05-05-2017, 04:04 PM | #45 | |
Rep 1,015
If it were, virtually every incandescent bulbs would be brighter than ANY LED. |
05-05-2017, 05:47 PM | #47 | ||
Rep 1,772
If you read the thread you will see I said nowadays leds have approx 100 lumens per watt efficiency or more. |
05-05-2017, 10:43 PM | #48 | |
Rep 1,015
But you are leaping to a conclusion based on wattage. According to measurements, the headlights are nowhere near that bright. |
05-05-2017, 11:41 PM | #49 | ||
Rep 1,772
It would make sense that given both are led the higher wattage led would provide more light (im not using wattage to compare led to hid here as efficiency is different). So either there are more leds to make total of 36w for the low beam in the adaptive or they could be more powerful leds to make 36w. I'm guessing more leds to perform their adaptive function. Unless bmw are using leds with different efficiency it would make sense that the more powerful adaptive would be brighter than the non adaptive. And I agree the measured output is not that bright as you say but again if you read what I wrote I referred to the source light. The "road lumens" being a different story. |
05-06-2017, 06:45 AM | #50 | ||
Stark und Frei
48
Rep 155
As I said before... Cost reductions. Last edited by Mauricio Palacios. MD; 05-06-2017 at 07:00 AM.. |
IK6SPEED4487.00 |
05-06-2017, 09:12 AM | #51 |
Rep 13
I received my new F36 yesterday and drove it at night. It has the non adaptive LED headlights and visibility was excellent. Any brighter and it would start fires imho. I really do not recognize the negative comments...
05-08-2017, 12:01 PM | #52 | |
Rep 701
It depends on your previous experience, your own standard and etc.. But i can tell you from my personal experience, my initial reaction to the LED was the same as yours. I was blown away by the white color on the ground vs. my previous HID, which were all yellowish on the ground regardless what they look like from the headlights themselves. It was not until several months into the ownership, i start noticing some of the negatives. So i was looking for ways to adjust them to make them aim slightly higher. But since it has reflectors instead of projectors, it is difficult to aim them to a satisfactory level without blinding others. |
05-21-2018, 05:29 PM | #53 |
Rep 18
Poor Lights on M 235i
Its Factory Set..and does not shine far enough ahead on the read..
I am thinking of getting the LED option on the 2019.. Any Comments or Recommendations..Thank You |
05-21-2018, 05:56 PM | #54 |
Rep 10,473
Comical to see all the mistaken assumptions over the past 2 years in this bumped thread.
Since that time, US Govt has tested headlights and we know BMW non-Adaptive LED are rated poor (as are Halogen) but the halogens actually perform better than the non-Adaptive LEDs. Even the BMW Adaptive LEDs only get an acceptable rating (only 3 ratings are Good, Acceptable and Poor). They were not even rated Good for 2 years in a row. Adaptive Xenon HID are still the best lighting for BMWs in the USA. |
upsidedownfunnel1996.00 |
05-22-2018, 01:17 AM | #55 |
Rep 415
I also have an F36 with standard, non-adaptive LED's and find them excellent. The pre-LCI F36 had xenons as standard, so I would hope that the LED's are comparable, but there seem to be so many negative comments from 3 series owners. Does anyone know if the F30 and F36 have the same system?
Current: G20 330i M Sport
Previous BMW's: F36 420i Gran Coupe M Sport; Z4 Coupe 3.0si M Sport; E46 325i Sport coupe; |
05-22-2018, 09:53 AM | #56 | |
Rep 10,473
09-29-2018, 12:37 PM | #57 |
Rep 640
Drives: 2008 M3 (E93)
I have a 18’ 340 with non adaptive leds and I find them plenty bright at night time. I also noticed that they’re self leveling even though they’re non adaptive which is pretty cool
"Hard times create strong men. Strong men create easy times. Easy times create weak men. Weak men create hard times."
09-29-2018, 12:42 PM | #58 |
Rep 247
I have the adaptive LED's, coming from my 2011 S4 with xenons. I immediately noticed how much whiter and better the LED's illuminate the road, especially with the fogs on. I can't imagine why they would be rated poor or anywhere near the performance (or lack there of) of halogens
09-29-2018, 06:26 PM | #59 |
Rep 191
im confused at everyone saying non adaptive aren't as bright. I just picked up a '19 f36 with standard led and they are the projector style (like bixenons) and look just as good as my '16 f32 with adaptive ( 4 reflector style)
did they change to projectors in later Model years?
2012 335 2016 435 2019 440 GC |
09-29-2018, 06:38 PM | #60 |
Rep 1,392
I have adaptive LED with HBA. Had the car coded to euro specs HBA. Seeing high beam split as you comes up to the car in front of you. It is the coolest thing ever.
2014 435i M Sport //AW, CR//premium, tech, lightening pkgs//20% tint//full clear bra//ppk//blk grills//20" Vertini wheels//digital gauge//Apple Carplay//MPE with catted DP//VSRF charge pipe//Wagner FMIC//
09-29-2018, 11:44 PM | #61 | |
Rep 10,473
https://m.iihs.org/mobile/ratings/mo...s-4-door-sedan |
09-30-2018, 08:20 PM | #63 |
Rep 257
A few cars ago, I had a Lexus with Adaptive LED's and they were the best headlights in any car I had been in or owned. They had an additional reflector halogen high beam that I had replaced bumped up to 100 watts per side from 55 watts.
The adaptive LED's on my 2018 are every bit as nice. I like the way the fogs come on in the corners and with the turn signals. I just wish they could be coded for anti glare like the earlier ones, but oh well. ADAPTIVE LED (36 watts): NON ADAPTIVE LED (22 watts): AIMING GUIDE:
2021 i3s AC Schnitzer BMW CCA #67486 |
Poochie9104.50 |
09-30-2018, 11:26 PM | #64 | |
Luxury at the redline :)
9105
Rep 7,563
35 watts is brightest allowed in the US. 55 or 100 watts would have to be aftermarket and most likely will blind other motorist, if not aimed properly.. Were they worth the upgrade ? https://www.thecarconnection.com/new...for-headlights |
10-01-2018, 10:34 AM | #65 | ||
Rep 148
10-01-2018, 08:00 PM | #66 |
Rep 134
Drives: 2017 f32 440i coupe
I have adaptive but I hardly notice it doing anything. maybe im just blind
