12-18-2021, 12:21 PM | #23 | |
Rep 126
Thx man you’ve helped me a lot in the past ! |
12-18-2021, 02:00 PM | #24 | ||
Rep 5,392
Login to Bootmod3 and connect to the car. I use a Kies WiFi adapter with my phone Choose OTS MAPS Choose the new map that you want Choose GET TUNE It will download the map from the Bootmod3 server to your My Maps Choose MY MAPS Find the new tune that you just downloaded You will see that the existing version is still in My Maps and the new one has been added to the list. If you click on each map it's version information comes up. See photo from my My Maps. Those are three different versions that have come out over the past few years. They don't go away unless I delete them. FOLLOW THE INSTALL GUIDELINES Make sure the driver's seat belt is connected, all headlights, radio, fan, etc are off Fold backseats forward and open trunk for emergency access to battery (I always drive around for 20 minutes before flashing to make sure battery is fully charged) Choose the new tune from My Maps Choose FLASH Hope this helps! |
12-18-2021, 03:37 PM | #25 | |
Rep 126
johnung4526.50 |
12-19-2021, 09:29 AM | #26 |
Rep 189
Hello !
I'm close to tune my recently acquired F31 340i. I read a lot on B58 tuning, limits etc... It seems BM3 (and probably others) are working very close to the limits on ignition timings. Some people recommend to use a lower octane map with a higher octane fuel in the tank. It seems OTS v2.2 maps are now boosting more. "Revised timing tables" may lead to less aggressive timing ? Long story short, I'm in France, with easy access to RON98 at every stations. with v2.2 stage 1 should I go to 93/98 tune or 91/95 tune ? thanks ! greatings from Bordeaux |
12-21-2021, 11:24 PM | #28 | |
Rep 1,452
2022 CT4-V Blackwing 6-speed
12-22-2021, 11:11 AM | #29 |
Rep 126
12-22-2021, 11:40 AM | #30 | |
Rep 82
Car is a rocket, way more power, you feel a good amount of difference, pulls harder through the entire rev range, feel more power up top too |
12-22-2021, 02:17 PM | #31 |
Rep 51
I've done more dragy pulls than I came to remember, and the fastest 100-200 I achieved with stage 2 93 was around 9.3 secs (heavy weight F31). First pull on the new stage 2 93 was 8.96. It's definitely quicker, but the last time I ran stage 2 93 was back in the summer so the cooler temps will have made some difference on that time.
12-22-2021, 04:21 PM | #32 | |||
Rep 77
also let us know how the new logs look! Thank you for your inputs. |
12-22-2021, 04:56 PM | #33 | |
Rep 126
But hopefully it punchier mid to upper if that low spike is lost a bit |
12-23-2021, 09:37 AM | #35 |
Rep 190,725
12-23-2021, 07:51 PM | #36 |
Rep 75
Just flashed the updated stage 2 93 octane. The torque feels wayyy better then the previous stage 2. I think overall power feels around the same. But the car is way more fun to drive. I used to completely hook in a 2nd gear pull… now in second I will spin tires all the way. Feels fun lol
12-23-2021, 08:42 PM | #37 |
Rep 77
Just flashed stage 2 91 octane myself. I definitely feel like overall the power delivery is much smoother. I do think power is much more linear and less of that punch. Mid and high range rpm there is power throughout as well.
Definitely need to drive it a little bit more to determine which one I prefer more. |
12-23-2021, 10:37 PM | #38 |
Rep 126
Well I just ordered the ER catted DP from X-PH for my 340i and it looks like I’ll be flashing that v 2.2 93 octane map soon.
12-24-2021, 09:08 AM | #39 |
Rep 190,725
Congrats
12-24-2021, 09:23 AM | #40 |
Rep 89
Coming from the BM3 Stage 2+ e30 to the e50, I can no longer safely drive in sport+. The car spins through 2nd gear...I love the additional power (plus I have a Vargas GC Turbo on order) but now I'm re-thinking my tire/wheel setup. Mod-Life is so expensive...lol!
12-24-2021, 10:05 AM | #41 |
Rep 82
I data logged again last night the new E50 map, new Michelin tires. Forget third gear to data log, car fish tails now versus e30, didn't do that. Car is much quicker. I was pretty spot on at E50 fuel, no timing pull, but rail pressure drop to 2000ish, then right back up. the rest of the log looks good. I am running the TU pump. At E35-E40 fuel on the E30 map, rail pressure was solid.
Anyone know how much rail pressure drop is acceptable? I was thinking about going down to E45, then logging, see if my timing is till good and if rail pressure gets better? |
M140_BCS237.50 |
12-25-2021, 11:01 AM | #42 |
Rep 2,124
I've noticed it's easier to reverse without losing traction with the new update
Previous: 2010 F01 740d M Sport | 2015 F36 420d M Sport
Current: 2018 F36 440i M Sport (Stage 1 BM3, xHP stage 3) |
12-25-2021, 02:12 PM | #43 | |
Rep 413
2017 440i F36 - Drexler LSD - B58TU HPFP - MHD Stage 2 - xHP - 200 Cell DP - MPE
12-25-2021, 04:46 PM | #44 | ||
Rep 24
M140_BCS237.50 |
