07-19-2018, 02:53 PM | #596 |
Rep 606
Neh... tried all there is but also avin users have it. With or without a splitter.
New software solved 90% of the problem so it cant be wiring. Which software are you using? |
07-19-2018, 11:17 PM | #599 |
Rep 207
Hi calle14,
your gps splitter works with the oem gps antenna in the ugode screen? In my installation could not having it working (no stable satellite connections) in ugode. Bmw oem navigation works fine with the splitter. Can you share more info please? |
07-20-2018, 03:12 AM | #600 |
Rep 606
I have the splitter as well but be careful on the connection that is different than the original. It doesnt have a pull protection so you actually pull on the inner copper signal wire.... that broke in mine and had to solder it. I have instant sattelite lock and not during my holiday when i get out of a tunnel with 100km/hr i have a lock within 10 meters leaving the tunnel exit
07-20-2018, 06:25 AM | #601 | |
Rep 207
Thats very strange, because I was very careful. Hope I dont have a defective cable... I have bought this: https://www.aliexpress.com/item/Fakr...852595449.html
One more opening this will be the 5th or 6th time. I have been an expert opening it. We should arrange a competition of who is the fastest installer of ugode screen. I am sure I will be in the top 3 Quote:
07-20-2018, 06:33 AM | #602 |
Rep 606
Well, if the idrive works (check gps signal in advanced menu and not navigation. The unit also works with car sensors!)
If thats ok, its most likely the connection on the screen and thats just 6 screws... Ive removed the unit probably about 10 times now. First the avin, then the ugode... Challenge accepted! |
07-20-2018, 06:59 AM | #603 | |
Rep 22
07-20-2018, 09:47 AM | #604 | |
Rep 132
I went for a 500 km drive with 3 breaks. I didn’t have the blank screen problem anymore during navigation. But I had once the “No signal” problem during navigation with Sygic. Screen first showed vertical white lines with blue background and after 1 second it showed the “No signal” text. Android system seems to be completely down. No music, no navigation voice. Switching to BMW side worked, I could listen to radio. Switching back to Android side, it still showed “No signal”. No help. Maybe it is a problem with system on heavy load? Because I was downloading maps update in the background before the crash. GM performance is still sluggish. Android showed a message that GM app has stopped responding...I could wait or close the app. DAB app is still get killed. I reported back to Louie. Last edited by wacky007; 07-20-2018 at 10:49 AM.. |
07-20-2018, 09:48 AM | #605 |
Rep 159
I starter the update an hour ago, and now im stuck on this screen
|| BMW F31 Mineral Grey || JOM Coilovers || Supersprint Axleback || BM3 Stage 1 || GFB DV || Old cars: E46 320i, F30 318d celtic tuning stage 1 || |
07-20-2018, 10:55 AM | #606 | |
Rep 606
I dont think its an issue with load.. im guessing its heat... Its also the reason the units processor has been downclocked i heard. Let us know what Louie says! Atiqofsweden , id reinstall the software. Looks like something went wrong. If it doesnt work after a reboot, my best guess is to put it on an USB stick and insert it before booting. If it doesnt work, rename the file to px3_reset.img and try again.. |
07-20-2018, 03:38 PM | #607 |
Rep 102
Today I had again the issue with Waze, looks like the update didn't solve this problem for me. I believe I'm the only one having this problem, could someone post a video with the setings of the unit? Maybe there is a setting that I have to change?
Edit: this are the current settings Could you please compare this to your unit settings and let me know if something is different? Last edited by florinbrv; 07-20-2018 at 04:26 PM.. |
07-20-2018, 06:00 PM | #608 | |
Rep 132
Heat as reason makes sense because of "features" implemented by the manufacturer: 1. Downclock CPU from 1.6 GHz to 1.2 GHz 2. Reduce number of apps running in the background by killing them. Only a few apps on the white list are allowed to run. Tried to measure the CPU temperature with CPU monitor app, but no sensors are available. Btw a CPU monitor app is also get killed when running in the background. |
07-21-2018, 11:06 AM | #609 |
Rep 63
@Ravijordan - are you CIC (2011 approx) and if you are would you have the latest version of the MCU to share?
07-21-2018, 11:17 AM | #610 | |
Rep 132
I have Car Type settings in english starting with F48... Rest of the settings is the same. I left everything on default. |
07-21-2018, 11:19 AM | #611 |
Rep 606
Other cartype XML file. Not that it really mathers its only a config file with several options and as long as there is one.that works, its ok
07-21-2018, 11:53 AM | #612 |
Rep 8
07-21-2018, 12:07 PM | #613 | |
Rep 102
I think the main issue is that after the player starts, I press the menu button and start Waze immediately. I don't allow the unit to boot up completely. Anyway, I thought that the issue is the GPS antenna location and I removed the trims (again) and with the GPS Test App, I've searched for the best position. Looks like that under the A-pillar trim has very good reception, best position would be on the dashboard, but I wantend to have it hidden Until today, the GPS receiver was attached to the top of the air vents, inside the dashboard GPS signal before: GPS signal under the A-pillar finisher: Last edited by florinbrv; 07-21-2018 at 12:22 PM.. |
07-21-2018, 01:09 PM | #614 |
Rep 93
07-21-2018, 01:24 PM | #616 |
Rep 102
Try to find an image with this trim, maybe on ebay? You'll see that on the top side there is a metal clip, in the middle a plastic clips and on the lower side two fixing features. The disassembly should start from the top, using plastic trim tools
