BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > DIY Rain/Light/Solar/Condensation Sensor for F20/F30
      05-16-2015, 07:38 PM   #23
mokorx
Thailand
51
Drives: G30 530e M Sport, F30 316i
The light, rain, and solar is one unit.
Here is the cuurent one on ebay
http://www.ebay.de/itm/NEU-ORIGINAL-...item1c5250e4f9
      07-27-2015, 11:06 AM   #24
risanta
Drives: 320d F30
Hi,
Was just about to order new sensor from ebay but checked my car sensor first.
It was old model RLSBS so should it support following retro-fit just with coding?
Do I need anything else than switch mod and coding?
Br, Riku
      07-29-2015, 08:51 AM   #25
mokorx
Thailand
51
If it actually is a RLS, you need only switch mod. And coding.
      07-31-2015, 03:56 AM   #26
risanta
Drives: 320d F30
Hi,
Can't find FEMBODY FLC_AKTIV?, everything else is coded.
My car is with Halogen not Xenon.
      07-31-2015, 09:48 AM   #27
mokorx
Thailand
51
Originally Posted by risanta View Post
Hi,
You can code it another way by adding 521 to FA and VO code FEM. (no need to do FDL coding "one by one")
      10-13-2015, 02:47 PM   #28
mightycrown
Drives: f31 320d black sport
I retrofitted the sensor and did a mod on the light switch. Everything works well, except I got a error code from INPA
0x030351 Schaltzentrum Lenksaeule (SZL) (LIN): falsche Variante (Steering wheel cluster
0xD90D16 Bedieneinheit Licht (BEL), (LIN): falsche Variante verbaut light switch)
Any one know how to fix this?
      11-20-2015, 01:06 AM   #29
xxxyyyzzz
BMW Specialist
Croatia
Drives: E91 335d
2009 335d  [0.00]
does anyone know if 61359354843 will fit on f20... real oem says:
61359293279
Rain/light/solar and condensation sensor
Superseded by:
61359311711 (03/01/2014 — 03/22/2013), nonexchangeable retrospectively
61359321006 (08/01/2013 — 08/07/2013), Exchangeable retrospectively
61359332179 (08/01/2013 — 07/24/2015), Exchangeable retrospectively
61359347395 (03/01/2014 — 06/06/2014), Exchangeable retrospectively
61359354225 (04/01/2014 — 01/08/2015), Exchangeable retrospectively
61359354843 (11/01/2014 — 07/15/2015), Exchangeable retrospectively
61359387621 (03/01/2015 — ), Exchangeable retrospectively
Supersedes:
61359270588 (11/01/2011 — 06/13/2013), Exchangeable retrospectively
61359266413 (11/01/2011 — 12/01/2011), Exchangeable retrospectively
61359249520 (07/01/2011 — 11/25/2011), Exchangeable retrospectively
61359243568 (07/01/2011 — 09/17/2010)
Part 61359293279 was found on the following vehicles:
1' F20   (07/2010 — 02/2015)
1' F21   (07/2010 — 02/2015)
3' F30   (02/2011 — 07/2015)
3' F80 M3   (04/2012 — 06/2015)
3' F31   (07/2011 — 07/2015)
3' F34 GT   (07/2012 — 10/2015)
3' F35   (06/2011 — 08/2015)
4' F32   (11/2012 — 09/2015)
4' F82 M4   (02/2013 — 09/2015)
4' F33   (03/2013 — 09/2015)
4' F83 M4   (06/2013 — 09/2015)
4' F36   (07/2013 — 09/2015)
and when i clik on this number i look for:
61359354843
Superseded by:
Supersedes:
61359293279 (03/01/2013 — ), Exchangeable retrospectively
Part 61359354843 was found on the following vehicles:
2' F45 Active Tourer   (11/2013 — 09/2015)
2' F46 Gran Tourer   (07/2014 — 09/2015)
3' F30 LCI   (09/2014 — 10/2015)
3' F80 M3 LCI   (01/2015 — 09/2015)
3' F31 LCI   (09/2014 — 09/2015)
3' F35 LCI   (01/2015 — 09/2015)
i8 I12   (02/2013 — 09/2015)
X1 F48   (11/2014 — 09/2015)
X5 F15   (08/2012 — 10/2015)
X5 M F85   (04/2013 — 09/2015)
X6 F16   (09/2013 — 10/2015)
X6 M F86   (10/2013 — 09/2015)
it doesnt show f20 here but of first search i shows Exchangeable retrospectively. what does this mean and will it work or wont work at all.
      07-04-2016, 11:41 AM   #30
edika
Switzerland
Drives: F31 320dX
Hello, someone can help me with coding this mod. I'm a newbie and only programmed FA.
Which step I have to follow with e-sys to code this mod?
Edika
      02-25-2018, 11:11 AM   #31
Moto-XXX
Sweden
Drives: 2013 335iA Touring M-sport
Are all sensors compatible?
I found a sensor from a scrapped car that according to bmwvin.com had automatic air conditioning and rain sensor.
Will that work in my car or are there also other parameters to consider?
My car does not have HUD, lane departure warning, lane-change warning or driving assistant.
      04-12-2018, 10:53 AM   #32
bill_f31
Drives: BMW F31 M Sport
On my F31 I have from factory the solar/condensation sensor (part number 61359347398) with auto climate and 6WA insta.cluster.
Do you know if I can activate just by coding the auto light function only, as I don't care about the rain function,or I have to change the existing sensor for the light-rain-solar-condensation sensor?
Thanks in advance
      10-19-2018, 07:37 PM   #33
Mikej0h
Netherlands
49
Drives: BMW 540i G30 2018
Hi,
I've followed this excellent retrofit guide to the letter.
