BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > dash cam - suggestions
proTUNING Freaks
      11-16-2019, 06:23 PM   #23
F36GC_NYC
Drives: 2016 EB 435GC xdrive
Originally Posted by Wgosma View Post
F36GC_NYC:
Thanks, good info. Good luck, hopefully you never see any suspicious activity going forward
thank you sir. appreciate it.
      11-16-2019, 06:25 PM   #24
F36GC_NYC
Originally Posted by Solidjake View Post
This
I have a Blackvue DR750-2CH with two B-124 battery packs and a 256gb card. The two batteries have 48-52hrs of record time
what about the cloud issue, how does it upload files to the cloud without wifi =(
      11-16-2019, 07:11 PM   #25
Solidjake
\_(ツ)_/
Solidjake's Avatar
Poland
498
Drives: '13 328i Msport 6MT
I don't use the cloud stuff with my camera. Just swap SD cards every time I go drive the car overnight and review footage if needed or review stuff via wifi when I get into the car.
IF you have a hotspot (from Verizon, etc) you can have it upload to the cloud continuously
Apex SM-10/PSS | 400m/X-ice Xi3 | Injen Intake/Exhaust
Stoptech SS Lines | 335 Brakes | Hawk HPS 5.0 | RBF600
Bootmod3 Stg 1 93 | ER Charge Pipes | Wagner Evo Comp 2 FMIC
      11-16-2019, 10:14 PM   #26
SportySpice
SportySpice's Avatar
Drives: 2015 335i Xdrive
I have the Thinkware F800 PRO with front and rear cameras that I hardwired myself. I've been pretty happy with it. The only downside is that the Thinkware microSD cards are expensive and the camera doesn't work well with other brands of cards.
      11-16-2019, 10:29 PM   #27
Solidjake
\_(ツ)_/
Solidjake's Avatar
Poland
498
Have you tried Samsung? My blackvue technically only goes up to 128gb cards but with the samsung card below in works perfect with 256gb
https://www.amazon.com/Samsung-Micro...3961318&sr=8-6
This is another one
https://www.amazon.com/Samsung-Endur...3961343&sr=8-1
      11-16-2019, 10:55 PM   #28
louielouie
Drives: '15 435i | '16 M4
I use the BlackVue DR750S-2CH with backup battery and have been pretty happy with it. Highly suggest a backup battery over the Power Magic Pro. After doing some research, BMW drivers had issues with it not working and you also don't want to cycle a $500 battery on a dash cam.
Main gripe with Thinkware was the bulky look, and how you're unable to customize notifications so it can be very chatty over the Blackvue.
      11-17-2019, 01:06 AM   #29
Logicoeur
Logicoeur's Avatar
361
Drives: F30 335i xDrive
For SD cards just make sure you get one that has a high write speed. It's the same with any video recording device. There are a lot of pixels so the storage needs to be able to support that write speed or you'll run into issues. They are usually branded as SDHC/SDXC or something of the sort. High capacity va extended capacity
F30 335iX | Remus Axleback | 18X9 ET32 TR-1 255/40/18 | MPerf LSD
      11-17-2019, 10:29 AM   #30
SportySpice
Thinkware dashcams work with the proprietary branded storage card. Blackboxmycar claimed that the Sandisk cards were also validated to work with the cameras so I tried them. One worked for a few months, the second one didn't work at all.
OP: Btw, if you're going to install yourself and hardwire to the fuse box, be sure to order the extended power cable. The out-the-box one from the manufacturer isn't long enough.
      11-17-2019, 11:01 AM   #31
Sigtran
Sigtran's Avatar
Serbia
Drives: F30 320d xDrive M-Sport
As a pure dashcam, I think best bang for the buck would be Viofo A119 v2, I have it and for its price, it is really great.
There are also newer and more feature packed models from Viofo, but more expensive, so check yourself, https://www.viofo.com/en/12-car-dash-cam
A119v2:
https://www.viofo.com/en/car-dash-ca...-dash-cam.html
P.S. for A119v2, make sure you also order a GPS module (for accurate time/date/location/speed) and it is also used as a perfect mounting kit, so dashcam can be easily removed if needed. And if mostly driving in bright sunlight, also order CPL filter.
      11-17-2019, 06:18 PM   #32
cfm56d7b
Originally Posted by cfm56d7b View Post
Dedicated NEO battery. Highly recommended.
yup im leaning towards that, how about the SD card? 32 enough or buy a 128 from amazon. they charge 70 bucks for 128 card.
I use BlackVue SD cards to avoid any issues. The price? Well - it is what is.
      11-17-2019, 06:36 PM   #33
Logicoeur
Logicoeur's Avatar
361
I promise you it isn't proprietary, just rebranded. There are only a couple nand/flash manufacturers in the world. Capacity, read and write speed is all you need to worry about. If thinkware won't tell you the R/W specs on their rebranded card it's just to fatten their own pockets. Any Sdcard highly rated for GoPros or DSLR cameras should suffice.
      11-18-2019, 10:38 AM   #34
SportySpice
Do you use a Thinkware dash cam? I've tried highly rated memory cards from a different brand. The camera would randomly turn off and restart while in use, which is not desirable behavior in this type of device. I'm not paying extra for their cards for the heck of it. The camera is more reliable with the branded card. Perhaps they've addressed this issue with the newer F800 Pro D+ models, but it's something I encounter with the camera that I purchased in April 2018.
      11-18-2019, 11:03 AM   #35
Dheeth-F30
Dheeth F30
Dheeth-F30's Avatar
Drives: 2013 BMW 335i M-Sport 4dr
I just got myself 2CH Viofo A129Pro Duo with Cellink Neo battery, so far so good.
