BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > xDrive All-Wheel Drive Discussions > XDelete- the answer to XDrive?
      11-15-2019, 09:11 AM   #331
Rodbearings
Rodbearings's Avatar
Drives: Too many to list
Originally Posted by Logicoeur View Post
You are asinine.
kern4173132.50
      11-15-2019, 09:43 AM   #332
Skyhigh
Skyhigh's Avatar
656
Drives: BMW F36
@floridaorange
Great.
So when you find the answer to that (in Bimmerpost or elsewhere), let me know please:
"And I definitely want to know how to flash back to stock xdrive, not x-deletes version of x-drive, I never thought of that."
      11-17-2019, 04:56 AM   #333
Onizukachan
Great Teacher
Onizukachan's Avatar
Drives: E46/3 M56 & F31d
Somewhere I probably still have the dealership training white paper from xDrive introduction.
M have different bias, 0:100, FWD are 100:0.
everything else is. 40:60.
Period.
Programming schmogamming. The actual code might vary but the results being output are identical despite hardware differences.
40:60. And if I remember my fact sheet, that changes over 100 mph to more like 20:80 for improved stability.
And it works pretty fine.
You aren’t saving hardly any power by adjusting the bias to 0:100, you are still powering all the extra rotating mass... just using the ground to do it indirectly instead of the driveshaft.
I could see this being useful for burnout contests and Dyno pulls. And that’s about it.
I thought I’d hate the awd, but it’s pretty good.
I think the old viscous coupling was a bit smoother to engage. I’m sure with a less laggy turbo you could take advantage to really power thru the corners by applying power early and tightening the corner to let the car 4 wheel drift slightly under power on the way out. That’s how we did it on the “good old days” of viscous couplings and torsens
      11-17-2019, 02:45 PM   #334
AlpineX
Drives: Diesel
Originally Posted by Skyhigh View Post
@floridaorange
By recoding to BMW specs via ista or during a dealership full-programming event?
Little bit different than flashing via their software.
      11-17-2019, 03:46 PM   #335
Skyhigh
Skyhigh's Avatar
656
Drives: BMW F36
The desire is to be able to do it easily yourself.
      11-17-2019, 06:03 PM   #336
city1991
Drives: 2015 535i x drive F10
Originally Posted by bimmer456 View Post
Can you do this on the fly while driving?
I'd assume you would need to be at a stop
      11-18-2019, 07:37 AM   #337
chaungo
=D
chaungo's Avatar
Drives: 13' 335ix
Need to be parked, and on ignition mode.
It's faster now if you use MHD black wifi adapter, it's compatible with xDelete and XHP now.
2013 335i xDrive
Bootmod3, Pure Stage 2, Pure Inlet, Turbosmart VR9 BOV, AFE Pro Dry S Drop-in Filter, ER CP/TIC CP, ER Catless DP, ATM FMIC, Borla ATAK, Dinan Springs, Dinan Shockware, XHP ZF8AT Stage 3, xDelete
      11-18-2019, 07:37 AM   #338
chaungo
=D
chaungo's Avatar
Drives: 13' 335ix
Period.
You arenít saving hardly any power by adjusting the bias to 0:100, you are still powering all the extra rotating mass... just using the ground to do it indirectly instead of the driveshaft.
I could see this being useful for burnout contests and Dyno pulls. And thatís about it.
I thought Iíd hate the awd, but itís pretty good.
I think the old viscous coupling was a bit smoother to engage. Iím sure with a less laggy turbo you could take advantage to really power thru the corners by applying power early and tightening the corner to let the car 4 wheel drift slightly under power on the way out. Thatís how we did it on the ďgood old daysĒ of viscous couplings and torsens
Don't forget turn in and steering feel.
There's a considerable difference when I went xDelete.
2013 335i xDrive
      11-23-2019, 06:15 PM   #339
1966-TR4
Scotland
258
Drives: F31 330D xDrive MPPK ACS
I am a software engineer.
And what is the safety critical software you are publishing via the App Store?
F31 Mineral Grey 330d Xdrive, ACS, Adaptive, MPPK.
Gone but not forgotten: 1967 Triumph GT6 Mk1 (6 pot 2 litre widowmaker) 1966 Triumph TR4A (4 pot 2.2 litre, huge torque, lovely car) 2004 Audi TT 3.2 DSG Quattro (weak springs & nose heavy) 2006 VW Golf GTI (brilliant on good tyres)
Skyhigh655.50
      11-23-2019, 06:20 PM   #340
deviantspeed
poopycat
Drives: 2017 F31 330i
@floridaorange
Great.
Regardless, flash counter will be incremented and warranty claims most likely voided.
I kinda see where you are going in 1 direction there, but my direction is an absolute.
Seems fun, if you are out of warranty.
