BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > Intermittent Stalling B58
      10-31-2024, 06:21 PM   #1
samspiderman3125
samspiderman3125's Avatar
60
Drives: 2017 440i gran coupe
Currently having an issues where my car (2017 BMW 440i F36) intermittently stalls out while driving, only codes are 1-6missfire and it feels like the car runs out of fuel.
If you leave the car for a few hours and come back, you get correct fuel pressure and all is good.
Spool FX150
Reflex+
Spool stage 3 LPFP DIY
Precision raceworks 750cc injectors(PORT)
Want to mention that the LPFP is rigged off of a HOBBS switch.
Sound like an EKPS to you? How can I test this?
      11-02-2024, 03:54 AM   #2
jav140i
jav140i's Avatar
Drives: BMW M140I
Similar problem with my car, im guessing EKPS can be the problem
      11-02-2024, 07:01 PM   #3
blacksapphire440i
Novice
blacksapphire440i's Avatar
320
Drives: 2018 440i Gran Coupe
Spool FX150
Reflex+
Just asked my tuner about this
This could be your EKP module or fuel pump module that the EKP wire connects to.
Whos your guy's tuner?
MHD by default runs the EKP at 90% load and my tuner said he runs it at stock which is lower than MHD
      11-04-2024, 10:01 AM   #4
Oksamit78
Oksamit78's Avatar
Drives: E39, F30 & F34
I've having the similar stalling issue of my car (2017 F34 with B58) while normal driving. Car is stock except Stage 1 / 91 tune and intake by Dinan. Car has ~ 96K km (~60K miles on the clock). The intermittent stalling had started roughly 4 - 6 weeks ago and it does happen at idle and at low RPMs (less than 2k RPM) at highway speeds. Frequency of stalling is around every 30 - 50 seconds once engine warms up (not as much on cold). Any recommendations for at-home testing for the culprit? Thanks!
2003 E39 530i 5-Speed w/ M Spec, Saphire/Black, M54B30, Active Autowerke Performance Tune
2010 Lancer GTS 5-Speed, Black Pearl/Black, 4B12
2015 F30 335i XDrive w/ M Sport Pack, Alpine White/Black, N55B30M0
2017 F34 340i XDrive w/ M Sport Pack, Azure II /Black, B58B30M0, Dinan Stage 1
