01-29-2019, 11:37 AM | #310 |
Rep 1,499
That's what I thought. I've noticed it takes longer to connect with my iPhone XS versus my old iPhone 7. I'll try your method and see if that works better for me. I have a 6 speed manual.
01-29-2019, 01:42 PM | #311 | |
Rep 937
Gotcha, I've got 8at and just wanted to ask some questions regarding shifting, thanks though
Hi
02-04-2019, 10:19 PM | #312 |
Rep 170
Anyone else having trouble updating their agent right now?
My agent keeps trying to grab an update from https://www.dropbox.com/s/dl/nxejiaartuu83xd/agent.jar But it keeps saying it failed since the link goes nowhere. Strange that they are using dropbox to host updates haha. |
02-04-2019, 10:27 PM | #313 |
Rep 170
Protip.
https://www.dropbox.com/sh/zqbgzb6df...6Oqa?dl=0&lst= Grab it from here and use scp to load it onto your device. From windows Code:
scp C:\users\urname\Downloads\agent.jar bm3@169.254.0.2:/home/bm3/ |
02-05-2019, 05:28 AM | #314 | |
Rep 210
deezeedee33532.00 |
02-05-2019, 10:33 AM | #315 | |
Rep 86
Please report back our findings if you get a solution!!
2013 F30 335i PWG
VRSF DP/ VRSF FMIC/ ER CP/ AFE Intake Filter/ PowerStop Brakes/ Custom Exhaust/ BM3 Stg 2/ AEM Water Methanol Injection/ MotorSports Hardware Studs, Locks and Spacers |
02-05-2019, 10:52 AM | #316 |
Rep 325
Drives: 2016 F36
It was an issue with the third party "installer" program and the file was temporarily removed for updates. They just released v51, which should take care of the auto update and install for the agent. The new app is up for android and pending Apple review for iPhones.
◊ 2016 F36 xDrive N26 ◊ Black Sapphire Metallic ⁞ Dakota Black ◊
║ VRSF HD FMIC ║ ER DP custom paint ║ AWE cat back Exhaust Suite ║ NGK Plugs ║Bootmod3 Stage 1 93 ║ GFB DV+ ║ BMS 10mm Front ⁞ 12mm Rear Spacers ║ P Style BSM Rear Spoiler ║ Smoked Front Reflectors ║ Madico Onyx 20 Tint ║ LCI Lighted Trim Bezel ║ Opti-Coat Pro+ ║ |
deezeedee33532.00 |
02-05-2019, 12:23 PM | #317 |
Rep 1,499
So I've played around with different startup sequences and this is the best I've found.
With car locked and asleep... Unlock iPhone and browse to the Hotspot Page Unlock car via remote Observe the iPhone screen until you see the hotspot connection icon (clock in upper left-hand corner turns blue) as you enter the car Launch bm3 app The app should show a connection to the vehicle and vehicle vin If the app get hung on "connection to OBD agent" then shut down the app and restart
02-05-2019, 04:59 PM | #318 |
Rep 340
i left a hotspot in the car power by usb cable from avin 10.25 android. same with the wifi agent.. when i turn on the car and open app it connect constantly
2016 435i GC - FBO - PS2 - XDI-35 hpfp - Stage 2 lpfp - M performance LSD -Custom tune BM3 w/ MHD monitor - xHP Flash stage 3 - Valvetronic Design Exhaust
02-07-2019, 12:38 AM | #319 |
Rep 373
Is anyone having a similar issue, once i am connected to the agent and update it via the app it says updating then a minute later says updated completed. Once this happens the agent disconnects from the car and never reconnects. I cannot use it at all as it does the same thing every time. Anyone got any pointers or tips?
'14 F20 M135i EWG FBO:// INJEN INTAKE // PURE INLET// TURBOSMART BOV DUAL PORT // //CSF INTERCOOLER // ER CP // SNOW S2.5 METH KIT // B58TU HPFP // NGK 97506 // ER DP // TMSS MID PIPE //MPE // MPBBK // UR STRUT BRACE // BM3 CUSTOM JORDAN E85 TUNE // XHP STAGE 3 // |
02-07-2019, 09:01 AM | #320 | |
Rep 2,653
02-07-2019, 02:12 PM | #321 | |
Rep 1,499
yeah...evidently PTF changed the server location for the firmware file so the update through the app won't work until you flash the latest v51 image which will require removal of the SD card and flash via computer.
02-07-2019, 07:41 PM | #322 |
Rep 50
So I just flashed my sd card to v51 and everything was fine until it said to update. After the update it lost connection still. The latest update that I know is v52.
02-08-2019, 05:50 AM | #323 |
Rep 5
Same here, Phux.
Downloaded v51 for both and it's ok! After v52 app update, the same problem to apply the update to my wifi agent. Last edited by tskstar; 02-08-2019 at 06:27 AM.. |
02-08-2019, 07:09 AM | #324 |
Rep 931
V52 they released is solid. If you’re not running that they said you will have an issue with updating it. They also fixed some other things they said. I got the v52 app update too this morning. Its already out for Androids.
02-08-2019, 07:37 AM | #325 | |
Rep 1,499
Yeah it looks like they were having so much backlash over the v51 update not being able to be pushed through by the agent that they changed again to v52. I believe if you are anything older then v51 that the auto update now will work to update to v52. Time to pull the SD card and flash again.
02-13-2019, 06:48 AM | #327 |
Rep 1,206
Last night i was trying to update my raspberry pi wifi agent which i bought from someone here that i never used. I downloaded the latest firmware. Unzipped it to roughly 7 gigs. Then i used the etcher to write it to the SD card. This process happens smoothly. It says writing then it authenticates. It says 100% done and completes. However when i look at the card i dont see the latest firmware there. So i am assuming it didnt work.
I keep getting an error to format the card. I dont think i want to do that. I am guessing that will delete the entire card which i am not sure i want to do?? I think the error comes bc its a Linux files on there?? Should i be seeing the latest firmware on the sd card after etching? Should i format the card? Thanks for help |
02-13-2019, 07:58 AM | #328 | |
Rep 2,653
02-13-2019, 08:18 AM | #329 | |
Rep 1,499
Are you trying to view the Sd card file via a Windows machine? You might not be able to see the files. I know when I plug the SD card into my windows machine it also asks to format the card. Before worrying about viewing files on your windows machine plug the SD card into your agent and see if you can connect.
02-13-2019, 08:26 AM | #330 |
Rep 1,206
