BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > F36 upcoming bumper replacement
      06-04-2023, 07:13 AM   #1
RobotDoctor
Professional Nomad
RobotDoctor's Avatar
679
Drives: 2019 440i F36 Sportline
This past week I noticed something odd in one of my pictures (front view, see attached). I got back from a recent business trip and took a better look under the bumper. Sure enough there is about a 6" tear. I have not hit anything or gone over a bad pot hole while I have owned this car so this damage was here when I purchased the car in March. Shame on me for not getting under the car to take a look. it was raining but still no excuse. That said, I will probably now be looking at a bumper replacement and will go with a M Sport bumper.
I have done a search in the forum for past threads and there are few that discuss going from an Sportline bumper to a M Sport. For those who have done this let me know what M Sport bumper was sourced, the parts needed that are different from parts for the Sportline, what parts can be transferred, and the overall process in the replacement. This is something I will probably undertake later this summer or into the fall when I get some time.
Thanks in advance!!!
      06-19-2023, 07:50 AM   #2
Boostedphil698
Boostedphil698's Avatar
Drives: 2015 BMW 435i Xdrive MSport
2015 BMW 435XI  [0.00]
2009 Honda Civic  [0.00]
I did a full OEM M sport retrofit to 435i about 2 months ago. In terms of parts, it varies greatly. If you're going aftermarket, you won't need a whole lot... OEM is a completely different story.
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily)
      06-20-2023, 07:47 AM   #3
Oksamit78
Oksamit78's Avatar
Drives: E39, F30 & F34
RobotDoctor
I'd start the homework from realoem.com Use your cars manufacture date at the beginning so that you can see the most applicable list of part numbers for your car.
Below are examples for 2019 F36 (manufacture date mid 2019) as an example.
Front Sport Line bumper set-up:
https://www.realoem.com/bmw/enUS/sho...diagId=51_9252
The M Bumper set-up for same car:
https://www.realoem.com/bmw/enUS/sho...diagId=51_9255
Look for difference in airducts as well. Some are interchangeable between SportLine and M Type:
https://www.realoem.com/bmw/enUS/sho...diagId=51_9256
Good luck.
2003 E39 530i 5-Speed w/ M Spec, Saphire/Black, M54B30, Active Autowerke Performance Tune
2010 Lancer GTS 5-Speed, Black Pearl/Black, 4B12
2015 F30 335i XDrive w/ M Sport Pack, Alpine White/Black, N55B30M0
2017 F34 340i XDrive w/ M Sport Pack, Azure II /Black, B58B30M0, Dinan Stage 1
      06-21-2023, 09:09 AM   #4
Boostedphil698
Originally Posted by Oksamit78 View Post
RobotDoctor
Good luck.
Nothing is interchangeable between the sportline front bumper and the m sport front bumper except for the kidney grills and the reflectors. All the ducting, supports and almost everything behind the bumper changes when you go OEM. It's not an easy swap and it's expensive. But, nothing beats OEM for body parts imo.
      06-21-2023, 12:04 PM   #5
Oksamit78
Oksamit78's Avatar
It is expected. I went through full M swap on my e39 M Spec car in the past, front and rear. Even the radiator front cover and ducting had to be replaced.
      06-21-2023, 12:12 PM   #6
RobotDoctor
Professional Nomad
679
I had seen that there are a few different parts. I have found a couple kits that contain all the necessary parts like ducting, supports, etc. I have still not decided whether I will do this or have the bumper repaired but am leaning on replacement. Problem with replacing the bumper to an M Sport version is that I will need to eventually replace the side skirts for a better aesthetic look. Then again I prefer the M Sport but the Sportline isn't hideous for this old man.
      06-21-2023, 12:13 PM   #7
Boostedphil698
Not fun at all. The deformation elements are the worst part as you have to move cooling system components to access the mounting bolts.
      06-21-2023, 12:18 PM   #8
Boostedphil698
If you're going to do the conversion I suggest buying the entire kit from getbmwparts.com. they sell the entire conversion kit for around 4900 shipped. The only thing it doesn't come with is the door sills and the steering wheel.
      06-21-2023, 02:49 PM   #9
RobotDoctor
Professional Nomad
679
Thanks! I will definitely keep this in mind. I appreciate the insight.
      07-18-2023, 07:02 AM   #10
RobotDoctor
Professional Nomad
679
The bumper damage isn't that bad so a bumper replacement is now not on the table. There is a bumper retaining rivet missing and a screw that was stripped. I will look for a replacement rivet once I find out what is used for the bumper and relocate the screw. I may look into adding a Sportline front bumper lip that will conceal the bumper repaint that I will end up doing.
