BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > can I use OEM bolts on aftermarket wheels
      07-08-2020, 10:51 AM   #1
shayne.k
Drives: F32
Do aftermarket wheels require new bolts on an f32? I purchased Enkei TY-5 5x120 and was wondering if I can use the oem bolts. If not, which bolt style do I need to purchase. thank you in advance
      07-08-2020, 11:25 AM   #2
alohasurftoad
oem lug bolts are conical seat. all aftermarket wheels i'm aware of(including enkei)have conical seats.
chowser512025.00
      07-08-2020, 02:23 PM   #3
shayne.k
Drives: F32
So both are conical hence they should work? Thank you for the response
      07-12-2020, 01:50 AM   #4
chowser51
chowser51's Avatar
Drives: F33 430 and F39 M35i
yes, according to tire rack:
The wheels you chose are engineered to use Original Equipment lug hardware and therefore lug hardware is not included with your order.
      07-13-2020, 12:39 AM   #5
shayne.k
Drives: F32
Thank you!
      07-13-2020, 10:52 AM   #6
brettsvn
brettsvn's Avatar
22
Drives: BMW 435i (F36)
2016 BMW 435i  [0.00]
2015 BMW M4  [8.50]
I'm curious to see what they look like on your car! I've been considering these wheels but can find pics of any f3x with them. Post some pics when they're all setup!
If you?re not first, you?re last
      07-13-2020, 04:48 PM   #7
shayne.k
Drives: F32
Will do. Hopefully tomorrow
      07-14-2020, 04:12 PM   #8
shayne.k
Drives: F32
Here ya go. All installed and ready to go. 5lbs lighter than the oem 18 wheels which are almost 29lbs without tire
      07-14-2020, 06:03 PM   #9
chowser51
chowser51's Avatar
Looks great! Are the center caps the same size or did you use stickers?
      07-14-2020, 06:10 PM   #10
alohasurftoad
bruh, you gotta re-orient the pics. can't be tilting our heads to view them.
      07-14-2020, 10:39 PM   #11
brettsvn
brettsvn's Avatar
22
2015 BMW M4  [8.50]
Looks good! What specs did you end up going with?
      07-15-2020, 01:25 AM   #12
shayne.k
Drives: F32
same size caps
chowser512025.00
      07-15-2020, 01:26 AM   #13
shayne.k
Drives: F32
haha no clue on why it does that when I upload directly from my phone
      07-15-2020, 01:28 AM   #14
shayne.k
Drives: F32
I went with 19x8.5 square setup. I think you could do the 19x9 +35 square as well. I had the 245 tires just laying in the garage from my alfa romeo. plus I wanted to save weight a bit so I assumed x8.5 would be at least 1-2 lbs lighter than x9
      07-16-2020, 06:43 AM   #15
brettsvn
brettsvn's Avatar
22
2015 BMW M4  [8.50]
Nice! I ended up ordering the wheels in the staggered setup so thanks for a few photos to help convince me haha.
      07-16-2020, 05:44 PM   #16
shayne.k
Drives: F32
glad I could help
