BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic Maintenance: Wash, Wax, Detailing, Repairs > Seat Belt Cleaner / Techniques
proTUNING Freaks
      07-23-2021, 01:04 PM   #1
sspade
sspade's Avatar
Drives: F30
2016 BMW 320i  [7.87]
2014 BMW 328i  [6.83]
After a brief search, Ive come up empty handed.
Wasn't so much an issue when I had the black interior but with the beige Ive noticed the seatbelts could use a freshening up.
Can anyone recommend a product they have tried on the F30 (or prior bimmer) and also what sort of technique or method you used?
      07-23-2021, 07:45 PM   #2
John in VA
Drives: 2015 228i M Sport
A dilution of all-purpose cleaner, Folex upholstery & carpet cleaner or Woolite used with a soft brush will work. Rinse well with cold water.
2015 BMW 228i in EstorilBlau II Metallic / Terra Dakota Leather - 6-speed manual, M Sport Package, Cold Weather Package, Lighting Package, Premium Package, Harman Kardon premium sound, Anti-theft alarm system, Blue Metallic Matt Accent Moldings, Aluminum Hexagon Interior Strips, Anthracite Headlining
sspade2464.50
jasonjo61.50
      07-23-2021, 10:52 PM   #3
WallySlash
WallySlash's Avatar
Drives: 2014 428xi Sport Line
2014 BMW 428xi  [9.00]
I extend the belts and use a binder clip to keep them from retracting. I use Woolite as well to soak the belts and then scrub and rinse. My final rinse (or two rinses) is a mixture of 25% white vinegar and 75% water to ensure all the soap is out. Will smell like a pickle for a day and then the vinegar smell is gone. I have a two door and starch the belt where the seatbelt extender catches the belt so it doesn’t slip off.
sspade2464.50
      08-03-2021, 08:08 AM   #4
sspade
sspade's Avatar
Drives: F30
John in VA WallySlash
Fellas... finally got around to picking up some Woolite. Unsure on a reasonable dilution to use. Any suggestions?
Going to pull belts all the way out, clip in place at the top and soak as much of belt as possible in the solution. Let sit for an hour and then agitate belt with a brush. Finish with a thorough rinse or two.
      09-18-2021, 02:30 PM   #5
bmw310
Drives: 528I
Dishwashing soap works wonders.. and its one of the most mild.
      09-18-2021, 02:42 PM   #6
johnung
Oxiclean laundry stain remover
      09-22-2021, 11:30 PM   #7
gerdasmi
Drives: BMW F11
I should do this myself as well
      09-23-2021, 09:52 PM   #8
Onizukachan
Great Teacher
Onizukachan's Avatar
1086
Drives: 06 e91 325ix
2006 E91 325ix  [10.00]
2006 Mini r53 JCW  [0.00]
2005 Mini r53  [0.00]
Scrubbin bubbles and a microfiber towel on the e46 (grey).
Nothing on the black ones on the e34 or f30.
over Terra (one of 1), Nav, Sport, L7
A few OEM+ mods:
MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come…
      01-09-2022, 05:16 AM   #9
pawciq
Drives: F30
stain remover
      02-08-2022, 03:13 AM   #10
Rale92
Drives: BMW F36 428i XDrive
did you have any luck removing the stains?
sspade2464.50
      02-08-2022, 07:33 AM   #11
sspade
sspade's Avatar
Drives: F30
Yes… the Woolite works well! Cant speak for the other solutions but if you have light colored belts that have some miles on them… you'll notice a fair difference at minimum and the color of the water will be proof that something is good is going on.
A couple months out and no negatives to report. Belts are very soft and no residue. The smell was pleasant at first but vanished rather quickly.
Rale921.50
      04-09-2022, 05:34 AM   #12
alltalk
Drives: bmwf30
Has anyone tried steam?
works well for me with clean cloths
sspade2464.50
