01-02-2019, 03:48 PM | #1 |
Rep 20
Oil Temperature Gauge Not Working
I have a '12 335i Sportline 6MT. I was driving home from out of town and I noticed that my oil temp gauge on my dash wasn't working. The needle was all the way to the left. I had been driving for an hour, so my car was at operating temperature. I pulled over, looked under the hood, listened and everything seemed okay. No check engine light, codes etc. I made it home and drove it again yesterday, same thing. I have heat, car sounds fine, runs fine. I've tried to find some more info online, just can't pin it down. Could this be the oil temp sensor going bad? If so, is it an easy DIY? Where is this part located in car?
01-02-2019, 04:08 PM | #2 | |
Rep 15,858
Hidden menu, the one accessible using the code generated from the last few numbers of the VIN number. There are videos on how to access, if you are not familiar with the way in. |
01-02-2019, 05:45 PM | #3 |
Rep 1,905
You can also run instr cluster self-test with hidden menu- that will rule in/out possible cluster failure.
You can also set the cluster to readout coolant temp in Deg C....have to do it each time you startup the motor but sure as heck a lot safer than driving blind/no engine temp info. |
01-02-2019, 08:11 PM | #4 |
Rep 10,253
Do you have a code scanner such as Foxwell NT510? It's unusual for CEL not to turn on if a major component such as oil temperature sensor could be malfunctioning. There could be other codes stored.
01-02-2019, 09:43 PM | #5 |
Rep 20
Thanks everyone. I guess I'll look up the "hidden" menu & try that. I don't have a scanner, but I guess I could go to a auto parts store and have them scan it for a code. I'll try these suggestions and report back. I can work from home, but do you all think it's safe to drive locally until I can figure this out?
01-02-2019, 10:04 PM | #6 |
Rep 1,905
Don't drive the car again until you get the cluster unlocked so you can monitor either the Oil or Coolant fluid temperature (both are available via hidden menu....go to YouTube and search BMW F-Series hidden menu).
You don't want to overheat the motor, be smart on this and get that temp info displayed before you run the car even a few miles. Codes: auto parts store may be able to read but not certain they will be able to interpret - you may well need a mechanic (Dealer or Independent mechanic) to assist on this. Or buy scanner and learn how to use it. |
01-02-2019, 11:38 PM | #7 |
Rep 1,827
Regardless of whether it's the cluster or the sensor, I don't think driving moderately is an issue. I'm pretty sure there are cars out on the road that have neither an oil or coolant temp gauge. I see you're in Pittsburgh, so I'm guessing overheating won't be an issue. Check out the digital temp readout as others mentioned, and while you're at it, check your oil level if you can (I don't know if it'll even work given the current situation...another instance where a dipstick would be nice).
You should be fine driving to a shop or the dealer to get it checked out. Previous poster said "don't drive the car" but I don't think this is so severe an issue that would warrant suggesting you tow the car to get it checked.
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~ |
azuritschwarz347.50 |
01-03-2019, 09:28 AM | #8 |
Rep 1,905
You don't need to have the car towed; it's just not sensible to drive very much at all w/o being able to monitor engine temperature.
Good luck w/repairs / Bill |
01-03-2019, 01:21 PM | #9 |
Rep 20
I found the "hidden" menu and ran the system test. The oil temp gauge needle moved & operated on that test. Everything else seemed fine. After my car idled for 7 minutes in my driveway (heat off, 35 outside temp), I shut it off and looked at the coolant and oil temps in the hidden menu. Coolant temp read -128C or (-198.4F) & oil temp 47C or (116.6F). The coolant doesn't seem right at all and the oil temp seems low but might be right as I wasn't actually driving, just idling. I'm going to run a few errands and I'll be driving a total of 3-5 miles. I'll re-test when I get home and report back. Any thoughts? Thermostat stuck open? Coolant sensor? Thanks to all for the help so far.
