01-16-2022, 01:57 PM | #1 |
Rep 7
Help! BM3 Stg2+ E50 log review. HPFP issues?
Car is feeling weak after new stg 2+ e50 tune and upgrade HPFP.
Ran a 3rd and 4th log pull today after changing plugs, coils, and installing new Bosch B58TU HPFP. Log shows massive deviation from target boost. Also upgraded HPFP doesn't appear to be keeping up. Could you please review and give input? https://www.bootmod3.net/log?id=61e4...729b398efece7c 2016 340i Catless Burger air filter upgraded bosch HPFP 50k miles |
01-16-2022, 03:05 PM | #2 | |
Rep 5,392
01-16-2022, 06:24 PM | #3 |
Rep 7
01-16-2022, 07:52 PM | #4 | |
Rep 82
Also, I see less boost in cooler conditions, I saw your IAT at 60 and coolent temp at 172, that might be why you see less boost. |
01-16-2022, 08:37 PM | #5 | |
Rep 1,452
2022 CT4-V Blackwing 6-speed
01-16-2022, 08:38 PM | #6 | |
Rep 7
Fuel is likely just high of E50. Probably E52 from Calc. Was just under 40 degrees today. Pump was able to keep up in 4th gear. -3rd gear fuel pressure is wrong -4th gear boost just plummets top end Thanks for input. I'll siphon some fuel out of tank and test. Still don't understand hpfp 3rd vs 4th |
01-17-2022, 09:42 AM | #7 | |
Rep 82
Below is an E50 map, I'm running e48 for fuel in cooler temps. In looking at my logs, i'm not hitting boost targets up top in cooler weather. HPFP is much better at E48 versus E50 fuel. I have not run the 12/28 map yet, I think they made an adjustment for the HPFP to keep up. https://www.bootmod3.net/log?id=61d9...90c630d62f9671 Last edited by Cobra358; 01-17-2022 at 01:11 PM.. |
01-17-2022, 04:51 PM | #8 | |
Rep 7
I reduced boost target by 15% in 1st through 6th and it's running great. This has to be a lack of fueling exaggerated by denser air. I regret not splurging on the dorch stg2. By the way, the anti-siphon on these bmws is top notch. Haha. Could not test my fuel to compare to blend Calc. Thanks for the help. Will run log with lower boost target to confirm fueling issue. Might just drop to E30 stg2+ until I snag a dorch. |
