10-13-2018, 04:54 PM | #1 |
Rep 368
Left side "clunk" noise during heavy cornering + low speed bump (RESOLVED)
I need help diagnosing a "clunk"/loose metal noise on the left/driver side.
It's present during these situations: 1. Whenever I hit a moderate bump on my front left wheel during hard cornering to the right -- and only right. Like when I'm going on an on-ramp. 2. At moderate speed when I go over large bumps in the road like one of the larger protruding lane reflectors on the road. My car is at 70k and have just replaced both lower thrust/control arms (with M3 arms), sway bar links, struts + shocks (Bilstein B6 on Dinan springs) and tie rods. The noise was present BEFORE all the replacements and is still present after. Could it be a sway bar bushing? Steering? It's not something that arises frequently but it does rear its head during more spirited driving ... which really take away from the experience. Thanks ------- UPDATE 1: So I finally received the service kit. See picture below. However, I decided to hold off on installing the kit and just try tightening the problem three-prong steering cap/bolt. 1/8 clockwise turn fixed the problem. Initially tried 1/4 which made the steering stiff and prevented it from going neutral after a turn. So I backed it out to 1/8 and it was perfect. No more knocking noise on bumps and no more knocking noises when steering wheel is shuffled left and right when car is off. [IMG]https://i.ibb.co/nqG2kHH/Screen-Shot...2-36-30-PM.png[/IMG] [IMG]https://i.ibb.co/bXRfHZY/Screen-Shot...2-36-35-PM.png[/IMG] [IMG]https://i.ibb.co/zJ22Thw/Screen-Shot...2-36-41-PM.png[/IMG] UPDATE 2: Noise came back after 10-15k. I went ahead and installed the service kit. So far after 10k, still no noise. Also, Harbor Freight sells an adjustable pin wrench that works great for the three-prong cap -- no need to buy an special BMW tool. https://www.harborfreight.com/adjust...nch-36554.html
2016 340i XDrive: Bootmod3. And stuff.
10-14-2018, 11:28 PM | #3 |
Rep 368
Really? 😞
10-24-2018, 06:29 AM | #5 |
Rep 44
BMW actually acknowledge there are "acoustic abnormalities" with the steering rack and having undergone around 14 part number changes they now sell a repair kit for ~£20
Scroll to the bottom of this link... https://www.etkbmw.com/bmw/EN/search...0d/ECE/32_2071 The real cheek is that they arent doing a technical recall when they practically acknowledge there is a defect!! |
10-24-2018, 12:07 PM | #6 | |
Car Hypochondriac
331
Rep 899
Edit: I'm dumb, it's a whole kit. Probably has a bunch of pieces. Maybe I'll order and see if I can figure it out? Last edited by Eschmacher; 10-24-2018 at 12:13 PM.. |
10-24-2018, 12:17 PM | #7 |
Car Hypochondriac
331
Rep 899
Related video about the repair kit:
From a comment on the video: "I had this done two days ago by a BMW specialist garage. There is a few special tools you need to complete the work, not sure if a computer adjustment is needed. The kit was released by BMW on the 18/09/18. It was fitted to my car 430d 18/10/18 and so far has transformed the drive, honestly it feels like a brand-new new car. Get it done but don't do it yourself." Sounds like I might consider doing this... I wonder how much my local shop would want |
10-25-2018, 01:06 PM | #8 | |
Rep 368
10-25-2018, 02:30 PM | #9 |
Rep 776
Does anyone know if the clunk is actually damaging anything besides whatever replacement parts are included in the repair kit? Is the clunk shortening the steering rack's life?
M240i | Mineral White | Coral Red
10-25-2018, 07:50 PM | #10 | |
Rep 687
Drives: 22 TR X3MC
2022 X3M Comp
2013 335i xDrive (Sold) |
10-26-2018, 04:50 AM | #11 | ||
Rep 44
11-06-2018, 08:34 PM | #12 |
Rep 173
Anyone else have any feedback on this repair? Install cost?
Here are the install instructions that I found. https://www.newtis.info/tisv2/a/en/f...nit/1Vnc3X9PQZ |
11-07-2018, 01:47 PM | #14 |
Rep 886
I want to kiss the dude that posted the video!!
I've been dealing with a thunking noise from the left front of my car (for over 18 mths) that the dealer diagnosed as a failed EDC damper. The verdict a nearly $3K repair to swap both front EDC dampers......despite having a Platinum Extended warranty - dampers are deemed as consumables and not covered under warranty. I always questioned the diagnosis as there was no change in handling, no fluid leaking from the damper, and the suspension mode switching works just fine I did the shake test with the car off like shown in the video and I have the exact noise in a very pronounced fashion. I'm certain this what the problem is. |
11-09-2018, 04:19 PM | #15 |
Respect My Authoritah
368
Rep 873
This thread is awesome. Thanks everyone!
2014 335xi M-Sport 6MT: Estoril Blue II, MHD Stage 2+ , Dinan Exhaust, Dinan CAI, ER Catted DP, ER Chargepipe, AA FMIC.
11-09-2018, 08:11 PM | #16 | |
Rep 552
TKP (thyssenkrupp) and ZF. BMW are only describing it as an acoustic abnormality. So maybe they don't see it being a safety concern for a recall. |
11-13-2018, 04:11 PM | #17 |
Big Turbo Boys N Girls
327
Rep 579
Just make your own tool to tighten the 3 prong nut down or buy the $50 part and turn it a quarter of the way. I tightening mine up and problem went away. They get slop over time or were not tightened down enough from factory. I went through 3 steering racks and problem always came back. Decided to tighten down the cap 1/4 and problem has not returned in 2 years.
2012 F30: G25-660 Bottom Mount Mani+ DP+ Intake, CSF FMIC, VRSF CP, Walbro 450 LPFP, PR Injection with AIC 4, S63TU Injectors, Tuned with BM3, ZF Race 4 Puck and Non SSA Pressure plate, Catless, 3.5" Quad Muffler, Custom Valved Bilstein B8 + H&R SS. Max 456 WHP - 452 WTRQ. Currently tuned down to 434 WHP and 362 WTRQ to save the rods.
11-13-2018, 04:28 PM | #18 | |
Rep 173
Did you make your own tool? If so what did you use? I have searched and searched for the tool from a US supplier. I can only find it in Ukraine for $25 + $75 shipping. |
11-13-2018, 10:21 PM | #19 | |
Rep 5,451
Drives: F30
11-30-2018, 10:25 PM | #20 |
Rep 1,827
Sub'd. Just noticed the same thing starting about a week ago.
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~ |
12-04-2018, 04:42 PM | #21 |
Rep 368
FIXED!
So I finally received the service kit. See picture below. But I also decided to DIY the three prongs tool out of a piece of aluminum, some screws and bolts. 1/8 clockwise was what I needed for my car. Initially I tried 1/4 which made the steering stiff and prevented it from going neutral after a turn while driving. So I backed it out to 1/8 and it was perfect. No more knocking noise on bumps and no more knocking noise when steering wheel is shuffled left and right when car is off.
12-06-2018, 10:03 AM | #22 | |
Rep 142
