11-03-2019, 02:59 PM | #969 | ||
Rep 237
11-03-2019, 02:59 PM | #970 | |
Rep 67
how to get google voice activation working system wide.
problem: "ok google" only working in google maps & assistant but not in dashboard. problem source: google app not installed as system app inside the google app -> more settings -> voice -> voice match > "access with voice match" is greyed out and can not be toggled on. solution: move app to system requires root https://forum.xda-developers.com/sho...&postcount=740 adb connect IPort adb root adb connect IPort adb remount adb shell mv /data/app/com.google.android.googlequicksearchbox* /system/priv-app/ adb reboot enable voice match. -> now you can use "ok google" everywhere. Quote:
11-03-2019, 04:40 PM | #971 | |
Rep 159
I didn't have that fast boot prior to installing that new firmware px6-9.0_2019092901T. The only setting I changed was enabling "Stay Awake" in the Developer Settings under the Android Settings. I'm unsure if that did it, I can't even remember if I even had that option prior to the firmware upgrade. Interesting to point out is: It cold boots if I shut down my car and return to it within 1-3 minutes. It fast boots only after longer sittings, which doesnt make sense to me I need to play around with it some more. |
11-03-2019, 04:43 PM | #972 |
Rep 67
stay awake should have nothing to do with it since its a native android setting and not related to the car communication.
very strange indeed, if you can reproduce the warm boot for some days please give a quick headsup, really interested about this. |
11-04-2019, 06:45 AM | #973 | ||
Rep 45
11-04-2019, 06:55 AM | #974 | |
Rep 29
The app is working great for me. I'm using it everytime now. Also it doesn't require root. BUT... The main problem (and why I haven't released it yet) is that I'm using the steering wheel scroll wheel to adjust the dimming and switch day/night mode. And to use this button you have to make sure the default music player doesn't start at boot. When the music player starts at boot it enables the play/pause/next/previous music functions. So when you change the dimming it also change the music lol. It can be problematic for most of the people. The dimming can also be control using an Android intent so you can use it with Tasker or Automate. I would like to find a solution for the controls so it can satisfy everyone.. Let me guys know if you have an idea. RaceX58 |
11-04-2019, 07:24 AM | #975 | |
Rep 29
I'm asking myself if we can upgrade an Android 8.1 device to Android 9 using a PX6 update.. Does someone have an information about it? |
11-04-2019, 07:45 AM | #977 |
Rep 29
11-04-2019, 08:09 AM | #978 |
Rep 1,407
Drives: 13' F30 328i 6MT
I did the glove box and center console USB, The dash one I was just showing for others who may have not known it existed.
'13 F30 328i Sport 6MT | '18 G01 X3 xDrive30i | '95 E36 325i Vert 5MT
92 Sentra SE-R SR20DET DET Build Thread 89 E30 325is [sold & missed] |
11-04-2019, 08:23 AM | #979 | |
Rep 67
My problem is just that sometimes camera turns on for a sec and goes off while driving. Normally a relay should do the trick but mine doesnt. Is there another solution maybe? |
11-04-2019, 09:35 AM | #980 | |
Rep 44
I used a voltage divider instead of a relay, cost me 2 resistors and some wire, pretty cheap, non mechanical and seems to keep on working without any issues. That is also explained in the original post by the way. |
11-04-2019, 10:20 AM | #981 |
Rep 67
try to remove the aux port in the armrest, just unplug the cable, no need for any permanent damage.
my unit is now stuck at the boot logo, anyone any idea how to recover (rk3399?) already tried: usbkey with px6_format.zip & px6_reset.zip, unplug car battery behavior: 1.system boots to bmw bootlogo 2. no signal after 60 seconds (retry?) 3. system again at bmw bootlogo 4. nothing happens (waited for atleast 15min) Last edited by marakeh; 11-04-2019 at 10:44 AM.. |
11-04-2019, 10:28 AM | #982 | |
Rep 1,407
Mentioned above I tried it for sh|ts n giglges made no diff, I didnt expect it to though cause I dont have a combox my 3.5mm connects direct to the headunit. Hope you fix your issue.
