07-04-2018, 04:57 PM | #133 | ||||
Rep 6
after following these steps, it worked! Quote:
07-05-2018, 01:48 AM | #134 | |
587
Rep 898
BM3, MHD, ECUTek Calibrator | N55/S58 specialist | 2023 X5 45e Frozen Marina Bay Blue
07-06-2018, 09:30 PM | #135 |
Rep 109
07-06-2018, 10:26 PM | #136 | |
Rep 10,473
07-06-2018, 10:40 PM | #137 |
Rep 109
i picked up a OBD agent hardware device and can't seem to get it working. i have been working with with their tech support two weeks. its definitely connected to my iphone hotspot (bootmod3/bootmod3) but OBD agent not detected. i wiped the microsd card and copied the .img back to the microsd card(firmware update)
https://bootmod3.atlassian.net/wiki/...irmware+Update I cant figure out what i'm doing wrong here. |
07-09-2018, 08:56 AM | #138 | |
Rep 2,382
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit |
07-10-2018, 10:01 AM | #139 |
Rep 109
I've been working with PTF tech support for the past two weeks on trying to get get this device agent working. i know for a fact its connected to the iphone hotspot but when i launch the bm3 app and update the agent. the app keep saying OBD disconnected. now, theres nothing wrong with my enet cable, because it works just fine on my laptop. and the device agent ethernet port has activity flashing LEDS.
im stumped as hell why its not work and PTF tech support seems to be clueless also. |
07-11-2018, 09:04 AM | #140 |
Rep 2,382
Have you tried seeing if you're getting an IP while it's plugged into the car?
07-11-2018, 09:40 AM | #141 |
Rep 109
yes, i have logged into the raspberry box with a hdmi monitor and usb keyboard. i was able to get an dhcp ip address from the iphone hotspot and i was able to ping out to yahoo.com
07-12-2018, 11:42 AM | #142 |
Rep 2,382
No, I'm talking about getting an IP once plugged into the car.
07-16-2018, 07:10 PM | #144 | |
Rep 771
I had gotten it to work for a day but then ran an update and then i dont know what happened... Gonna also try connecting to a different phone....frustrating
2020 BMW M340ix Dravit Grey
2018 BMW M3 Alpine White |
07-16-2018, 07:12 PM | #145 | |
Rep 771
07-17-2018, 08:56 AM | #146 |
Rep 2,382
You should be plugging into the ethernet port directly. I just built another one just this weekend with the latest update and had no issues.
07-18-2018, 06:38 PM | #147 |
Rep 771
Got it working. A lot of times i have to go into the BM3 menu on the ABOUT screen and hit RESET SETTINGS and it connects after 30 seconds.....but this is way way better than a tethered laptop in the car for flashing and logging. so much easier. This is definitely the way to go!!!! Thanks
JaredG_F301106.00 |
07-19-2018, 06:36 PM | #148 |
Rep 396
Drives: 2014 335i M Sport, 2004 .:R32T
just got everything setup and worked flawlessly. thank you OP for this thread!
F30_SixSpeed1170.50 JaredG_F301106.00 |
07-23-2018, 05:53 AM | #149 |
Rep 443
Thank you for this OP!
Just built mine for under $35 total Thanks to amazon prime day! |
JaredG_F301106.00 |
07-25-2018, 03:29 PM | #150 |
Rep 72
Will be setting up mine this weekend. Thanks for the write up.
13' F30 335i
F80 M3 Front End, VRSF Catless Downpipe, BootMod3 Stage 2 E30 OTS, ER Chargepipe, VRSF 5" FMIC, BMS Intake H&R Super Sport Springs, Fuel-it Stage 2 LPFP |
JaredG_F301106.00 |
07-29-2018, 06:27 AM | #151 |
Rep 415
Another one setup using your guide, thanks 👍🏻.
Had some issues with the hotspot but need to go through the troubleshooting guide to sort it. Worked perfectly by connecting my iPhone charging cable into the device. Connected instantly. |
07-29-2018, 06:19 PM | #152 |
Rep 72
Im having some issues getting mine set up. On the first attempt I downloaded the firmware supplied in the link from the OP. I connect it to my car, and it tells me that I need to update to the latest OBD agent. After doing so, my phone switches over to screen that says it needs to restart. After waiting about 20 mins on that same screen, i disconnected and restarted the app. Still get no success.
Last night I go onto BM3's website and downloaded the latest firmware from off the site and write it to my sd card. Today I turn on my hotspot, see that the agent has connected, run the app, and it says to Update my agent again. As we speak my phone is back on the same screen that says "Restarting..." it has been on that screen for the past 45 mins now. Feeling defeated
13' F30 335i
07-30-2018, 09:16 AM | #153 | |
Rep 2,382
08-01-2018, 08:06 AM | #154 | |
Rep 72
Aside from that I guess everything else is working fine the device agent itself, since my phone picks it up when I turn on my hotspot.
13' F30 335i
