BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Sport automatic -- 2TB do it!
European Auto Source (EAS)
      06-24-2016, 06:11 AM   #89
frackje
frackje's Avatar
Belgium
44
Drives: AH3
According to the dealer nothing is wrong with it..while I have 2TB.
jknight12.50
      07-03-2016, 01:18 AM   #90
cs135i
Comes to RWD from FWD, with a dream of AWD
cs135i's Avatar
Drives: AW 09 135i
Anyone have this error code after coding 2TB?
Code:
Unknown - FKB_CF2101 - No message (shift paddle operation, 0x207)
Fault description: The receiving control unit logs the fault when an expected message from transmitting control unit is not received. These types of faults usually stem from interference on the bust connection between the affected control units (physical link).
I did disable shift paddle under FEM_BODY => PADDLES_VERBAUT
Somehow this error is persistent
09 135i Arrived!!!
03-25-2010 7pm
      08-12-2016, 02:40 PM   #91
fhlh
fhlh's Avatar
Drives: 2013 BMW 335i M-Sport
2013 BMW 335i  [0.00]
Originally Posted by jondaman View Post
I just did it by changing the FDL
EGS/3000 Applikation -> Sportschalter_alt -> aktiv
EGS/3000 Applikation -> Sportschalter -> aktiv
I did not add the 2TB like others did because I don't care about having Sports +.
You guys are right, this was totally a great thing to add. I can't believe how smooth the gear shift is now when cruising. Should have been the default programming from factory to begin with. :\
Ok.. I need some clarity here.
I don't need to Code VO? to get sports auto performance?
I have a weird 2013 Msport, that didn't come with paddle shifters, BUT, I do have Sport and Sport+ mode available and 205 is listed in the VO.
If I change FDL to the above the DS indicator will change to gear output, and I'll have this smooth / quick shifting everyone is raving about???
TIA
2013 335i M-Sport 8spA
2011 M-B GLK350
2000 Dodge Ram 2500 QC 4x4 CTD
      08-12-2016, 02:50 PM   #92
jondaman
jondaman's Avatar
Drives: 2013 328i
I have a weird 2013 Msport, that didn't come with paddle shifters, BUT, I do have Sport and Sport+ mode available.
IF I change FDL to the above the DS indicator with change to gear, and I'll have this smooth / quick shifting everyone is raving about???
TIA
It has been a while but you don't have code VO since you already has the sports+.
I just coded FDL and the shift does become faster.
Past: E46 Metallic Blue Coupe 323i GONE: E86 Jet Black Z4 Convertible GONE: E92 Crimson Red 335i,
F30 Liquid Blue Matallic 328i
Current Garage Queen: Mineral White F83 M4
fhlh36.50
      08-12-2016, 06:28 PM   #93
fhlh
fhlh's Avatar
Yup. Best mod I've done so far! Thanks all!!
2011 M-B GLK350
      09-15-2016, 05:30 PM   #94
madmortar
Drives: 2013 BMW 328i M-Sport
Once you code for SAT, going left on the shifter, you will NEVER see DS anymore? Just S1, S2, etc etc?
      09-15-2016, 05:36 PM   #95
fhlh
fhlh's Avatar
that's correct... that is a good indicator you coded correctly, as is the swifter shifting... it's the best mod I've done to date
2011 M-B GLK350
      10-11-2016, 11:32 AM   #96
blackforge
Drives: 328i
I FDL coded only these two items on my car (2013 328i Msport that already had the Sport + setting with the 205 option) and it is now showing a check engine light. Any ideas or should I just revert back?
      10-12-2016, 05:58 AM   #97
kretzu
King ♕
kretzu's Avatar
Romania
1360
Drives: F30 320d - STAGE1
You should make a test plan (diagnosis) with Rheingold and delete the errors. Also pay attention to what error the car gives you. It shouldn't come back.
p.s. - I think you should VO code your code, delete the 205 option and add the 2TB one. Before doing this, revert the FDL codings you did to default. (nicht_aktiv on both)
      10-12-2016, 11:22 AM   #98
blackforge
Drives: 328i
Thanks for the reply kretzu.
I ran tool32 for now to clear the code, so far it seems like everything is OK and hasn't come back. If it comes back, I will run Rheingold and see the specific error code.
Worst case scenario, I'll revert it back and take it to the dealer for diagnosis.
I don't know if it's a placebo effect, but I do feel a difference in the way the car shifts, even in comfort mode.
      10-14-2016, 12:46 PM   #99
D Unit
Drives: 2013 x1 s28i
Is it possible to program sport automatic on a BMW x1 e84? My wife's F30 has sport automatic stock and it's a night and day difference better than my x1.
