09-04-2023, 02:51 PM | #199 | |
Rep 487
In terms of aftermarket verse factory, if you choose wisely you can tailor the sound more to your liking and can exceed the carity and dynamics of the BMW systems from my personal experience. But also treatments such as sound deadening door panels and door cards does help. For audio with a trunk sub check out Mobridge 8.1.1 amplifier, ticks so many boxes, Full dsp, 9 channels of Audio with 400 - 500 rms on sub bass, Large voltage rails for underseat wooder amp channels ( 2-8 ohm no prob ) uses BMWs most digital audio for music and all idrive sound functions. One box solution rather than 3 if going using Match to achieve the same. . |
09-08-2023, 05:29 PM | #201 |
Rep 487
I’m also running with the six speaker positions that was derived from base audio. Have replaced door speakers with components , underseat woofers were 6.5s replaced with Harman Kardon ( they are ok ) and then replaced again with aftermarket. I don’t have center channel or rear parcel shelf speaker mounts.
Other than more sound treatment for trunk / boot it’s sounding really good. 10 inch sub however is less hassle from working through rattles than what I’m running. Hopefully give you some ideas Last edited by NealfromNZ; 09-08-2023 at 05:47 PM.. |
Arthurrs92.00 |
11-11-2023, 08:14 PM | #202 |
Rep 1
I have owned several bmws. I started by replacing the subs. It sounded much better than the stock HK. Next I replaced all 16 speakers throughout the car. Sounded much better especially when you stream music through Bluetooth. The satellite radio signal is very poor from bmw, honestly im not sure why. Just try it with the system you have now. Lastly I replaced the amplifier. This upgrade made the biggest difference of all. Not cheap but definitely worth it. Direct replacement. If I were you I would start with the subs then the amplifier. Even cheap paper cone speakers sound 10x better with more power and less distortion. Good luck which every rout you take
11-13-2023, 02:25 AM | #203 |
Rep 69
Drives: 2013 F13 M6, 2013 F30 328i
Guys Im having the 676 Hifi system, was wondering which upgrade sounds better?
BMW logic 7 Surround amplifier (with rear bookshelf adding) OR Match 7/8UP plug play? |
11-13-2023, 09:56 AM | #204 |
Great Teacher
1088
Rep 1,305
Drives: 06 e91 325ix
Match up7bmw with my or someone else’s tune file.
over Terra (one of 1), Nav, Sport, L7 A few OEM+ mods: MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come… |
NealfromNZ525.50 |
11-15-2023, 05:21 AM | #205 |
Rep 15
I recently installed this the SWS 8 in my G31, but I used the ESX QM500.4 amplifier. The sound appears less clear and more bass-heavy compared to before. It feels like there's an entire section of the frequency spectrum missing. I'm curious about how the frequency range of this component compares to the original BMW HK woofers. If a part of the range is indeed missing, adding a DSP may not be the solution.
11-15-2023, 07:09 AM | #206 |
Rep 16,088
The range isn't missing, you're just hearing the lower extension of the SWS combined with less upper bass sensitivity. DSP is the fix. The #1 shortcoming of the OEM systems is lack of a good DSP. It's why the Match Up amps are recommended.
11-16-2023, 12:30 PM | #207 | |
Rep 487
.https://www.crutchfield.com/S-duuDMW...converter.html If you turn the system you could damage the new amplifier. Look for a Loc that can take speaker level inputs of 32 volts or more EG. https://jlaudio.zendesk.com/hc/en-us...5989953-LoC-22 Here’s your amp showing a maximum input of 5 volts which is far to low when connected to the Hk amp woofer outputs. |
03-28-2024, 01:57 PM | #208 |
Rep 5
Hello everyone…. Been posting in the wrong places I guess and still haven’t received any helpful info so here goes. I got the Match 7UP amp and replaced every speaker with the Audiotech stuff except the under seat subs and I went with the Focal shallow subs. Well, one went out and i wanted to see if anyone’s had better “luck” with other subs. Definitely not the Bavsound and the Earthquaker seems like it would be a downgrade. I have a DD 3512 12” sub in the trunk wired through the pass through on the Match amp so I’m really looking for something that has a bit of punch or mid bass maybe? I dunno. Thank yall!!
03-28-2024, 04:24 PM | #209 |
Rep 487
What are your dsp settings and filters running on the Focal woofer channels.
What frequency range do to run the 1, Sub eg 0-xx 2, Focal woofers xx - xx 3 Match mid bass / tweeters xx -20,000 Do you run them in phase or out of phase with mids and sub ? ( phase transition at either end can cause dips if phase transition is wrong ) And did you go for 2 ohm or 4 ohm versions of the Focals ? ( match amp will have more transient power available driving 2 ohm versions ) Or it could be simply gain on Subwoofer is too high not allowing the focal woofer blend and keep up volume wise in that transition between sub bass and bass. I could recommend what I run as can get great impact from the underseats but the dsp tune is essential to get this to happen. Graphs of RTA response will help here as a number of us can comment and suggest if your tune is optimal before doing woofer replacement. |
04-10-2024, 06:24 PM | #210 |
Nitrorc21
Rep 2
anyone try the axton 8inch subwoofers ? seem to be a perfect choice for eu customers if they are decent sounding
https://www.ebay.co.uk/itm/186000785...&segname=13110 |
04-10-2024, 10:02 PM | #211 |
Rep 16,088
The only way to know how any driver will work is via speaker modeling software using the driver Thiele-Small parameters. They're found on driver data sheets, for instance: https://www.parts-express.com/pedocs...spec-sheet.pdf
04-11-2024, 02:24 PM | #212 | |
Rep 487
Running Morel BMW which come in 2 ohm. They should take the full power of the match amp and load the channels up nicely. They have almost double the power rating of the focals so harder to overpower them. They are a nice acurate underseat woofer and do have impact when tracks demand it. They also follow acoustic bass nicely. I have mine filling from an acoustic 60 -175hz with the crossovers running 45-175 hz. Have an old but well performing high excursion sub doing 15-60 hz and the morels blend in nicely. |
bigdnno98288.00 |
04-20-2024, 08:08 PM | #213 |
Rep 11
This is an awesome thread! Loved Johnung's install pictures. I have a 2018 F30 sedan with the H/K Logic 7 system. It's not bad. I started out looking at the BimmerTech and Bavsound systems, but it seems an awful lot of $ just because they've made it PnP, not because it's superior equipment.
