BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > What did you do to your F3X today?
      11-15-2019, 04:07 PM   #6249
im_an_alien
Drives: 2016 340i
Originally Posted by F30lolz View Post
Maybe the tow hook front plate bracket? I’m going to have to order a few of them for my cars as I’m moving to Indiana next summer which requires front plates. I hate em!
Indiana doesn't require front plates... At least they didn't when I lived there 5 years ago...
F30lolz3858.00
      11-15-2019, 07:58 PM   #6250
F30lolz
I can haz cheezburger?
F30lolz's Avatar
Drives: 09 335i/11 CTS Coupe/15 428 GC
2015 428 GC  [0.00]
2009 335i  [0.00]
2011 CTS Coupe  [0.00]
I stand corrected as I thought I saw front Indiana plates last time I was there in 2015.
Thank you Jesus!
Originally Posted by RaptorKTM View Post
So there is actually more of a chance to get more hp out of a 330 then a 335 in my opinion
Originally Posted by Wmf80 View Post
Seems like ur out of touch with baseball a bit. A few years behind.
You didn’t know who Hader was. And Kershaw is a mess in the playoffs. No thanks
      11-15-2019, 09:33 PM   #6251
amancuso
amancuso's Avatar
400
Drives: Z3, X5 4.8is,M5, M2
2004 X5 4.8iS  [0.00]
2000 Z3  [0.00]
2003 M5  [0.00]
Received some green P21w bulbs and fitted them in my NA spec prefacelift tails. Sure enough they flashed amber. So odd. Not sure if I want to use them or stick to my ROW amber tails. They aren't as bright as I think they should be.
2016 428xi, 2000 Z3 2.3, 2003 M5, 2004 X5 4.8iS, 2018 M2 Visit the Northeast M2/ 2 series owners group on Facebook https://www.facebook.com/groups/1832292440408437/
      11-16-2019, 09:11 AM   #6252
haagm58
haagm58's Avatar
Drives: F30 328d Sport Line
Had fun with BimmerCode.
Coded option to have a fog light turn on when turning (triggered by turn signal)
Mirrors fold with lock, unfold with unlock (from key)
Start with auto-off disabled
Decoupled ambient lighting from rest of dash lighting
iDrive off after opening driver door
      11-16-2019, 10:19 AM   #6253
amancuso
amancuso's Avatar
400
2000 Z3  [0.00]
2003 M5  [0.00]
Funny. I coded off the fog light on turn. Noticed it really didn't do much except burn down the filaments in the fog lights.
      11-16-2019, 07:12 PM   #6254
haagm58
haagm58's Avatar
I thought I'd give it a try but this is good to know, thank you!
amancuso399.50
      11-17-2019, 12:45 AM   #6255
Logicoeur
Logicoeur's Avatar
515
Drives: F30 335i xDrive
Refitted the 400M with brand Dunlop winters. Car feels different adding 4+ lbs of wheel back to each corner.
F30 335iX | Remus Axleback | 18X9 ET32 19lb TR-1 255/40/18 | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete
      11-17-2019, 04:35 PM   #6256
MSCD
MSCD's Avatar
Drives: 328i Convertible
So my MSport brakes are driving me nuts with the squealing....
The inspection in Mid October has me at 4mm- 5mm remaining.
I have the Extended Maintenance package through BMW.
Thoughts please - are the covered to replace.
These are 2015 pads... are they the same or better?
My wife hates them and they're quite frankly embarrassing on a $50k car!
2012 BMW 328i E93 | Deep Sea Blue Metallic - 2015 BMW 328i F31 MSport Sports Wagon | Alpine White - BMW CCA DelVal
      11-17-2019, 06:22 PM   #6257
Carlosskrr
Drives: Bmw f36
Finally Put rims on the f36[IMG][/IMG]
MSCD2503.00
      11-18-2019, 01:19 PM   #6258
5mall5nail5
Not stock
5mall5nail5's Avatar
Drives: E34 525i Turbo
Send a message via AIM to 5mall5nail5
I have the stock pads from my M Performance kit as spare - bought the kit in 2019 - it has the "bitier, less shitty" pads. I swapped them to PowerStop dustless units and they squeak a little in the cold but I can deal with it. If you want to try my spare pads I am in SE PA also.
2015 BSM 328i Sport Line - BSM
2015 BSM X1 M Sport - BSM
1992 525i
1987 325e
MSCD2503.00
      11-18-2019, 02:27 PM   #6259
MSCD
MSCD's Avatar
Thank you Sir. I have the car booked in for the 29th.... if that comes back as a 'no change' deal I may take you up on that.
Much appreciated.... if I can get them close to 4mm they'll replace....