M kidney grill///Red start/stop button///MP decal ///LCI LED Taillights///MPE & 4" tips///MP rear diffuser///Aluminum pedals///M door lights///MP LED door sills///M mirror caps///MP rear spoiler
///VRSF 5" Stepped HD FMIC, CP, Catless DP, NGK Step 1 Colder Spark Plugs, TICP, GFB DV+///Custom Tuned by Cary Jordan on 91 (Pump Gas)
      11-18-2019, 01:42 PM   #36
sinopath
Drives: 2017 base 440i cab.
If all you want to do is to deter a potential break-in suspect, then you will need a SURVEILLANCE CAMERA mounted to your house, not a dash cam in your car! Quite ironically, dash cams attract car thieves, and is among the top stolen items in break-in claims. I had a high-end dash cam before, one morning I found my window shattered, and the only thing missing was the front dash cam. Think about it this way, if you are a car thieve, and you broke into a parked car, got whatever you wanted, don't you want to just yank the dash cam off of the windshield to destroy all the evidences? After all, the SD card is inside the camera. To put a 300+ dollar dash cam in your car, you are only asking for more break-ins. Think about your glass, your insurance deductible, your leather upholstery, your CARFAX record for resale.
      11-18-2019, 02:01 PM   #37
sinopath
Dash cams are designed to catch the moment of an accident, so you can provide no-fault evidence to your insurance company. Parking mode has been overly hyped. Yes, your Li+ battery pack provides 24h+ extra recording time, but how many days of footage can be stored in your SD card? Unless you do a careful walk-around inspection everytime you get into your car, by the time you find a paint scratch on your passenger side door, the footage is long gone. Plus, if someone intentionally keys your car on the side, it won't trigger either motion detector or acceleration detector, provided you don't have a 4-channel setting.
      11-18-2019, 02:11 PM   #38
sinopath
For those wondering what SD cards are best. I have a Blackvue 750s 2ch. I use Samsung 128 PRO Endurance microSD cards, and they work fine (you need min 2 cards, so you can switch to preserve potential footages). Any high endurance cards designed for continuous read/write may be suitable. For a 2ch FHD setup, 128GB gives you 2.5-3 days of footage, 64GB lasts 1.5-2days. If you opt for a 4k 2ch, these may be halved.
      11-18-2019, 02:16 PM   #39
thompsac25
Stance to make her dance
thompsac25's Avatar
Drives: 2013 e92 M3
Recently did an install DIY on my channel.
Thinkware FA200, two channel (both front and rear) - I've been really happy with it. Extremely affordable.
INSTAGRAM: thompsac_m3 YouTube: ACCELERATED MOTION
2013 AW e92 M3 6MT ZCP M Performance, Eisenmann Race, Macht Schnell, BayOptiks, BPM Sport, RW Carbon, iND, KW HAS, aFe Power
2014 MG on Coral Red F30 335i MSport, MPPK, JHP Dynamics M Performance CF Lip & Diffuser, 437M's, LCI Blacklines, iND
      11-18-2019, 02:56 PM   #40
silver.f30
Drives: 2015 335i - Glacier Silver
I use the Vantrue T2 which I think is often overlooked. One of the most important things I wanted was a parking mode as I park in an active garage with mediocre camera coverage. The T2 plugs into the OBD port and has a microwave sensor which I've configured to detect motion within about 5 feet in front of my car. The OBD port provides enough power to run the motion sensor and record video when activated, without draining my car battery. If the voltage on the battery dips too low, it simply shuts off. I've left my car parked for a few days at a time with no battery issues (the camera shows recording as I walk up to it).
If you don't want to take the OBD route, you can also power it via USB port in the cigarette lighter or plug it in to an external battery. They also support rear-facing cameras as well. For the features and price, it was an easy pick for me.
      11-18-2019, 03:27 PM   #41
chhappy7
chhappy7's Avatar
95
Drives: 2015 328i
2015 328i  [0.00]
I wish there were something like this but with dual channel. Is OBD live even 10+ min after car shuts off to keep running parking mode unless the voltage gets too low?
2015 328i - M3 style front bumper/fender/side skirt, M Sport rear bumper/diffuser, M Performance brakes in yellow, M Performance exhaust, ceramic iDrive control, LCI radio trim
Check out my YouTube channel
      11-18-2019, 03:39 PM   #42
Ishan99
Ishan99's Avatar
Drives: 2017 BMW 320i
Rexing dashcams are amazingly reliable. I have one in the front and the rear. Super easy to hardwire also. I have 2 because I didn't know that I could buy the front and rear option lol. So I have 2. Combined with the gps logger, it's amazing. I was involved in a hit and run a few months back and the cameras caught the culprit. Police got to them and my car's damaged got paid for. Super clean quality videos. It's also the number one rated on amazon.com. Also, it has a very descents design.
Ishan Achar
Former: 2004 BMW E46 325i
Current: 2017 BMW F30 320i
Follow @Black_Lux_Cars on IG
      11-18-2019, 05:19 PM   #43
TommyG-inFlaNow
TommyG-inFlaNow's Avatar
37
Drives: 2015 435 Vert Alpine White
I'm looking at the Rexing and Thinkware. I have a convertible so that makes the rear camera a little more tricky
Anyone have some cool videos to share here?
      11-19-2019, 02:28 AM   #44
sinopath
No video, but here is an example with pictures of how to fit four cameras in an M4 convertible, you can get the idea. I'm on the same boat but I'll ditch the rear cam.
https://www.blackboxmycar.com/blogs/...l-installation
