BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > BMW 340i B58 VRSF Downpipe DIY :) NO CEL ;) *SOUND CLIP* Stock exhaust+Catless DP
proTUNING Freaks
      12-10-2017, 02:37 PM   #23
F30MGM
F30MGM's Avatar
Drives: 2016 340i
Originally Posted by paimon.soror View Post
Originally Posted by F30MGM View Post
Still check engine light free
Thats awesome. I am hoping I have the same luck. Not sure if it is worth just getting an L spacer like yours, or getting something like this
http://www.fabspeed.com/universal-o2...tic-converter/
The 911 guys have had some great luck with this, wondering how the F chassis do.
Well it's 15$ vs 125$. I still haven't had a CEL with my 15$ spacer yet after over 2k miles of driving. Choice is yours
Car List:
2000 328i E46 Steel Gray Metallic 5SPD MT- Sold
2016 340i F30 M Sport Mineral Gray Metallic 8SPD AUTO - Current
      12-10-2017, 02:39 PM   #24
paimon.soror
paimon.soror's Avatar
Drives: 2016 F36 435x MSport
I like your thinking.
      03-15-2018, 08:17 PM   #25
ocN55
ocN55's Avatar
Drives: '15 M235i 6MT/ '16 M3
OP, ever got a CEL yet?
Hope the answer is no because I want to do the same
FBO M235i r
F80 M3
      04-28-2018, 11:47 PM   #26
infamous2119
Drives: 2018 BMW 340i
Great tutorial! You saved me a lot of time. I didn't have the expansion tool so I spend majority of time trying to get the mid section on. I used the L spacer as well. However I am getting a CEL. Is there anything I am forgetting to do that's not mentioned in this tutorial?
      05-06-2018, 05:25 PM   #27
F30MGM
F30MGM's Avatar
Drives: 2016 340i
send a photo of how you have it
Car List:
      05-13-2018, 08:47 PM   #28
infamous2119
Figured out the issue. The spacer DOES work. One of the o2 sensor pins was bent when I plugged bank 1 back in. It was bank 1 throwing the CEL.
      07-29-2018, 09:01 AM   #29
Jadenkid22
Jadenkid22's Avatar
Drives: 2019 X3 30i M sport
Almost a year later and still no CEL? I don't have a b58 , I have a N26 but that's amazing
      10-16-2018, 12:09 AM   #30
fb58
Drives: 18' AT 340Xi
grabbed one for my er downpipe. will keep thread posted.
EDIT: didnt fit :L
      11-28-2018, 09:57 PM   #31
F30MGM
F30MGM's Avatar
Drives: 2016 340i
How's everyone's b58 ? my CEL is still off 😁
Car List:
fb5830.00
540iSUP704.00
      12-12-2018, 12:56 AM   #32
vinzcast21
vinzcast21's Avatar
161
Drives: F30 340i MY2017
What the hell why is the fuel indicator going up and down
Mod bug will bite you if you buy a BMW
      12-13-2018, 02:12 PM   #33
kern417
Cheapskate
4450
Drives: 2018 440i |2016 340i | 2010 X5
JB4 turns the fuel gauge into a boost gauge under certain circumstances, like flooring it.
Youtube/Instagram/TikTok: @kern417
540iSUP704.00
      01-11-2019, 06:49 AM   #34
Martin30x
Drives: 540i xdrive
Guys how is your MPG now with downpipe fitted.
Had rs4, with dp and it takes much more petrol.
I am thinking of fitting dp in 540i but I am unsure now.
Btw: anyone with b58 have checked emission ? How much goes up.
Rs4 was over 4x times higher and you could smell fuel from exhaust.
DP will be arriving somewhere next week for 540i b58.
      01-14-2019, 03:08 PM   #35
patofdzb
Mexico
Drives: F80 2018
Wow, this makes me want to get a dp
      03-08-2019, 11:39 AM   #36
CodyReviews
CodyReviews's Avatar
Drives: F30
Did you only use the extension on one 02 sensor?
Looking for YMB 6SP F80...
      03-08-2019, 02:44 PM   #37
JD11937
Drives: 2017 M240xi
I have the CG Downpipe and was getting a code error reading when I checked through my jb4 and occasionally a light on the dash. O2 spacer made both go away.
      03-08-2019, 07:03 PM   #38
EB340i
Drives: Stock 340i
Most people probably don't care but what does the catless DP and O2 spacer do to the fuel economy?
      03-25-2019, 08:42 PM   #39
heusing240i
2018 M240i / BMS CAI / JB4 / Catless VRSF
heusing240i's Avatar
Drives: 2020 Misano Blue M2CS
For those who installed a vrsf, are you reusing the factory V-clamp?
Can't stop the //Addiction...2020 Misano M2CS 6MT - New Toy
2018 m240i b58 - Formerly owned / BMS CAI / VRSF DP / JB4 map 2 - 340WHP; 363TQ
2016 328i xdrive n26 - daily
2015 GMC Sierra 1500 - daily driver
HEUSING240i
      05-13-2019, 10:36 AM   #40
Tiago@VRSF
Tiago@VRSF's Avatar
Drives: F90 M5
Most end up re-using the factory clamp
      05-14-2019, 03:43 PM   #41
Solid67
Drives: 2019 M240i xDrive MP Edition
How bad will the car smell with VSRF or any aftermarket DP and stock mid/axle back?
      05-14-2019, 05:19 PM   #42
Tiago@VRSF
Tiago@VRSF's Avatar
Drives: F90 M5
If properly installed, you won't notice any smell at all unless you're in bumper to bumper traffic on the highway with your windows down or are idling in your garage.
      06-06-2019, 02:15 PM   #43
BornATeste
BornATeste's Avatar
Drives: 2016 340i Sportline Black RWD
soundclip added, and for the undercover, you gain some access to certain angles which are nice to have when youre under the car, so i took mine off
Did you need to use any extensions to give the ratchet space to turn when you were loosening the v-band clamp and the two small mounting nuts?
      06-10-2019, 02:03 PM   #44
Brett530
Brett530's Avatar
208
Drives: '17 F30 340i
I posted some of my notes after doing my downpipe install as a supplement to this DIY (which was very helpful - Thanks!).
https://f30.bimmerpost.com/forums/sh....php?t=1623235
2017 F30 340i RWD // MG Flasher // xHP // CG DS-1 // ZTR ZMP ZCW ZLP