      11-18-2019, 02:31 PM   #6260
BEM-S4
BEM-S4's Avatar
Drives: Dinan M235, Dinan Sport Wagon
If you want to look at non-stock options the Thompson folks suggested the Hawk HPS pads as an upgrade to stock. I was mostly concerned with performance, not noise, so you may want to check with them on that front. When my cars are due I am going to give those a shot.
Otherwise you have the blue brakes right? I have all of the stuff from the grey kit piled up in my garage if it's of any use to you, just taking up space. Took off a while ago when we upgraded to red BBK.
2016 F23 M235 xDrive Convertible • Dinan Stage 2 • AA IC • Apex EC-7 • MPE
2016 F31 328 xDrive Sport Wagon • Dinan Stage 1 • Vorsteiner V-FF 105 • BBK • 34 Hours 35 Minutes NY to LA
2006 E46 330ci ZHP Convertible • Apex ARC-8
MSCD2503.00
      11-18-2019, 04:06 PM   #6261
MSCD
MSCD's Avatar
Yes I have the blue brakes. If they can be replaced due to wear I'll get it done under the extended maintenance plan....
I'm hoping that is the case as no charge (already baked in and paid)! If not I'll have to see.
The slow crawl braking is excruciating on the ears!
      11-18-2019, 04:13 PM   #6262
mlev
mlev's Avatar
Drives: 2014 335i M-Sport
I had this issue, there are quite a few posts about it in the Brakes section. I cringed every time I knew I had to stop the car with people around. It got to the point where I didn't even want to drive to places like the mall because it was so bad and embarrassing. I have the M Sport Brakes (blue calipers). Dealer told me this was normal for the upgraded M sport brakes. They wouldn't do anything for me under CPO.
I tried swapping the pads to aftermarket ceramic ones, but the issue continued and actually got much worse. So I swapped rotors to Zimmermann's, and swapped to Akebono premium euro ceramic pads. I wanted low dust, and no noise, with solid stopping power. And that's what I've finally got. Haven't heard one squeal at all since install. Wheels stay nice and clean from no dust.
Many times simply swapping the pads won't help this issue because the rotors get grooves over time from the old pads. So the grooves of the new pads won't align with the old rotors, making them squeal. So it seems to be generally recommended to replace both pads and rotors at once if you want to fully eliminate the issue. Your rotors may also be glazed as well, and you can't safely resurface BMW rotors.
If you are forced to source your own parts, recommend RockAuto for the pads and Newparts for the rotors. Again, lots of info for you in the Brakes section of these forums.
MSCD2503.00
      11-18-2019, 04:19 PM   #6263
MSCD
MSCD's Avatar
Thanks for this. I'll see the outcome in a couple weeks with luck. I searched the forum and a lot was older.
I had same issue last year in the cold but this is much worst... agree on the mall... I had to pull up in front of a hospice with a number of people outside.... random person said in earshot of my wife 'needs new brakes' - nope, just decent ones!
      11-19-2019, 04:02 PM   #6264
amancuso
amancuso's Avatar
400
2000 Z3  [0.00]
2003 M5  [0.00]
Decoupled the ambient lighting from the cluster dimming. Wow, what a difference! (No Blockbuster video jokes, please) 🤪
      11-19-2019, 04:07 PM   #6265
Poechi
Drives: BMW F30 320i
Originally Posted by Poechi View Post
My OEM msport rear bumper, side skirts and 3D design style front lip are painted.
Fitted! Dual exhaust tips will be next!
Anyone know a good quality Alpina C13 style/replica wheel?
      11-19-2019, 04:52 PM   #6266
Shawzy44
Shawzy44's Avatar
Drives: 2019 BMW X5 40iX
Added Alcantara sun visors (Bimmermasterpieces)and open pore carbon headlight switch surround (carbonfibermods)
The sun visors look fantastic. Much better then the plastic version with yellow warning signs the car came with. Matches other Alcantara interior highlights. The colour matches perfectly.
Shawzy44
2019 BMW X5 40iX
MSCD2503.00
haagm58741.50
      11-19-2019, 05:31 PM   #6267
MSCD
MSCD's Avatar
Got a link to the sun visors? Cost? The look great!
      11-19-2019, 05:44 PM   #6268
Kaisah
Drives: 340i LCI
2017 340i  [0.00]
What exactly does this do?
      11-19-2019, 06:04 PM   #6269
Shawzy44
Shawzy44's Avatar
Pricey. Hard to say if it's worth it. Depends how bad the cheap plastics bother you.
https://www.bimmermasterpieces.com/s...product/jdqckx
Shawzy44
2019 BMW X5 40iX
      11-19-2019, 07:00 PM   #6270
Michael340i
Drives: BMW 340i Touring, Aston Martin
Their ad says they reduce the amount of plastic in the cars interior. Interesting, but aren't the visors covered in Alcantara, which is … plastic. Better plastic, but still plastic
