess anything up.
Photos would be great also.
      05-23-2016, 04:15 PM   #2
black_F10M5
black_F10M5's Avatar
204
Drives: F10 M5
that will fit fine
      05-23-2016, 04:17 PM   #3
vincechase
vincechase's Avatar
Originally Posted by aw328i_NJ View Post
that will fit fine
What about speeding? potholes, locked turns ? Would that be okay aswell ?
Thanks for the response.
      05-23-2016, 07:31 PM   #4
black_F10M5
204
Drives: F10 M5
I am putting the same size 245/40 on a new set of 18x8.5 wheels this week. This is very similar to the stock setup of 225/45 on 18x8 wheels. They are slightly shorter in diameter but highly unlikely to cause any issue.
      05-24-2016, 04:59 AM   #5
Dog Face Pony Soldier
Drives: M Sport 335i
2014 335i  [4.87]
Originally Posted by imkash
Hey Guys,
Doesn't X-Drive come with 8" wide rims?
      05-24-2016, 06:28 AM   #6
Vitoco
Infidel
Vitoco's Avatar
Sweden
118
Drives: F31 328i M Sport
What about it, you fear the profile is too low? That would be really funny considering what most here run. I have a square 8.5" setup with 245/35R20īs, MPSS and no problem at all.
Glacier Ag. F31 328iA RWD M Sport oct. 2012
| Sport Automatic | Adap. M Susp. | Pano. Moonroof | 20" ATS Racelight Grey w. Michelin PSS| M Sport brakes | Harman Kardon | Elec. Seats | PDC F&R | ACC Stop&Go | 335i MPE | Perf. Parts |
      05-24-2016, 09:30 AM   #7
vincechase
vincechase's Avatar
That sounds great. May you upload some pics so I can see how it looks when your finished ?
      05-24-2016, 09:32 AM   #8
vincechase
vincechase's Avatar
Yes it does, just heard of people having rubbing so I wasn't to sure what would happen.
      05-24-2016, 09:33 AM   #9
vincechase
vincechase's Avatar
That's not bad actually. So I have a question for you. Cause I also thought of going 19 inch'. What are the pros and cons of having bigger rims on your car?
Don't want to effect of decrease my performance.
      05-24-2016, 12:45 PM   #10
bad karma
Drives: 2015 328i F31 M-Sport
There won't be any issue with those tires. On my F31 xDrive I run 245/40/18 Michelin PSS's on the stock 400M 18" wheels without any rubbing at all, not even close. The tires are very similar in size to the stock 225/45/18 Conti ProContact SSRs.
      05-24-2016, 01:02 PM   #11
2014 335i  [4.87]
My comment is related to your original post where you mention having 8.5" rims. I guess that was an oversight?
      05-24-2016, 01:33 PM   #12
vincechase
vincechase's Avatar
Well yeah it comes stock 8 inches. I guess half and inch at 8.5 shouldnt be an crazy difference.
      05-24-2016, 01:34 PM   #13
vincechase
vincechase's Avatar
Yeah well thats a relief, I just feel the 8 inch stock look too slim and want a Beefer square stance for my car.
      05-24-2016, 07:35 PM   #14
paul e
Drives: 340i xDrive 6MT
Your tire and wheel size 18"x8" are what Tirerack used in testing high performance all season run flats. They used a 2012 F30 328. So as the others have said, you're fine.
Plus quite a bit difference in choice with the 245/40, thanks.
      05-25-2016, 04:05 AM   #15
Vitoco
Infidel
Vitoco's Avatar
Sweden
118
Bigger rims is mostly for looks, but as long as u keep the weight of the wheels down there will be no performance loss. Comfort is another issue, but it goes hand in hand with the weight as well, not only less profile. I had the 403Ms with RFTs (19") and they weighed more than this set of 20" wheels paired with Michelin PSS, both the comfort AND "zippiness" of the car was really improved. I chose a taller tire than standard, just for that extra bit of comfort.
So performance/comfort wise there doesnt have to be any con at all, if the weight is kept down (at the cost, of the cost). So itīs basically down to how much u are willing to spend
      05-25-2016, 04:16 PM   #16
E30toF30
Drives: 2016 528i Executive Edition
I'm running 235/40/18 square as one of my setups on 18x8.5 Apex Arc 8 wheels. Also a 335 xdrive.
That was the main recommended size by Apex. 245/40/18 was a secondary option they recommended. I didn't do the math myself, but I'm assuming 235 wide is probably a little closer to stock spec than 245, but both are within the 3% threshold?
      05-25-2016, 05:30 PM   #17
T4NZ4NIT3 335i
Drives: 2013 BMW 335i xdrive Sportline
235/40/18 is seriously undersized overall diameter.255/40/18 is stock size, 245/40/18 is slightly undersized.
      05-26-2016, 06:44 PM   #18
E30toF30
This comment made me worried a little so I went figured out how to do the calculations myself.
235/40/18 is far from "seriously" undersized. It is still within the 3% threshold so is still well within acceptable size. 235/40/18 is approximately 2.4% smaller than 255/40/18. Naturally the 245 width will be even closer to the OEM 18" sizing and a better option.
This does make me wonder why APEX would recommend a 235 width tire over a 245 width if the 245 is even closer to stock spec. Maybe the 235 wide works better with an 8.5" wide wheel? I'm going to ask!
      05-26-2016, 07:13 PM   #19
black_F10M5
204
Drives: F10 M5
did they know you had an F30 and not an E90? The 235/40 would be closer to stock height for the E90. I went with 245/40 on my F30 and although they are not mounted on the car yet they look almost identical to my 225/45 as far as overall height
      05-26-2016, 07:30 PM   #20
E30toF30
Yeah they did know it was for a 2015 F30.
I think he recommended the 235 as a better fit for a 8.5" wheel seeing both 235 and 245 are both within spec (within 3% threshold).
I still haven't had the chance to send them a message to clarify.
Will see what they say.
      05-27-2016, 07:12 PM   #21
.BMW.
.BMW.'s Avatar
Sweden
1817
Drives: BMW F11/F31
235/45-18 (1.5% taller than OEM) would have been a more logical recommendation for a 235 tire.
      05-29-2016, 01:17 PM   #22
vincechase
vincechase's Avatar
Yeah for sure, so either or would probably have no problem being fitted. Guess thats true
335, rims, sedan, wheels, xdrive f30