      11-23-2019, 06:33 PM   #341
Logicoeur
Logicoeur's Avatar
506
Drives: F30 335i xDrive
Ok Boomer.
F30 335iX | Remus Axleback | 18X9 ET32 19lb TR-1 255/40/18 | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete
ali820237.00
Blubaron791107.00
jmack139.00
      11-24-2019, 03:44 AM   #342
Skyhigh
Skyhigh's Avatar
656
Drives: BMW F36
@floridaorange
Great.
Warranty is one thing (yes, it will be voided if discovered, irrespective of what software load is currently on and in my case I have several years of warranty still).
But I was more thinking that I would like to be driving my own vehicle's native, stock XDrive software when in XDrive, not XDelete's dump of some other vehicle's (potentially different/outdated) load.
In other words (irrespective of warranty considerations) I (and this is just me) would definitely prefer to be riding stock when not using the XDelete RWD.
      11-24-2019, 03:56 AM   #343
1966-TR4
Scotland
258
Ok Boomer.
This is your problem. I have built and owned old cars. That says nothing about my age.
      11-24-2019, 10:30 AM   #344
kern417
Cheapskate
Drives: 2018 440i / 2010 X5
It's not just your cars. It's your comments too. You sound like the type to see technology progress, but say you don't trust it because your 1970 3-speed whoopdie do did just fine without it.
Ok. But that has no bearing on a new option that has been proven across platforms.
Instagram @kern417
      11-26-2019, 05:06 AM   #345
flashollie
Drives: F31 2017 335d black
I am a bit confused.
Most of the folks on here are US / Canada and have petrol 35i engines with xdrive have done the x delete.
You are turning off the traction control and getting lots of wheel spin back end moving out and this is of course a safety issue.
Over here BMW will only sell the 335d in xdrive in am led to believe because they think the torque is too much for rwd only from a safety perspectve.
Over here in the UK we have lots of 340i engines running only rwd as stock. BMW seem happy to sell these that people can run without the traction control. So I am at a loss why the 335i engines from an xdrive with xdelete are felt to behave so badly and as they are surely just behaving like a 340i with the traction off that BMW build? The fault to my mind is not removing the x drive but removing the x drive and turning traction off.
Maybe I am missing something?
      11-28-2019, 01:04 PM   #346
Skyhigh
Skyhigh's Avatar
656
Drives: BMW F36
This is peculiar. Would the following preclude flashing of XDelete as well?
https://www.2addicts.com/forums/show....php?t=1603379
Has anyone with a late SW version / update done recently attempted to or successfully done XDelete? (the thread is for a different model, but the same i-Step codes appear on our vehicles)
There are very competent and knowing-it-all Software engineers here which I am sure will contribute with the best they have, as they always do.
      11-30-2019, 07:57 AM   #347
carguy138
Drives: E90 335i
Not a F30 but I've had xDelete on my E90 since it came out about a year ago.
Works great and zero issues. Mostly use the RWD mode but have tried the snow and sport modes. Always keep reverting back to RWD mode. Drives better and less wear/tear on the transfer case, front differential and front drive shafts.
I'll turn AWD on for bigger snow storms but that's about it.
      11-30-2019, 01:33 PM   #348
projectzer0
Drives: 2015 f30 335i xdrive
Does disabling the awd to rwd actually have the same driving dynamics as a rwd? There's extra weight from the transfer case and other components.
      11-30-2019, 07:40 PM   #349
floridaorange
floridaorange's Avatar
Drives: 2013 bmw 320i xdrive
I'll tell you what - the car turns waay better & my MPG went way up running rwd.
As far as gaining a bunch of HP, not so sure about that.
Stage 2 BM3
Originally Posted by GrussGott View Post
Sounds pizzagatey.
      11-30-2019, 08:33 PM   #350
GenXer
Drives: Like a bat out of hell.
I have a RWD 430i and wish I had AWD... SIGH
      12-01-2019, 11:23 AM   #351
Onizukachan
Great Teacher
Originally Posted by carguy138 View Post
Not a F30 but I've had xDelete on my E90 since it came out . Mostly use the RWD mode but have tried the snow and sport modes. Always keep reverting back to RWD mode. Drives better and less wear/tear on the transfer case, front differential and front drive shafts.
Perhaps I have misunderstood. I thought the rear transfer case output was the troublesome one on F30.
      12-06-2019, 08:20 AM   #352
carguy138
Drives: E90 335i
If anyone has the pre email login version, do not update it unless you absolutely have to.
They now require an internet connection to authorize the app every couple weeks. Meaning if you have any trouble with google play, login problems or no cell reception, you will not be able to re-flash when needed. Also disable any ability for the app to auto update.
They have also blocked older APKs from initializing so once you update, you're SOL.
Incredibly stupid.
