03-31-2018, 04:59 PM | #1 |
Rep 39
A/C Still Freezing after 3 "repairs"
so I just dropped my 2016 328 at the dealer for the 4th try at getting the a/c fixed. it seems to be the same issue that others have had where the a/c will essentially stop blowing air after any reasonable amount of time on the road, but nothing the dealer has done will get it working correctly.
first time around they did some sort of reprogram. second time around they replaced the compressor. the third time, after some sort of retrofit designed for this issue, I was told with confidence that it would be fixed. but of course 45 mins down the road and not only does it stop working, but one vent was actually blowing very hot air. so it's in the shop again with the service manager now heavily involved, but i don't know that they even know what's wrong. on her recommendation, we have also begun talks with bmwna and customer relations about a possible lemon law situation, but we would rather avoid that if possible. has anybody else had this similar issue? |
04-01-2018, 07:12 PM | #4 |
Rep 4,724
I had the same issue, but the reprogram fixed it. It's a known issue for 2015/16. I also heard of the retrofit too. Weird it's still doing it.
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive |
04-02-2018, 01:04 PM | #6 |
Rep 39
04-02-2018, 01:07 PM | #7 |
Rep 39
That is something I thought of. As I understand it, I would get something of nearly identical mileage, year, price, etc. but does anybody know if I would be able to pay out of pocket for features/packages that I don't currently have? That way would be much cheaper to get things like the M-sport body, LED lights and a couple other things that are pricey in the aftermarket route.
04-02-2018, 01:40 PM | #8 | |
Rep 10,473
There is a mileage deduction. Whatever cents per mile. That’s it. You are free to buy whatever car brand or model you want for whatever price....or buy nothing at all. |
MARC20102.00 |
04-02-2018, 03:17 PM | #9 | ||
Rep 39
04-02-2018, 06:24 PM | #11 |
Rep 39
04-02-2018, 06:26 PM | #12 | |
Rep 10,473
Did they replaced the ac condensor/radiator thats in front with the other radiators? A/c could be freezing up if there is moisture in system. They need to replace the ac condensor or at least the dryer in it and dry out all the lines Compressor will most likely need to be replaced as moisture will ruin it |
04-08-2018, 11:32 AM | #13 |
Rep 39
Update: the dealer called and let me know that the they completed the A/C repairs and should have the car back to me tuesday. i was told there was some freon leaking that may have been causing the problem. they replaced two hoses (can't remember which two off the top of my head but will update tomorrow with details) and said they have test driven it without any problems. The real test will be tuesday when the car gets delivered back to me as it is about a 5 hour drive. hopefully this fix works.
Thanks to you guys for your input. and hopefully you don't hear more from me about a lemon situation |
04-08-2018, 11:40 AM | #14 |
Rep 477
BMW can't do anything to avoid it. It's the law. Just get on the web and see exactly what the lemon law rules are for Texas. If you feel that you've met the criteria they outline, then just find a good lemon law attorney. Most won't cost you anything if the manufacturer is required to pay them if you win, and they usually waive any fees even if they lose. You are totally removed from the process until your attorney (hopefully) gets the outcome you desire. Most importantly, check the rules for your state.
04-08-2018, 01:59 PM | #15 |
Rep 4,877
Do you have the blower set to low? If there isn't enough airflow from the blower, the condenser freezes up, and you will lose A/C until it thaws again.
