BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Tire Rotation Procedure
VIBE Motorsports
      08-12-2018, 09:48 PM   #1
sspade
sspade's Avatar
Drives: F30 328i
2014 BMW 328i  [5.00]
About to rotate my tires tomorrow and figured Id ask the group their opinion...
I have a RWD.
Do you "cross the rears to the front" and "move the fronts straight back"
or
Just move the fronts to the rears and vice versa (keeping tires on same side of car).
I know this isnt the biggest deal and just keeping the tires moving is the main point for even wear but I was wondering people's thoughts.
BMW 328i visit my garage for build details.
BMW CCA: 545157
      08-12-2018, 09:55 PM   #2
sspade
sspade's Avatar
Drives: F30 328i
I should also mention I am running a square set up.
BMW CCA: 545157
      08-13-2018, 08:59 AM   #3
montr
Drives: 2010 335d, 2018 430i G-Coupe
I always keep the tires on the same side, front to back
      08-13-2018, 09:03 AM   #4
1QuikWS6
No 55mph
1QuikWS6's Avatar
Drives: F32 435ix MSport ->M6
2016 BMW 435ix  [0.00]
On square setup, if the tires are directional you can only swap them front for back - keep on same side
If not I use to cross them + front to back each time
With my staggered setup there's no rotating at all...
F32 435ix//Mineral Gray Metallic//Black Dakota Leather//Alum Blade Trim//M Sport Pkg//Prem Pkg//Tech Pkg//Driver Assist Pkg//Lighting Pkg//Cold Weather Pkg//Dyn Handling Pkg//HK Sound+BavSound Stg2//437M Wheels//M4 Mirrors w/NWC CF Covers//MPerf Pedals-CF Rear Spoiler-LED Sills-CF Shift Knob/Surround/IND M4 Alcantara Armrest//MPE w/CF Tips+CGP VSC-1//Dinan CF Intake//PURE S2 Turbo//AA FMIC//ER CP+TIC//3.5bar TMAP/DV+//AA OBD Flash Tune Stg2
      08-13-2018, 12:00 PM   #5
nissanite
Drives: 340i M-sport
2016 BMW 340i  [0.00]
I have a RWD.
or
I worked for Bridgestone for 11 years. Their rotation recommendation is "Cross to Drive". If you are using tires that DO NOT have an arrow on the side this works. It will even wear and help with noise. So for your car, cross the fronts and the tears go straight forward. This will give each tire a time on each corner.
Those with staggered can only rotate from side to side. Do it and do it often for best results.
kern4171018.50
      08-13-2018, 01:54 PM   #6
wdeerfield
A family of bimmers
Drives: '13 f30, '11 f10
Lf > Rr
Rr > Fr
Fr > Lr
Lr > Lf
2013 EB/CR 335i xdrive | DHP | 19" VMR V803 | MPS4S | MPerformance | M3 Grills | BMS Tips | LED Turn Signals | CTS intake | VRSF FMIC | VRSF CP
2011 JB 535i xdrive | ZPP | ZSP | ZCW | 6FL | NAV | 331s Square | MPerformance Spoiler | M5 Grills | Painted Reflectors
      08-14-2018, 12:31 PM   #7
kern417
Cheapskate
Drives: 2018 440i / 2010 X5
What tires?
On my wifes car (asymetrical all-seasons)
I rotate front to rear, then left to right.
On my car (directional summer tires)
I only rotate front to rear.
Crossing tires is ideal but a headache to do without a lift, so I don't do it. Just doing f/r and l/r every 5k has treated me well.
      08-14-2018, 12:35 PM   #8
sspade
sspade's Avatar
Drives: F30 328i
Originally Posted by kern417 View Post
What tires?
Conti DWS06
Im going to cross the fronts back to the rear and move the rears straight up. Thats what I was taught from a young age. Wanted to hear other opinions.
Appreciate all the responses!
BMW CCA: 545157
      08-14-2018, 09:44 PM   #9
Sirhc1115
Drives: 2014 F30
For non directional tires you cross rotate the non drive axle
      08-14-2018, 10:22 PM   #10
sspade
sspade's Avatar
Drives: F30 328i
So for a RWD vehicle...
Fronts crossed to the back and rears straight forward?
Already did exactly that, just making sure we are on the same page!
BMW CCA: 545157
      08-15-2018, 06:38 AM   #11
wdeerfield
A family of bimmers
yes. exactly what i posted to do
      08-15-2018, 06:40 AM   #12
wdeerfield
A family of bimmers
I use a winter wheel as the 5th wheel and my garage jack and then i just come full circle back to that wheel at the end and its simple.
      08-23-2018, 12:12 PM   #13
rambalu80
rambalu80's Avatar
Drives: 2016 BMW 340i
Originally Posted by wdeerfield View Post
Lf > Rr
Rr > Fr
Fr > Lr
Lr > Lf
Its called a rearward cross rotation pattern and recommended for RWD with square setup and non directional tires.
2016 BMW 340i
688 | LCL5 | 4FT | ZMT | ZTP | ZDA | ZLP | 494
Formula One Pinnacle 30 Tint | Brushed Aluminum Pedals
