08-12-2018, 09:48 PM | #1 |
Rep 5,457
Tire Rotation Procedure
About to rotate my tires tomorrow and figured Id ask the group their opinion...
I have a RWD. Do you "cross the rears to the front" and "move the fronts straight back" or Just move the fronts to the rears and vice versa (keeping tires on same side of car). I know this isnt the biggest deal and just keeping the tires moving is the main point for even wear but I was wondering people's thoughts. |
08-12-2018, 09:55 PM | #2 |
Rep 5,457
I should also mention I am running a square set up.
08-13-2018, 09:03 AM | #4 |
No 55mph
1622
Rep 8,476
On square setup, if the tires are directional you can only swap them front for back - keep on same side
If not I use to cross them + front to back each time With my staggered setup there's no rotating at all...
alohasurftoad3112.00 |
08-13-2018, 12:00 PM | #5 | |
Rep 68
Drives: 340i M-sport
Those with staggered can only rotate from side to side. Do it and do it often for best results. |
kern4174449.50 |
08-13-2018, 01:54 PM | #6 |
A family of bimmers
2748
Rep 7,742
Lf > Rr
Rr > Fr Fr > Lr Lr > Lf
alohasurftoad3112.00 rambalu8078.00 |
08-14-2018, 12:31 PM | #7 |
Cheapskate
4450
Rep 4,995
What tires?
On my wifes car (asymetrical all-seasons) I rotate front to rear, then left to right. On my car (directional summer tires) I only rotate front to rear. Crossing tires is ideal but a headache to do without a lift, so I don't do it. Just doing f/r and l/r every 5k has treated me well. |
08-14-2018, 12:35 PM | #8 | |
Rep 5,457
Im going to cross the fronts back to the rear and move the rears straight up. Thats what I was taught from a young age. Wanted to hear other opinions. Appreciate all the responses! |
nissanite45.50 |
08-15-2018, 06:38 AM | #11 |
A family of bimmers
2748
Rep 7,742
yes. exactly what i posted to do
08-15-2018, 06:40 AM | #12 |
A family of bimmers
2748
Rep 7,742
I use a winter wheel as the 5th wheel and my garage jack and then i just come full circle back to that wheel at the end and its simple.
08-23-2018, 12:12 PM | #13 |
Rep 1,241
Drives: 2016 BMW 340i
Its called a rearward cross rotation pattern and recommended for RWD with square setup and non directional tires.
2016 BMW 340i 688 | LCL5 | 4FT | ZMT | ZTP | ZDA | ZLP | 494 Formula One Pinnacle 30 Tint | Brushed Aluminum Pedals |