However I've used a slightly different RLS with partnumber 61356814596 (as RealOEM suggests it's the superseded part of 61359293279 - mentioned in this guide).
Today, as part of some other maintenance I've noticed some strange diagnostic messages in ISTA+ regarding the RLS-sensor.
I've seen the following messages:
- TBX: No current coding data stored
- TBX: Control unit is not encoded for the vehicle
- CON: No current coding data stored
- CON: Control unit is not encoded for the vehicle
- Compressor clutch: Break in wiring or short circuit to B+ (related to the "AIC_KOMPRESSOR_MAG_KUPPLUNG" to "aktiv"?)
But the most important one (that maybe triggers all of above):
- Rain-light-solar-condensation sensor: Wrong variant installed
- Rain-light-solar-condensation sensor: Missing LIN slave
Please do note all the functionality of the light and rain sensor seem to work as expected.
What could cause this error? Do I need to VO-code something, or change the type of sensor in coding (as it's newer)?
Or did I install an incompatible version of the RLS-sensor (as ISTA+ suggests)?
I've attached the screenshot with an overview to the errors, and a print-out of each error - I do believe however that all are related to just one 'real' error.
Hopefully somebody can point me in the right direction!
With regards,
Mike
      11-20-2018, 03:12 PM   #34
Mikej0h
Netherlands
49
Anybody a clue about what might go wrong here?
Should I just vo code instead of FDL coding?
      11-21-2018, 07:31 AM   #35
itomek
Unhappy
Hello
I've put 6814596 sensor to my car - previously I had 9270590. I choosed 6814596 because in realOEM there is information that 6814596 can be used as exchange of 61359293279
When I try to code it using Esys, I can't change FEM_BODY > 3060 > FLC_AKTIV from "nicht activ" - there is simply no "activ" option available from drop-down menu.
All other options mentioned in this DIY guide are available to change as decribed in pdf:
RLS_DEF_FLC_SCHWELLWERT_SATZ
WW_REGENSENSOR
RLS_LIN_VAR
REGENSENSOR_INTERVALL
My car has 9270590 sensor previously (SBS4/DE).
Do I need to make any extra coding for this retrofit?
      02-17-2019, 04:37 PM   #36
Sorinn2019
Drives: Bmw f30
Hy.
Did you fix this Problem? If yes can you Tell me how?
      06-10-2020, 08:23 AM   #37
tlorenz2014
Drives: F34
Reviving an old thread, while unfortunatelly I have no information for people experiencing problems, I want to state that everything went perfectly for me after picking part number from realoem and installing/coding everything works great (have not tested auto AC yet, but auto lights and auto rain works)
      06-10-2020, 08:26 AM   #38
Mikej0h
Netherlands
49
I can second this.
Although I've the ISTA messages as can be seen in the screenshots a few posts back, the sensor does seem to work as expected.
      06-10-2020, 10:27 AM   #39
tlorenz2014
Drives: F34
Originally Posted by Mikej0h View Post
I can second this.
I haven't checked on ISTA only programed using e-sys, as I'm still trying to get ISTA.
Just a thought, but maybe it would be possible to VO-code this feature? As I think maybe the errors mean that FDL and sensor mismatch the FA options?
      06-10-2020, 10:33 AM   #40
Mikej0h
Netherlands
49
Re-reading my old message, I come to the conclusion I have probably FA coded the change.
(My unedited post was stating I might have done the VO-coding)
I might give it a shot. It would make sense it would resolve the coding messages that ISTA shows.
All functionally seems to work (or at least doesn't let me notice it doesn't work ;-)), will see when I have some time to look into this...
To which VO would introduce this functionality, 521?
Last edited by Mikej0h; 06-10-2020 at 10:45 AM.. Reason: re-reading older post, and adjust statement
      06-10-2020, 12:41 PM   #41
tlorenz2014
Drives: F34
I've tried VO coding 521 and it seems successful, will test if the features work, however, I have observed some differences in the FDL provided after VO coding:
AIC_KOMPRESSOR_MAG_KUPLUNG
Should be according to guide: aktiv
Is after 521 VO CODE: nicht_aktiv
RLS_LIN_VAR:
Should be according to guide: RLSBS
Is after 521 VO CODE: RLSBSoH
I have left the values after VO code, I don't know if I should change them to be according to the guide or defaults after VO code, if anybody has any insight to what these mean, it'd be great!
Also, I am still downloading ISTA, so it will take me a bit to see if the errors are present after VO code
EDIT: I VO coded KOMBI and FEM_BODY as they were affected according to this post:
https://f30.bimmerpost.com/forums/sh...11&postcount=5
EDIT2: Unfortunatelly, I also get the errors in ISTA
      07-02-2020, 04:04 PM   #42
mki
Drives: F31
Hello
I have tryed to retrofit autolightswich on my F31 2013 (new light swich A function)
My car has automatic A/C...... do I have the right light/rain sencor?
I can not find: FEM_01 > LceMaster 3060 > LDS_MIT_STELLUNG_A = aktiv
Can I have a wrong FEM?
I have a Bimmercode
Best regards
Mogens
      08-05-2020, 03:20 PM   #43
IvvF21
Drives: BMW Serie1 120i F21
Exclamation :confused2
Originally Posted by mki View Post
Hello
I have a Bimmercode
Best regards
Mogens
I am in the same situation, I have a 2016 bmw f21 with sensor 9 388 215 - 0, will this sensor help me to do it? or do i need to buy another one? I also need help with coding. I have a bimmercode please.
      08-22-2020, 04:19 AM   #44
mki
Drives: F31
You have to chance the sencor to 9270588 then it works
The sencor for A/C is only sun/fog sencor
You need a sun/fog/light/rain sencor :-)
change the multifunction contact to 9531153 then the raincencor works too
Best regards
Mogens
