08-12-2018, 11:18 PM | #1 |
Rep 46
How do the model numbers work?
I used to think that I understood how the model numbers work, but now I'm not so sure.
I thought that: * The first number indicated the series (for example a 320i was a 3 series) * The numbers after the first indicated the size of the engine (for example a 320i has a 2 litre engine, and a 318i had a 1.8 litre engine. * The i/d indicated petrol or diesel. The thing that's made me think that's all wrong was when I got my 330e. If my theory was correct, it'd have a 3 litre engine, but no, it's got a 2 litre engine. Is there some consistency to the numbers? |
08-12-2018, 11:27 PM | #2 |
Rep 391
Drives: F87 M2C
The second number hasn't been accurate in a long time.
Currently as far as I can tell with the second number 2/3 is the 4 cylinder, 4 is the 6 cylinder and 5 is the V8
Past: 2011 Acqua Minerale Blue Hyundai Genesis Coupe 3.8 Past: 2017 Alpine White 440i F32 Current: 2020 Long Beach Blue M2 Competition PC Build: 5950x/6900xt |
08-12-2018, 11:30 PM | #3 |
Rep 1,048
Your info used to be correct. Now, first number is the series, but after that, it doesn't mean much that makes sense. 320, 328, 330 are all 2-litre, 4 cylinder. Horsepower outputs vary. 340 has a 3-litre, 6-cylinder.
08-13-2018, 02:17 AM | #4 | |
Rep 3,869
I used to think the same (never been a BMW guy). I also used to believe in authentic engine sound before engaging with BMW and their fake "sound experience"
08-13-2018, 02:57 AM | #5 |
Ring Leader of G8X Haters
25083
Rep 8,762
the second set of numbers (from my understanding) no longer represent engine size (they stopped that with the 325 and 525 e90/60 which had 3liter I6s) and started rating them at what their engine's output was equivalent to a naturally aspirated engine. For example a modern BMW 330i which has a 2liter turbo makes the equivalent to a naturally aspirated 3liter I6. The new 330i makes about 250hp and a 2006 330i with a NA 3liter I6 makes 255hp. Thus the new 330i is equivalent to the NA engine of an older 330i.
08-13-2018, 04:24 AM | #6 |
Rep 878
08-13-2018, 04:30 AM | #7 |
Rep 19
Drives: 2014 435i convertible
following
08-13-2018, 04:38 AM | #8 |
Rep 3,869
Key word - "currently"!
335i is no longer in production.
08-13-2018, 05:15 AM | #9 | |
Rep 15,858
Currently it seems markets and product placement, rather than output also influence the numbering. For example, the European 320d is renumbered a 328d for the US market. We've had a 325d in Europe, with more power output than the US 328d. 530d is renumbered a 540d, not for output, but again for marketing reasons. |
Poon Stick42.50 |
08-13-2018, 06:49 AM | #10 |
Rep 16,075
08-13-2018, 07:17 AM | #11 | |
Rep 1,290
This doesn't necessarily mean that the 335i driving experience is the same as with a car that has a 3.5L naturally aspirated 6 cylinder engine though. As you likely know, the turbo system noticeably changes the power delivery in the N54, N55, and now B58. The turbo engines can be, relatively, easily tuned to produce as much power as a naturally aspirated 5.0 to 6.2L v8 (approx 400hp and more). As stated earlier in the thread though, the second number is mostly marketing and product placement, like any model number from any make. I don't think we can ascribe too much real world info or meaning to it, other than where bmw places it in their line up. |
08-13-2018, 10:24 AM | #13 |
Sedan Driver
389
Rep 1,018
This. You got X2 with 28i which is a detuning of the B48 in the 330i but not detuned as much as the 320i. Just tells ppl which is more powerful relative to another and which costs more $$ within their series.
Slapping on M Performance parts, ZHP, badges, and stickers does not ///M car make
ZCP | ZHP | ZTR | ZE0 | MSport | ZMP | DHP | MStickerPack | THP | MPPSK | MPPK BMW MSP Lightweight Jacket | DTM Motorsport Team Cap| BMW M Drift Cat 5 | BMW M Thermo Mug |
08-13-2018, 11:05 AM | #14 |
Rep 4,446
Drives: '23 X1 28i xDrive
With the trend toward smaller turbo engines, car companies don't want their model numbers to "go down" or stay same with HP increasing. So they have abandoned the last 2 numbers being the engine size.
08-13-2018, 01:28 PM | #15 |
Rep 2,499
The second number is really just a relative power rating. Currently the 28-30 models are right around 250hp while the 35 models are about 300 and the 40 models are about 320-330hp. 50 seems to be about 450hp. An M prefix usually means a bit of a power bump as well (M850xi, M340, etc.).
Back when turbocharging wasn't common, engine displacement was a good indicator of relative engine output. A 3 liter engine could output about 50% more power than a 2 liter engine with some relative losses. However, now with turbocharging and using modular components, engine displacement has very little to do with power output. Higher output engines still need strengthened internals and better fuel delivery systems, stronger transmissions, stronger diffs, and stronger shafts. So it really doesn't make sense to define a car by how much volume the combustion chamber displaces. It makes no sense. A 250hp 2.0l engine will need to cost more than a 200hp 2.0l engine even if they use the same block. |
08-14-2018, 07:06 AM | #16 | |
Rep 1,290
08-14-2018, 07:19 AM | #17 |
Cheapskate
4447
Rep 4,993
I understand not realizing that the numbers don't correlate to an engine displacement anymore, but the fact that some of you are aware and still think it is associated with something else is amazing. The numbers have nothing to do with engine displacement or "relative" power. BMW is dealing with the same thing that Mercedes and Infiniti are. Premium brands are stuck using numbers in their model designation because it is taken as a more luxurious name. The higher the number, the higher the engine output and more expensive the car is. That's it.
When they come out with the next set of engines all the numbers will bump up again and again and again. That is, until they max out the 3 digits like porsche did and silently start picking smaller numbers that they never used before. Currently saving for 2065 391i. |
08-14-2018, 12:21 PM | #18 | |
Rep 2,499
It absolutely does have to do with relative engine output. Obviously as time marches on the numbers get higher. That's why I said relative. It's not a definitive horsepower figure, I never said it was. |
uncleruckus129.50 chiefneil771.50 |
08-14-2018, 01:07 PM | #19 | |
Cheapskate
4447
Rep 4,993
Edit: I see what I did when I went back through I referenced the wrong post. Mixup on my part.
uncleruckus129.50 tex26702412.50 |