11-04-2019, 12:34 PM | #983 |
Rep 1,407
---- SOUND QUALITY QUESTION ( ive been doing car audio for quite some time ) ----
My configuration :
Playing the same tracks via Android & OEM HK Audio the Android sound doesn't have the depth / punch. It sounds decent and most people prob wouldn't even hear much of a difference but in the upper volumes it gets tinny for lack of a better word and seems to be missing some of the bass hit. Im sure it will get better with fine tuning and this has been a hell of an upgrade to my 6.5" screen. My questions are : 1 - Will removing this sound filter help like others have posted or is this only a PX6 thing? If so do you just cut it out and connect the wires to each other ie yellow to yellow etc.. [ discussed here - https://f30.bimmerpost.com/forums/sh...&postcount=507 ] 2 - Is there preferred "Android Volume like your AUX Volume on the OEM side" that should be set for optimal sound? 3 - Remove the wire from the AUX Plug *** DONT BELIEVE THIS Applies to me I dont have a combox, AUX goes right to head-unit ( tried anyway makes no diff ). All in all this has been an awesome upgrade, I think a few tweaks and it could be great and its opened countless possibilities and options.
11-04-2019, 12:54 PM | #984 | |
Rep 159
I did run few tests, and wasn't able to get that instant boot when that option was turned off. However it was still booting quite quickly (like 10-15 seconds instead of 30) |
11-04-2019, 12:57 PM | #985 | |
Rep 159
11-04-2019, 01:27 PM | #986 | |
Rep 1,407
** UPDATE - Changed OEM Volume to 2 ticks from full ( no numerical value ) and changed Android volume to 30 which seems to have made a huge improvement when its up loud. Just waiting now to hear back about that sound filter box, if thats still a spot for more improvement. On a side note, We should make a wiki for all this stuff if lots of people are getting these head units. Would anyone have interest in this? I could self host the wiki for all of us. That way we have a comprehensive list of must do options / settings per unit, host firmwares ( all versions in one spot labeled etc etc ). I can put this together pretty quickly if you guys are interested, I cant populate all info but I could def host and create it.
92 Sentra SE-R SR20DET DET Build Thread 89 E30 325is [sold & missed] Last edited by QUiKSR20; 11-04-2019 at 02:05 PM.. |
11-04-2019, 01:44 PM | #987 |
Rep 67
i think i bricked my unit with rooting.
last time i used adb shell /system/bin/su --daemon& instead of adb shell /system/bin/su --daemon"&" at least with the rk3399 i would strongly advice to use adb shell /system/bin/su --daemon"&" when following any rooting guide i i can not get it to reflash trough usb ill have to unmount and see if i can get it to work through the otg connection :/ |
11-04-2019, 01:58 PM | #988 |
Rep 237
this could lead to a failed root, not to a bricked device.
11-04-2019, 02:23 PM | #989 | ||
Rep 1,048
Code:
<!-- Dashboard unit 0:Metric 1:Imperial --> <DashBoardUnit>0</DashBoardUnit> The Appname needs to be added here Code:
<!-- List of supported DVR applications --> <SupportDvrAppList> <Item name = "com.ankai.cardvr" /> <Item name = "com.anwensoft.cardvr" /> <Item name = "com.sicadroid.ucam_car" /> <Item name = "com.building.dvr" /> </SupportDvrAppList> Code:
<!-- USB DVR application names Default: Ankai (Valid when the DVR module type is USB DVR) Old: com.anwensoft.cardvr New: com.ankai.cardvr --> <DVRApk_PackageName>com.ankai.cardvr</DVRApk_PackageName Maybe the app selection will see a choice button like music app selection soon Oh, and i checked the source code a little bit further and found out that the Bootanimation.zip can now also be importet like the splash.img, so without need of root. just put your bootanimation.zip into the /OEM/ folder of your thumbstick and wait until the message "Boot Animation has modified" does appear. Quote:
I found some other hidden Setting string called, "LKT", but don`t know yet that this shortcut is. I also found where the settings are stored but they are open at android, so not able to save them away yet. if someone could share an NBT and NBT-EVO MCU Update for Snapdragon, this would be Quote:
You can do pull requests, i barely have time to do my own wiki stuff, but activating them should go fast. Or ask jspuij to geht some more permissions Chri |
11-04-2019, 02:38 PM | #990 | |
Rep 1,407
Glad to contribute
