12-11-2019, 03:05 PM | #155 |
Old Member
125
Rep 81
12-12-2019, 10:01 AM | #156 |
Rep 10
02-08-2020, 08:15 AM | #157 |
Rep 85
Has anyone ever experienced what feels like a double bump in a high gear around peak torque when you tip into the throttle? It feels like something is slipping . I have recently flashed both transmission flash and stage 1 93 ron OTS, everything else is stock
07-13-2020, 01:00 PM | #160 |
Rep 622
Resetting adaptations on bootmod3, clearing codes in diagnostics, and doing the bmw transmission reset procedures should help with any issues people may have
Ishan Achar
Former: 2004 BMW E46 325i Current: 2017 BMW F30 320i Follow @Black_Lux_Cars on IG |
08-04-2020, 09:36 AM | #162 |
Rep 37
Well, other than being a year old, it's been fine for me. I did not have the paddle shifter issues as other people stated above. It clamps harder when shifting, but I don't think it's anything which hurts the transmission, in fact I think it's better than the soft stock TCU load. It pushed me into the 3.9 second range from low 4's on Stg 1, CP/FMIC (no downpipe). I have 47K on my 2015 335i xDrive and other than having some weird "only BMW knows why" A/C unit flash update done, I haven't had any issues knock-wood.
I should mention that I flashed the TCU back to OEM one time for it's final BMW service. I did get some trans error which I couldn't "clear" with neither BM3 nor my two other obd2 scanners. To resolve this, I reloaded the TCU flash and drove about 100ft around my cul-de-sac and back into my driveway. Hooked up BM3 and removed again, then clicked clear all codes, and it was gone. None of the scanners found it again. Who knows, maybe something didn't remove itself correctly the first time I clicked return to OEM. Installed fine after the service was completed and it's been loaded on there since.
2018 G01 X3 M40i - BM3 STG1 (93)
2017 F26 X4 M40i - VRSF CP, BM3 STG1 (93) Last edited by Minez; 08-04-2020 at 09:45 AM.. |
08-10-2020, 08:12 PM | #163 |
Rep 1,236
I just flashed the bm3 trans upgrade on my 13 328i. It didn't work at first as I'm coded to 2tb. So I used bimmercode to revert to non sport auto. Successfully flashed the trans with bm3, drove it for a while, noticed a difference from the stock tranny, and then coded back to 2tb SAT.
Now to me it feels better than ever. The sport mode of the transmission shifts quick and I'm chirping the tires a bit more. Is it placebo? By coding to 2tb after the bm3 trans flash, did i cancel out the BM3? Hoping if I bring this back around someone might know something |
05-13-2021, 07:49 AM | #164 |
Rep 170
Does anyone know if they resolved the issue on N20 with using the N55 shift points? Don't want to flash this and end up endlessly lugging. There is no version info on the flash page and its also unclear if its still the one generic mapping.
05-13-2021, 08:27 AM | #165 | |
1296
Rep 3,533
I doubt they did anything with it. you may wanna look at xhp as a better option anyway.
05-13-2021, 09:00 AM | #166 | |
Rep 170
Thanks. |
05-13-2021, 09:35 AM | #167 | |
Rep 90
I was wrong..... Last edited by GAB0; 05-13-2021 at 12:46 PM.. |
05-13-2021, 12:22 PM | #168 | ||
1296
Rep 3,533
01-05-2023, 04:06 AM | #170 | |
Rep 89
Does one override the other? Or can/should you 'stack' these transmission flashes in a certain order? |
01-05-2023, 05:10 AM | #171 | |
Rep 1,236
I think you have to choose between them. Bm3 will only recognize your original transmission software. So 2tb in bimmercode, has a greater effect than the bm3 transmission tune. Imo. If I remember correctly
2023 M2. ZB. Manual.
2024 m235i |
01-05-2023, 05:49 AM | #172 | |
Rep 5,392
So I would suggest that you first turn on the BMW Sport Automatic transmission. Then flash the free Bootmod3 automatic transmission tune. Hope this helps! |
GrabEmByTheBimmer16.00 |