I keep my blower at the mid point, and have no issues. When I first got the far, I left it on low, and after a while on the highway, A/C stopped, it sounded like air flow got re-directed to thaw the condenser, and after about 1/2 hour it worked again. |
ZHP076145.00 |
04-08-2018, 02:59 PM | #16 | |
Rep 10,473
That’s when potent Lemon Law issues usually gets fixed. |
04-08-2018, 07:17 PM | #17 | |
Rep 477
The Four Times Test You pass this test if you have taken your vehicle to the dealership for repair Four (4) times for the same defect(s) within the first two years or 24,000 miles, whichever comes first; and the problem continues to exist. The Serious Safety Hazard Test A serious safety hazard is a life-threatening malfunction that substantially impedes your ability to control or operate the vehicle normally, or that creates a substantial risk of fire or explosion. You pass this test if you have taken your vehicle to the dealership two or more times for the repair of a serious safety hazard during first two years or 24,000 miles, whichever comes first, and the problem continues to exist. The 30 Day Test If your new vehicle has been out of service for repair due to a defect(s) that substantially impairs the use or market value of the vehicle due to defects covered by the warranty for a total of 30 or more days during the first 24 months or 24,000 miles, and the problem still exists. If no comparable loaner vehicle was provided to you by the dealer during this time period, you pass the test. It is advisable to contact the Lemon Law Section of the Texas Department of Motor Vehicles (TxDMV) for more specific information and assistance at (888) 368-4689. |
04-08-2018, 07:24 PM | #18 | |
Rep 10,473
As I noted, the car had not gone in 4 times and and most likely not been out of service for 30 days. Therefore, BMW COULD Avoid it, despite your early post to the contrary. Yes, 30 days is just one hurdle, but it is a hurdle unmet at this point. Therefore, it’s not the: You claim it to be. The AC is NOT a safety issue. It falls under the 30 day test of affecting market value. And if the dealership gave OP a comparable loaner, again your: Is false. Last edited by IK6SPEED; 04-08-2018 at 07:29 PM.. |
04-08-2018, 07:57 PM | #19 | |
Rep 477
From the Texas DMV: How many “reasonable attempts” to repair a defect is the manufacturer allowed? One way to show the dealer has had a reasonable number of attempts to fix a defect is to pass one of the following tests. Mileage requirements in the tests do not apply to travel trailers. The Four Times Test You pass this test if you have taken your vehicle to the dealership for repair Four (4) times for the same defect(s) within the first two years or 24,000 miles, whichever comes first; and the problem continues to exist. The Serious Safety Hazard Test A serious safety hazard is a life-threatening malfunction that substantially impedes your ability to control or operate the vehicle normally, or that creates a substantial risk of fire or explosion. You pass this test if you have taken your vehicle to the dealership two or more times for the repair of a serious safety hazard during first two years or 24,000 miles, whichever comes first, and the problem continues to exist. The 30 Day Test If your new vehicle has been out of service for repair due to a defect(s) that substantially impairs the use or market value of the vehicle due to defects covered by the warranty for a total of 30 or more days during the first 24 months or 24,000 miles, and the problem still exists. If no comparable loaner vehicle was provided to you by the dealer during this time period, you pass the test. It is advisable to contact the Lemon Law Section of the Texas Department of Motor Vehicles (TxDMV) for more specific information and assistance at (888) 368-4689. |
04-18-2018, 03:38 PM | #20 |
Rep 39
Update: I spoke with my SA and the service manager and they found that the expansion valve was not working properly, so they replaced that and i'm told that the a/c has been working properly on their drives since. I go to school 5 hours from the dealer, so they plan on delivering the car tomorrow to swap with the loaner i have. altogether on this 4th repair attempt, they have had the car for about 2.5 weeks and have had ample drive/testing time, but the 5 hour drive will be a true test if its working, as thats when it has stopped working in the past. I don't think the hoses they replaced were the problem, as it continued after that repair, but its good they got replaced. I think the expansion valve was the culprit. I will confirm that that was the issue once they get the car back to me with no issues.
I appreciate everyone's inputs. hopefully reading about this process will help anyone else having the same issues. |
CJ4211559.00 |
04-19-2018, 05:24 PM | #21 | |
Rep 477
hcw59.00 |
05-01-2018, 01:10 PM | #22 |
Rep 117
It seems like I have a somewhat similar issue. Had a three-hour trip back home today, outside temperature was 65F in the morning and went up to 80 later. After a couple of hours I noticed that the blow from the vents is gradually becoming weaker and warmer. Finally its temperature became equal to outside air, and even AC max mode did not do any difference - the fan was working on fastest speed, AC button was on, but it was blowing warm air. The climate control was completely useless for the rest of the trip.
I've asked our local BMW representational office if there are any TSBs available for my car, will see what they'll answer. |
