BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > New issues with my 340I along with check engine light
      11-18-2019, 06:22 PM   #1
Sleeper340i
Drives: BMW 340i
Hello all,
Long time lurker first time poster here and I was looking if I could get any advice about recent issues Ive been having with my 2016 340I. Currently running a agency power intake, evolution racewerks high flow downpipe and MHD stage 2 91 octane, and have used the Stage 2 E30 Map a few times as well.
Car has been running smoothly and strong on stage 2, especially on E30 MHD but been having some recent problems the last few days. Recent problems Ive been having are the pops are completely gone, even on aggressive setting the pops are just not there anymore and all I get is burbles or sounds like some gunk coming out in replace of pops. Admittedly I ran em on high with the high flow cats and popped it a lot. Also, the gear switches have been a little more rough than usual occasionally and have gotten knock I could feel badly the other day. Feels like my car is slower and the boost is under performing with about a 15-18 PSI average when it usually pulls between 19-22. Coincidentally, when the pops started to disappear, the intake noise increased seems like but that could be in my head. Today I got a check engine light and got this error message here.
Codes
180001 - Catalytic converter: Effociency below limit value.
CBD309 - No message ( Status of climate air distribution on drivers side, 0x2E6), receiver DME2, transmitter IHKA
If anyone could help me I would gladly appreciate it as this is worrisome
For me. Im thinking the pops might have melted some of the high flow cats? Which believes me why I get the first error message but idk what the second one means.
TLDR: last few days car has recently been feeling slower, boosting few less PSI than normal, pops dont work anymore, gear shifts occasionally rougher, and check engine light this morning with codes listed above.
Thanks in advance everyone.
      11-20-2019, 03:31 AM   #2
Sleeper340i
Drives: BMW 340i
Anyone?
Asked MHD and they dont even know what the second error code is. Also maybe an oil change and spark plug change would help my occasional rough gear shift? Especially since running E30 occasionaly.
      11-20-2019, 04:34 AM   #3
psyki
E36fiend
Drives: 2014 435i xDrive
2014 435i xDrive  [0.00]
2014 X5  [0.00]
Second error sounds unrelated to your drivetrain issues. If you check the codes in ISTA it will tell you the mileage at which the error occurred.
      11-20-2019, 08:43 AM   #4
BMWILUVU
Drives: 340ix
Originally Posted by Sleeper340i View Post
Hello all,
Codes
Oxygen sensor or the high flow cat is burned out. Go catless.
      11-20-2019, 10:44 AM   #5
ProjectBoost
Mod addict
ProjectBoost's Avatar
Drives: Black AWD N55
Could be the intake.
316 RWHP/428 RWTQ
      11-20-2019, 12:10 PM   #6
mlev
mlev's Avatar
Drives: 2014 335i M-Sport
2014 BMW 335i  [0.00]
You should not be running aggressive burbles if you have a cat. Possibly ruined that downpipe or O2 components. I would flash to stock or at least stage 1 until you get this sorted out, your car does not sound happy with the current map right now. Also as stated above the intake can cause sporadic issues.
Also, this should've been posted in the B58 section of the forums.
      11-21-2019, 02:46 PM   #7
neonnblack
Drives: 335i 6MT/e46 330xi
Raw fuel igniting in the exhaust system is where your (bad) pops come from. Raw fuel absolutely destroys catalytic converters in very short order.
      11-21-2019, 03:22 PM   #8
bimmer456
Drives: 340i
The mppsk doesn't void warranty and has its own warranty and the pops and bangs can sound like gunshots and echo off walls and overpasses. Somehow it does this without voiding emissions warranty.
      11-21-2019, 03:26 PM   #9
BMWILUVU
Drives: 340ix
I think MHD and Bootmod3 lets you turn up the burbles and all of that extra fuel igniting in the exhaust is probably why his cat or sensor is gone.
