05-05-2016, 01:58 AM | #1 |
Rep 70
Help Needed: M-Performance suspension or coil-overs?
I need to upgrade my 2013 F30 335i Sport line suspension with something stiffer and something that would improve the handling and road feel of the too comfortable car. I don't think I would be adjusting the coil-over dampening and rebound on regular basis if I get one with those adjustments. I am looking for something that I can install and forget as I don't have much experience and knowhow about car suspension systems and coil-overs. To give you an idea of what I am looking for, I want the ride and feel like E90 or even better E90 or F80 M3. Is it possible to achieve that kind of stiffness, handling and road feedback with suspension upgrade? I have the Continental ContiSportContact 5 SSR summer performance run-flats that came with my F30 and I plan on keeping them (vs replacing with Michelin Super Sports).
I have shortlisted the following: 1) M-performance suspension 2) Coil-overs: - KW (Not sure which version to get out of v1, v2 or v3) - Bilstein B14 I am looking to spend around $1500 including install. Is this reasonable? I searched and found that M-perf suspension itself costs $1500 without install. Any discounts or deals on that? Also, any recommended shops which do good installation and reasonable prices in San Francisco Bay Area? Thanks for taking time to read my post |
05-05-2016, 10:54 AM | #2 | |
Rep 4,327
if you go coils ohlins and ast are the top of the line but cost quite a bit. even KW will cost you more than M-Perf. if you don't mind that the drop is just 10mm i highly recommend it Last edited by alohasurftoad; 05-05-2016 at 11:04 AM.. |
05-05-2016, 12:20 PM | #3 | |
Rep 3,947
M Performance Suspension will cost you $1500. Any suspension install is going to involve a substantial number of labor hours. Fortunately, you already have the Sport suspension anti-roll bars. Otherwise, the labor cost could conceivably be more than that actual parts cost. Also, I'd highly recommend you replace your tires (when they wear out eventually) with a better tire such as a Michelin PSS. As far as set it and forget it, M Performance Suspension is the way to go. |
05-05-2016, 12:55 PM | #4 |
Rep 70
@alohasurftoad, thanks for your reply. I actually don't mind the 10mm drop; I just want a firm ride and handling that a BMW "sports sedan" *should* have from the factory.
@Polo08816, I understand your point and you are right. If I can at least bring my F30 335i to E90 335i levels in terms of stiffness and road feedback, I would be more than happy. Looks like I would need to shop around for M-Performance Suspension! |
05-05-2016, 07:25 PM | #5 |
Rep 1,733
Drives: 2003 M3
Any lowering option is going to cause you pain if you are keeping the run flats. They are brutal with lowering springs or coil overs. I couldn't wait to get mine off on both my E90 and this F30.
05-05-2016, 07:27 PM | #6 |
Rep 70
That is what I have heard but at least I can install the suspension/coilovers first and then I can install non-RFT after they wear out if I find them too brutal.
05-05-2016, 08:14 PM | #7 |
Rep 764
I never really noticed it at first, but now that I put my rfts back on (winter tires are go flats) I realize how stiff they are and how much they rattle the car. Sounds like my car is going to fall apart when I go over bumps or road joints.
05-06-2016, 01:22 PM | #9 | |
Rep 4,327
if you're sending it out then i suppose it doesn't matter, though. |
05-06-2016, 04:08 PM | #10 | |
Rep 284
Drives: F30 335i EBII MPPK/BBK
Garage List 1999 Honda CR-V [0.00]
2013 BMW 335i [0.00] 1986 BMW 325e [0.00] 2014 Porsche 991 Ca ... [0.00] 2018 Audi SQ5 [0.00] 1971 Volkswagen Sup ... [0.00] |
To cut down your choices based on price point, you cannot get into V3s on an F30 in your price range. You are also a few $ hundred out on the PSS10's, V1 and V2's. I think, based on your install and forget plan, you should opt for the M Performance suspension; $1500, or as I found $1600 out the door from Tischer BMW in Maryland.
