BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > B58 Log Review Thread
Studio RSR
      05-27-2021, 07:38 AM   #1871
dlj
dlj's Avatar
Drives: 2017 340i xDrive
Originally Posted by T_H_O_M_A_S View Post
its normal to dip when shifting . rpm drops so less rotations of your hpfp aswell , then the closed loop wil compensate
Yeah the dips at the shifts I wasn't concerned about, it was the beginning of the pull. For about 2 seconds it was about 350 psi under target. I guess that's not that big of a deal though.
Thanks for all the help guys.
      05-29-2021, 02:26 PM   #1872
CoachMCs
Drives: 340i
I have a couple of logs I’d like someone to take a look at. This E30 from the pump not mixed by me. Trying to see how well it does with Stage 1 E30 flash.
https://datazap.me/u/mcurry/log-1622...og=0&data=5-23
https://datazap.me/u/mcurry/log-1622...og=1&data=5-23
      05-29-2021, 09:47 PM   #1873
WrxToBeamerGuy
WrxToBeamerGuy's Avatar
498
Drives: BMW 340i xDrive
Hey everyone my IATs seem really high after replacing my heat exchanger with a CSF heat exchanger here are my logs. Is there anything that stands out to anyone?
https://datazap.me/u/wrxtobimmerguy/...54?log=0&data=
      05-30-2021, 07:25 AM   #1874
kern417
Cheapskate
4455
Drives: 2018 440i |2016 340i | 2010 X5
I always forget the exact temp differential but the DME targets I believe 20F over ambient. so if it's ~97 outside, you'll typically see IATs as high as 117 while cruising. It's really not uncommon or something to be concerned about. Especially if you're parked or moving slowly in traffic. IATs drop quickly once you get up to speed, and the car doesn't begin pulling power until IATs are 140+ during a pull.
Youtube/Instagram/TikTok: @kern417
      05-30-2021, 10:14 AM   #1875
WrxToBeamerGuy
498
Thanks kern but it was 70 outside while I was recording this log.
      05-30-2021, 10:15 AM   #1876
JP.BSB
Brazil
Drives: BMW X3 M40i 2018
  [0.00]
2018 BMW X3 M40i  [0.00]
Hi guys,
I would like you guys to help me review my Logs:
X3 M40i 2018 (only mod is the catted downpipe) - BM3 OTS Stage 2 93 octane
I've been using 95 AKI fuel (102 RON), but I've been getting a lot of timing corrections and some knocks.
Here are my logs (4th gear - DSC Off):
https://www.bootmod3.net/log?id=60b3...90c60b18fe6e3b
https://www.bootmod3.net/log?id=60b3...90c60b18fe6e3e
https://www.bootmod3.net/log?id=60b3...729b37e9a8108a
      05-30-2021, 12:38 PM   #1877
kriszty
kriszty's Avatar
329
Drives: B58 M240ix pureturbo800 dorch1
Originally Posted by JP.BSB View Post
Hi guys,
not really bad, some minor corrections, but overall timing is ok
Bmw M240i Xdrive , Dorch Stage 1 , pure turbo 800 , Midpipe , Remus exhaust. Bootmod3 , 100+ E5
JP.BSB9.00
      05-31-2021, 07:41 AM   #1878
FastSleeper
Drives: 2013 BMW 335i
  [0.00]
2020 BMW X3MC  [0.00]
Hoping to get some feedback on my recent logs. Currently running bm3 stage 2+ 93. Not sure if this tune is a tad bit too aggressive. Mods include AA HFDP and TU Pump. Timing advance is decent and hpfp is holding strong but seems be pulling timing quite a bit in the early rpm range. This also includes 1.5 gallons of e85 to a full tank of shell v power 93. Thanks.
https://www.bootmod3.net/log?id=60b4...90c60fd5b8d89d
https://www.bootmod3.net/log?id=60b4...0b436b0461a4bd
https://www.bootmod3.net/log?id=60b4...0b436b0461a4bc
      05-31-2021, 07:44 AM   #1879
mike buu
Drives: 2008 BMW 335xi Manual Coupe
I have an M240xi with downpipe dorch stg2 hpfp xhp. Here is my log on 93. I see timing is being pulled through 5th gear in cylinder 1 and 2?