Not wanting to throw thousands of $ at my system at once, I was going in stages.. I started with the underseat woofers. After a lot of research, I settled on a pair of Integral Audio SoundStage series 8 ohm woofers. After installing those, things sounded worse, and I went back to the stock H/K woofers. I'm assuming the stock H/K amp isn't feeding the Integral Audio woofers enough power? So, next I found a pair of Audison BMW4KE components, and threw those in the front doors, which really woke up the system. I have some more separation and clarity, with a bit more volume. I want to keep going, and after reading Johnung's posts about adding the AudioControl ACM-2.3 amp, it seems like that would be the next logical step? That'd be about $350 vs almost $2K for an 8 ch amp with DSP. I was hoping Bill or Johnung could give me an opinion on whether I'm going in the right direction? Will the addition of the AudioControl amp running the underseat woofers give me a better soundstage? Also, I see that Johnung ran thicker wires directly to the woofers, rather than a more plug and play system using the factory connectors. That was the only part of the install that confused me. Last edited by Airtraffic; 04-21-2024 at 07:11 AM.. Reason: Typo |
04-21-2024, 04:12 AM | #214 | |
Rep 487
Did you try swapping +- wires on one side ? I hear that HK runs speakers on opposite polarity on under seats. Gets a bit more output @ 80-90hz but below 50hz it drops away. |
04-21-2024, 05:04 AM | #215 |
Rep 487
This is roughly what you'd end up running HKs with more power. The Amp feeding this graph gives them 120 - 140 rms. At this volume level it's getting reasonably loud.
Yellow = booth woofers playing together and running the same polarity. Green = left woofer purple = right woofer The lower end needs bumping up and the higher end needs pulling down a bit. But they did sound ok, but not amazing. HKs have a drop around 55hz mark so lower bass guitar region. But come back up a bit lower. Ironically running these High passed at 20 hz meant more buzzes and rattles where occurring. I run different under-seat speakers 45hz up and it's less of an issue even with trunk sub. But if I run those down to 20 hz the low end performance from 20-60 hz is substantially better than HK. |
04-21-2024, 07:13 AM | #216 |
Rep 11
Neal, thank you for the reply.
"Did you try swapping +- wires on one side ? I hear that HK runs speakers on opposite polarity on under seats." Since these involved factory connectors, I did not experiment with changing polarity of the wiring. |
04-21-2024, 09:32 AM | #217 | |
Rep 5,392
The Earthquakes need more power than the HK amp provides. But the HK amp doesn’t have typical connections to add a secondary amplifier. So a high voltage LOC is required to interface the HK amplifier to a secondary amplifier that will drive the Earthquakes. My goal was to improve the bass sound of my H/K system without taking up valuable trunk space. I searched for over a month before finding the perfect solution, the AudioControl ACM-2.300 combination LOC/Amplifier. High quality, perfect power to drive the Earthquakes and small size. I mounted it on top of the tool compartment in the right trunk alcove above the battery. Also needed is the $65 custom harness from Technicpnp website. Provides easy connections with no wire splicing and it’s easily reversible. An Earthquake spacer ring kit (~$27) is also needed to mount the Earthquakes in the BMW sub cabinets. When I installed this upgrade several years ago we weren’t sure if the stock speaker wire that BMW was using between H/K amp and the underseat subs was a heavy enough gauge. So I bought speaker wire (14g i believe) and ran it from the secondary amp to the Earthquakes. Since then a number of people have used the stock wire and I haven’t heard of any issues. Using existing wires is easy to do. The Technicpnp harness is just configured to use existing wire. At the Earthquake end the stock wires are terminated at a rectangular plug. Just clip off the plugs with 1-2” of wire remaining so it can be reversed later if necessary. Then just strip the wire ends and insert into the spring clips on the Earthquake spacers. For a car with the H/K system, this configuration of Earthquake SWS-8Xi subs & spacer rings, Technicpnp harness, AudioControl ACM-2.300 is the best way to upgrade the stock bass. It makes the HK system sound like it should have from the factory without taking up valuable trunk space. Now keep in mind this is not going to thump the cars around you at a red light like a large trunk mounted subwoofer, but they have their own issues too. There’s no doubt that a Match 10DSP amplifier setup with the Earthquakes would sound amazing because it adds a new modern DSP system. But it costs much more. Hope this helps! |
04-21-2024, 10:35 AM | #218 |
Rep 11
Thanks Johnung, that's super helpful! I'm not the type that feels the need to thump, just a full soundstage is really what I'm after. I'll likely take this route, as it's about 1/3 the cost of the 10 DSP. That'll have to wait until next year. Until then, thanks for the help!