D Unit
Bay Area, CA
      10-15-2016, 03:25 PM   #100
TePee
Drives: F34 LCI MY2019
The E84 X1 has a completely different automatic transmission, older generation ZF 6-speed. The F30 we're talking about here is a younger generation 8-speeed ZF 8HP (which has sport automatic option). This could explain the night and day difference
      10-15-2016, 03:49 PM   #101
D Unit
That is unfortunate and I believe your facts are correct. I guess I will avoid driving my wife's f30 as much as possible....
      10-19-2016, 08:13 AM   #102
MrMarvin
electrified
Sweden
28
Drives: 330e -17
Hey guys,
I have a question, my 330e didn't come with the sport automatic option, but it still shows S1, S2 etc instead of DS. It shifts really quick aswell, sometime it feels like a jolt when it shifts gears. Can it be that this car has a special gearbox due to the electric motor?
Thanks in advance.
      10-21-2016, 01:36 AM   #103
nemobanks
Nemo banks
nemobanks's Avatar
Drives: 2014 BMW F30 328i
Originally Posted by KGB_123_99 View Post
I have had the sports automatic coded on my F30 for almost a year now and really took it for granted. Before going to the dealer this week, I reverted back to the regular automatic tranny programming. What a difference!!!
The sport automatic is the best coding you can do for your car imo. Not only are the shifts faster in every mode including comfort, but the gear changes are so much more responsive. In Sport mode the tranny feels like a DCT with a nice jolt every time you up shift with WOT. It boggles my mind why this programming is not default on a BMW.
In other words, code your auto transmission and see what it's all about if you haven't yet!
How do you revert back?
      10-21-2016, 01:42 AM   #104
nemobanks
Nemo banks
nemobanks's Avatar
Originally Posted by Davey78 View Post
Yeah, the ordered the new shifter based on VIN. My SA was pretty cool, he called me when it arrived and confirmed it was the same one that I had. I told him that I'll bring the car back next week to finish the i-step update, once I set the 2TB back to 205. They noted my service order that "vehicle needs update, customer will bring back due to time contraints"...
How can i do this ? I coded 2TB and removed 205 . Can you please tell me how to go back to 205.
      10-21-2016, 09:51 AM   #105
KGB_123_99
Drives: '17 330ix M-Sport
You just undo the FDL coding on the EGS ECU.
      10-27-2016, 07:59 PM   #106
catharsis
Drives: e60
Originally Posted by MrMarvin View Post
Hey guys,
Thanks in advance.
The 'sport auto transmission' is not an available option for the 330e BUT the 330e comes with paddle shifts and Sport+ mode already installed by default.
I coded SAT and was unable to see any clearly identifiable difference (as you point out pushing shifter to the left already brings up S1,S2 etc on the 330e)
I keep meaning to code launch control via FDL coding and see if that works. To date I've not been able to see confirmation of whether anyone else with a 330e has done that (successfully or otherwise).
      11-08-2016, 04:32 AM   #107
MrMarvin
electrified
Sweden
28
Drives: 330e -17
Does it come with paddle shifters coded by default? Cause mine didn't come with the physical paddles. But surely enough it shows S1, S2 etc and has Sport+ aswell.
      11-17-2016, 02:05 PM   #108
Aello
Drives: 335i xDrive M-Sport Package
Hi guys,
I have a 2014 335i xDrive with the M sport package but without the sports automatic transmission. I need help coding 2TB since this is my first BMW. Can anyone help me out. I have seen that I need a cable and a few programs, it's what I need to do inside the programs that I need help with.
      11-17-2016, 08:14 PM   #109
Almaretto
Almaretto's Avatar
Drives: Test Vehicles
Hey guys,
Thanks in advance.
Like the F15, xdive40e, the 330 has option 2TE Automatic Transmission with Gearshift.
Depending on your EGS, you may not even have LC funktion parameter present.
Code:
Yeah, I have seen that before. Usually, much like coding 6NS, without followup with changing mic # back to 1 will show dash fault. However, only error codes showed up in ISTA+.
Originally Posted by Aello View Post
Hi guys,
It is rather straight forward. You need E-sys and Psdzdata to VO code vehicle. If you plan to FDL code, you need TM's Launcher to generate token and provide CAFD mapping. Let me know if you need software.
      11-30-2016, 06:52 AM   #110
sdjro
Romania
Drives: BMW F32
Today i coded back to 205 due to upcoming service visit, and i can say what a big difference ! it feels a lot slower and with decreased sensation of power.