My 60-130 time is 12.4x consistently.
https://datazap.me/u/mikebuu/car-so-...og=0&data=3-19
      05-31-2021, 08:27 AM   #1880
kriszty
kriszty's Avatar
329
first cylinder is a bit off
      05-31-2021, 08:32 AM   #1881
kriszty
kriszty's Avatar
329
your log looks ok for me
      05-31-2021, 08:36 AM   #1882
FastSleeper
  [0.00]
Any idea what i could do to fix that cylinder? Do you think more e85 would help? I have normal stage 2 93 logs and timing is near perfect. Its only impacted on the 2+ map.
      05-31-2021, 08:39 AM   #1883
kriszty
kriszty's Avatar
329
i know stage 2 + needs more octane, try some more E85 or 2-3 liters ethanol 100% and log again
      06-01-2021, 08:25 AM   #1884
CoachMCs
Drives: 340i
Can anyone take a look at these... I've been messing with E30 and 93oct to see how the car responds.
      06-01-2021, 11:26 AM   #1885
designatedposter
Drives: m235i
it does well by the looks of it. do you log the target hpfp pressure? i can see the actual pressure, but you should turn that on if available to compare the target vs actual to ensure you are not outpacing your hpfp.
M235i rwd 6mt
      06-01-2021, 03:31 PM   #1886
CoachMCs
Drives: 340i
I will check it out... thank you for looking at this. This was on E30 pump gas not mixed by me.
I was worried it wouldnt work... I want to try it with E85 mixed with 93 Oct to see if there is a difference.
The problem with the pump gas is that I do not know what the E was mixed with: 87, 91, or 93
      06-03-2021, 01:15 AM   #1887
eluded
2JZ-GTE
eluded's Avatar
Bulgaria
3064
Drives: 340 6MT, 50e, others
In theory it would only be 15% of the volume of the E 85. So a wash.
      06-03-2021, 08:29 AM   #1888
CoachMCs
Drives: 340i
Im talking about the E30 mix from the station. I do not know what octane that was mixed with to get the E30 mix, 87, 91, 93?
eluded3064.00
      06-03-2021, 04:29 PM   #1889
Ciaran2903
Drives: BMW 440i xdrive Coupe
Just got MHD and went with an E30 mix. Stage 1 for now (DP on order for Stage 2). Looking with help on the timing corrections:
https://datazap.me/u/ciaran2903/e30-...33-34-35-36-37
https://datazap.me/u/ciaran2903/e30-...17-32-33-34-35
Let me know your thoughts. Is the timing most likely an octane issue? Might need more E?
      06-04-2021, 12:48 AM   #1890
kriszty
kriszty's Avatar
329
Log looks ok, some corrections at cylinder 6 at high rpm, you could try some more octane , but overall it,s not bad
      06-04-2021, 08:02 PM   #1891
sultan340
Drives: 2018 340i RWD MPPSK
so back with some runs on stage 2+ OTS map this time, with Dorch stage 1 HPFP installed (fuel rail issue seems fixed now).
3rd gear pull:
https://www.bootmod3.net/log?id=60ba...729b321cd73764
4th gear pull:
https://www.bootmod3.net/log?id=60ba...90c607d8fdf7c8
5th gear pull:
https://www.bootmod3.net/log?id=60ba...90c60748a0afb1
3rd -> 4th -> 5th pull:
https://www.bootmod3.net/log?id=60ba...729b321cd7376b
i had cleaner logs in stage 2, (much less corrections). Any ideas what can cause above?
Already did new plugs, coils etc.
      06-05-2021, 02:37 AM   #1892
kriszty
kriszty's Avatar
329
3rd gear pull:
4th gear pull:
5th gear pull:
Still on the same fuel ?