01-03-2019, 02:35 PM | #10 | |
Rep 145
I'd be curious about what the actual oil temperature was after driving for a little and really warming the oil up. If it starts to read over 160F and isn't registering on the gauge, than your issue is narrowed down something beyond the actual sensor. Not familiar enough with BMW electronics to say whether it's a cluster or some component in between the temperature sensor and the cluster. |
01-03-2019, 03:12 PM | #11 | |
Rep 1,827
I'm still leaning towards there not being a mechanical problem, just a bad sensor, IMO. I would like to think that there are redundant safeguards in place should something go wrong. The car would likely go into limp mode to protect the engine if there was a serious issue. I can't imagine one faulty sensor being enough to cause catastrophic failure.
01-03-2019, 03:15 PM | #12 |
Rep 20
After doing some errands, I ran the tests again. Coolant temp same as before -128C or (-198.4F). Oil temp was 71C (160F). I was driving very conservatively, shifting @2500 or so. Maybe a wire running from a sensor? Any other ideas? I forgot to take it to Advanced Auto to run a scan. I know I should just buy a good scan tool. Any suggestion for that? Foxwell? I'll probably just bite the bullet and take it to the shop. I've been trying to do maintenance/DIY work on this vehicle as much as possible, but sometimes it's above my "skill" level.
01-03-2019, 03:46 PM | #13 |
Not stock
474
Rep 617
Are you saying it is reading "negative" 198F? Does it change from that at all? Obviously "negative" temperature is never a good thing...
2015 BSM 328i Sport Line - BSM
2015 BSM X1 M Sport - BSM 1992 525i 1987 325e |
01-03-2019, 03:55 PM | #14 |
Rep 1,905
Seems the cluster checked ok- likely it's the oil temp sender signal.
Scan tool is decent investment if you are able/willing to DIY some repairs. Very helpful. You might browse BimmerLink app. - it's pretty good. |
01-03-2019, 06:39 PM | #15 |
Rep 20
01-03-2019, 07:07 PM | #16 | |
Not stock
474
Rep 617
01-03-2019, 07:19 PM | #17 | |
Rep 1,905
Maybe you'd better run that instrument cluster self-test again and double check that it is fully functional. Looks like you have 2 issues: coolant digital reading and analog oil temp gauge, hmm...I'm thinking cluster issue- Sounds like time to get fault codes read; have mechanic look this over. Good luck/Bill |
01-03-2019, 09:00 PM | #18 |
Rep 20
It seems like it's stuck at -198. Both times I've run the test, it read -198 and didn't change. Did cluster test again and oil temp gauge "needle" moves during the test. Frustrating, but I'll be calling the mechanic tomorrow.
01-04-2019, 08:52 AM | #19 | |
Rep 145
Do you have heat after a few minutes of driving, or does the air blow cold longer than it seems like it reasonably should? My oil temp will usually settle right at 200, sometimes a bit higher if I'm driving spiritedly. If I'm idling, it tends to drop below 200. This is after 10-15 minutes of driving. |
01-04-2019, 10:00 AM | #20 |
Rep 109
As others have said, buy a scan tool. I use a cheap OBDII + Bluetooth tool and it is great. That will help determine if it's a bad gauge. If it's a bad sender, you will still see the same junk values from the OBDII port.
Two other thoughts: 1. It's cold out right now, and it's not uncommon to see lower oil temps if you're just cruising around. 2. If your thermostat is bad, it would be stuck open and your oil temps will only come up after significant driving. |
01-04-2019, 10:10 AM | #21 | |
Rep 15,858
Does appear that coolant is likely running cold. Faulty signal does seem likely, from the constant temperature reading. Cool ECT will prevent oil temperature from climbing as normal, particularly in colder ambient temperatures. |
01-04-2019, 02:22 PM | #22 | |
Rep 148
But I think that the N55 thermostat isn’t strictly electrically controlled. It does have an electrical connection, but I think the thermostat is primarily a mechanical device with electric input to tweak its operation. That makes a huge difference here. Probably no overheating risk. Probably. The B58, which replaces the thermostat with a “heat management module,” would be a different story. |