Current Garage
2018 Audi SQ5 2014 991 Porsche Carrera 4S 1986 BMW 325e 1971 VW Super Beetle |
05-08-2016, 03:13 PM | #11 | |
Rep 70
Also, just curious, what is your opinion on Bilstein B8 struts and Eibach/H&R springs combo? Seems to be less expensive than the M-Performance suspension considering that eventually, M-Perf is also a struts-spring combo in itself except that it is BMW tuned. |
05-08-2016, 07:28 PM | #12 | |
Rep 3,947
That Bilstein combo is less expensive than that M Performance Suspension but no one here will say it's a better matched pair than the MPS. There are plenty of Bilstein/H&R fails on the forums from basically mismatched springs/struts. |
05-08-2016, 11:06 PM | #13 |
Rep 10,256
It will be very difficult to stay within $1,500 budget, including installation. Since your goals are reasonable, take a look at KW Street Comfort coilovers.
www.allshocks.com has very attractive prices. KW Street Comfort and V1 are approx. $1,500 at allshocks.com. V2 are more expensive, nearing $1,800. Last edited by cfm56d7b; 05-08-2016 at 11:11 PM.. |
06-07-2016, 07:57 PM | #14 | ||
Rep 167
Is this 19" wheels ur having? As i saw a couple of other F3x with MPerf suspension but with more height than yours even on 20"!! I even thought to get the MPerf dampers with H&R sport springs plus the strut bar as my car is 2013 335 luxury model.....i.e non m-sport |
06-09-2016, 10:19 AM | #15 |
Rep 66
Drives: 335i X drive
That's a pretty small budget, forget coilovers. You could maybe do springs ad install. Most shops charging $700+ for install on the low end. Don't forget you'll need a 4 wheel alignment after the suspension installed.
11-12-2018, 04:34 PM | #16 |
Rep 70
Okay, so it is 2018 and I still haven't upgraded the stock suspension on my car. Reviving this old thread of mine. My car is at 68,000 miles already and the stock shocks will soon need a replacement, I guess. So, since my car was at a body shop (for a different reason), I thought I would take the plunge and do the suspension swap.
I have reasonable expectations now in terms of pricing. I am looking at $1500-$1800 for parts and $800-1000 for the install. My expectations are still the same: - I am looking to get a stiff ride but not overbearingly jarring experience on bad roads/potholes, etc. - Minimum drop in ride height ~20-30mm and not more I had earlier shortlisted: 1) BMW M Performance 2) KW V2s. I want to add Bilstein in the mix too 3) Bilstein B14 or B16 B16 seems to be expensive than V2s. I am assuming B14 is equivalent to KW V1 in terms of being able to adjust the height and dampening while B16 is more equivalent to V2; in fact, B16 have both rebound and compression dampening adjustments vs V2 has rebound. What I am stuck with the dilemma is that which one would provide a satisfactory ride out of 3. By satisfactory, I mean, stiff, less body roll, getting more road feedback but at the same time not being tired or hurting my back due to bad roads. Does that make any sense? I am on stock 18" RFTs and plan on keeping the same. Also, as already mentioned, non M-sport (sportline) 335i RWD from 2013. Also, for the price of M Performance kit (which is close to the price of KW V2), I am getting shocks, spring and also the front and rear sway bars. I am guessing BMW recommends anti-roll bars for non M-Sport package cars while the coil-over manufacturers don't. Can anyone explain why? Any help on this repeatedly asked question is appreciated. I read countless threads but still could not find a definitive answer on these 3 sets comparison, because, most likely not one person has experienced all 3 on the same F30 platform, I am guessing. |
11-12-2018, 09:42 PM | #17 |
Rep 1,934
All three will be compliant and stiffer than stock. B14 has no dampening or rebound adjustment, just height, like the V1. B16 Pss10 has both, but in one knob adjusting both simultaneously, unlike v2. They are also adjustable without removing the tires or shocks, unlike KW v2/3.
Go for the KW streetcomfort for your application. They go for ~$1600usd while the Bilstein variant is about $2200. However, that +$600 gives you the benefits listed above for the PSS10. Your "minimum drop" actually sounds like your maximum drop, and will be on the lower end of the Streetcomfort (kw or bilstein) adjustment range. All the others, on their highest setting, will be 30mm lower than xdrive base suspension.
11-13-2018, 11:47 AM | #18 |
Rep 192
In my opinion, Mperf vs coilovers is the wrong comparison to be making.
Given that the Mperf is non-adjustable, I'd just go for Bilstein B8 + Eibach pro-kit springs. There is little doubt in my mind it will be vastly superior performance-wise and the set can be gotten for well under 900$. I found a great deal on mine and managed to get the whole set including shipping for under 700€. The Mperf only drops 10mm, as do the Eibach pro-kits. Want more drop? Go with Eibach Sportlines (30mm) or H&R springs, which are almost 40mm, and stiffer. There's no point in paying BMW tax on certain parts where the aftermarket options are just better, and cheaper. It's like going to the dealer and buying official, stock runflats for a 40% markup and worse performance over a good set of sports tires anywhere else... |
Skipdeez9.00 |
