06-18-2019, 01:58 PM | #67 |
Rep 2,653
If you're just looking to remove limiters, increase clutch force and increase shift speeds then this is where it's at. Spending $350 if that's all you're looking to do is a waste IMHO.
06-18-2019, 02:07 PM | #68 | |
Rep 1,105
But I am interested to see how it compares to XPH since there are more calibrations and features through XPH.
06-18-2019, 02:23 PM | #69 | ||
Rep 2,653
06-18-2019, 03:07 PM | #70 |
Rep 1,105
Thanks for sharing and clarifying the description!
06-18-2019, 03:14 PM | #71 |
Rep 2,653
Anytime bud.
06-18-2019, 06:23 PM | #73 |
Car Hypochondriac
335
Rep 901
06-18-2019, 06:53 PM | #74 | |
Rep 63
On another note, I am curious how this compares to xHP. I currently have xHP and don't have any plans to swap and try the BM3 beta unless I hear it is much better.
2015 435i (current): VRSF Catless Downpipe, Bootmod3 Stage 1, xHP
2008 Corvette (sold):Vortech supercharger, ported/built heads, catless 2015 M235i (sold): CTS Turbo Intake, VRSF Catless Downpipe, CSF FMIC, MPE, xHP, Bootmod3 Stage 2 E30 |
06-18-2019, 07:03 PM | #75 |
Rep 965
Drives: 2016 F36 435x MSport
If you already have xhp, why not try the bm3 and compare what you experienced ?
06-18-2019, 07:08 PM | #76 |
Rep 1,286
I just flashed it and to be honest, after a 20 min drive, I can't really notice a difference. Drove in Manual-Sport and Manual-Sport+ and got on the throttle hard a few times.
I wasn't able to do a 3rd gear pull due to traffic, but other than that, I just couldn't perceive a difference in shifting speed or smoothness or anything else for that matter. I would be really interested hearing more opinions from people who flashed it and can compare to an XHP flashed 335/435. |
06-18-2019, 07:37 PM | #77 | |
Rep 2,653
06-18-2019, 07:49 PM | #78 | |
Rep 141
06-18-2019, 07:58 PM | #79 |
Rep 785
06-18-2019, 08:09 PM | #80 |
Rep 1,286
06-18-2019, 08:15 PM | #81 | |
Rep 2,653
06-18-2019, 09:44 PM | #82 |
Rep 1,286
I tried to re-flash the TCU and got an error at 1% that "flash failed". I cycled the ignition on/off 3 times, re attempted the flash and this time got stuck at 3% and got the same error message.
3rd attempt was finally successful! I have no idea what happened and why it failed the first 2 times Also, does everyone's flash finish with the message that the flash occurred in "Offline mode"? Not sure that's normal but i don't remember my DME flash for Stage 1 saying that. |
06-18-2019, 10:06 PM | #83 |
Rep 221
Did you update your agent today? I had no issues with the flash, but I updated my agent prior.
2011 F25 X3 35i |M-Sport Front Bumper Conversion|Largus Full Adjustable Coilovers|FTP Charge Pipes|Gutted Catalytic Downpipe|RB Oil Cooler Thermostat Delete|25 Row Oil Cooler|Custom Built Cold Air Intake|9"AEM Cone Filter Behind Kidney Grills With Outerwear|Precision Raceworks Coils|BM3 Stage 2 E30 Tune| BM3 Upgraded 8-speed TCU Flash|395mm X5M Front Brakes
06-18-2019, 10:10 PM | #84 | |
Car Hypochondriac
335
Rep 901
As for why the 335/435 seem to be the only ones with this limitation, maybe due to weight? |
06-18-2019, 10:30 PM | #85 |
Rep 1,286
Isn't this a torque converter transmission? I thought it doesn't have a clutch. I've been out of the loop for a few years when it comes to cars, so maybe I'm wrong.
06-19-2019, 02:52 AM | #86 |
Rep 54
I flashed today and managed to get in 25 minutes of city driving with a few launches from the lights.
The flash itself went smoothly and took around 2 minutes to download and another 2 to flash it on. Initial driving in comfort seemed very much the same, maybe slightly higher shift points. But it was very smooth. In Sport + I managed to get some hard launches and found it shifted very sharply and smooth, but again, hard to easily say it was better than stock. The most noticeable difference was in 3rd gear (as expected), I no longer had the dip in power as I wound the gear out past 60mph. Will be doing logs for my tuner this weekend and will share If I find anything interesting. Based on the post on the BM3 Facebook page, I only expected it to be a torque restriction removal tool. Personally my trans behaves much better once at operating temp, and could seem like a tune vs cold.
2017 540i x-Drive, M-Sport, Carbon Black and all the options..
06-19-2019, 09:52 AM | #87 |
Car Hypochondriac
335
Rep 901
You should look into how autos work, they're almost black magic. They have clutches (sometimes called brakes) that stop the planetary gearsets to switch gears.
Handling mods: Koni yellow - Eibach prokit - Millway street - M Performance LSD - M3 brakes - EBC bluestuff Exterior: Euro LCI tail lights - Shitty ECS CF spoiler - Chinese M performance diffuser Interior: Bavsound stage 1 and subs - custom trunk sub by Mike1327 |
06-20-2019, 10:58 AM | #88 |
Rep 1,282
I flashed mine last night and took it out for a spin. A lot smoother upshifting and downshifting in manual mode. And third gear pulls hard.
SOLD! X5 35i sdrive- JB4 SOLD! 435i- Cary Jordan E30 Tune~ Dinan Turbo~ BM3 trans tune~ XDI-35~ 3.5 T-map sensor~ VRSF HD FMIC~ VRSF Chargepipe~ VRSF Catless Downpipe~ CTS Intake~ FTP boost pipe~ FTP intake inlet~ FTP oil catch can~ Turbosmart dual bov~ |
