BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > HDD failure, iDrive stuck on "starting navigation system"
      08-18-2018, 04:37 PM   #1
ea55
Drives: 428i
Nothing works except radio. Out of warranty. New unit costs $2500 just for the part.
Is there a way to replace the hard drive itself without replacing the head unit? Please help! 2016 428i
      08-18-2018, 04:57 PM   #2
IK6SPEED
Drives: BMW M3 / AH3
What year 428i?
      08-18-2018, 04:58 PM   #3
ea55
Drives: 428i
Originally Posted by IK6SPEED View Post
What year car and model?
2016 bmw 428i
      08-18-2018, 04:59 PM   #4
IK6SPEED
2016 bmw 428i
Why is 2016 out of warranty?
High mileage?
      08-18-2018, 05:41 PM   #5
steve@codemybimmer
steve@codemybimmer's Avatar
Hong Kong
665
Drives: 2020 G20 320i M Sport
Your best bet is to probably just find a used one from a vehicle of the same model year and replace it. We do offer factory head unit replacements at a fraction of what the dealer charges and we can ship you the replacement pre-programmed and re-activated to your vehicle spec and VIN.
It would be bench programmed just like our retrofit kits.
PM me if you need help with that.
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming
steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca
Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs
IK6SPEED4488.00
      08-18-2018, 08:18 PM   #6
ea55
Drives: 428i
High mileage?
Yeah, just a little over 50k. No issues until now and car is in perfect condition
      08-18-2018, 08:20 PM   #7
ea55
Drives: 428i
I'm interested. Will PM.
Edit: is there a way to put a SSD in there? I dont want it to happen again. When it happened, I unplugged bimmertech amp and it started working until I plugged the amp back. Idrive restated immediately and issue came back. I'm afraid that the amp could be causing it. Had no issues for a little while
      08-18-2018, 08:24 PM   #8
IK6SPEED
Was going to be my suggestion if Car was truly out of warranty.
If it's truly just over 50k miles, you might try and see if they will make exception as electronics really should not fail on a 2016 vehicle regardless of mileage. It's not like other mechanical parts for wear and tear.
      08-18-2018, 08:50 PM   #9
ea55
Drives: 428i
I can try. I had a hard time getting stuff done under warranty. I'm 99% sure they will say no and I won't argue.
      08-18-2018, 08:52 PM   #10
IK6SPEED
I'd contact BMW NA
      08-18-2018, 09:02 PM   #11
ea55
Drives: 428i
I'd contact BMW NA
I will update with results.
I still dont understand why replacing a $50 hard drive costs over $3000. There must be a way to open the headunit and replace the harddrive itself only.
Rebound152.50
      08-18-2018, 10:33 PM   #12
steve@codemybimmer
Hong Kong
665
Responded to your PM.
The QNX system will not boot up if it detects that you swapped the HDD so the only way to fix this would be to replace the head unit.
      02-12-2019, 10:28 PM   #13
jimbobiggens
jimbobiggens's Avatar
Drives: 2013 335i xDrive
Are you talking about Blackberry QNX Car Platform? Could that not be hacked, er, coded to match the new SSD? I'm interested in this also because my idrive startup time is starting to vary quite a bit - I think the hard drive is starting to show it's age.
I'm not completely useless, I can be used as a bad example.
      02-13-2019, 06:39 AM   #14
sspade
sspade's Avatar
Drives: F30
2016 BMW 320i  [7.87]
2014 BMW 328i  [6.83]
My iDrive screen has randomly restarted while in use twice over the past month.
Im wondering if my head unit is dying as well?
      02-14-2019, 04:56 AM   #15
adrien78
France
52
Drives: BMW F30 335i
Just to know, if you clone the disk (before it fail of course), does that works?
Or it's S/N related.
      01-04-2022, 05:03 PM   #16
fossum
Drives: BMW 328i Touring
I would think the SN could be low-level modified as well. If it was SN related, you'd think it would have to be programmed at the factory and thus should be dealer programmable.
