BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Sport automatic -- 2TB do it!
proTUNING Freaks
      08-31-2019, 02:55 AM   #265
atzebmw
Drives: BMW 335XD F30 LCI
Originally Posted by mupet0000 View Post
How can this happen and why is it happening?
VO isn't changed from 205 to 2TB
Or you changed the VO but didn't load the changed VO because you read and activated the VO from the car (which isn't changed).
      08-31-2019, 03:58 PM   #266
mupet0000
Drives: 2019 F20 118i Shadow Edition
VO was coded to the car with "Write FA FP" and then confirmed with "Read FA FP". 2TB was present when read from the cars ECU. It only changed back to 205 after coding FEM_BODY.
Are you saying if I already had been in expert mode, coding, and had already read the FA before I changed to 2TB, that causes this problem?
So I should change to 2TB, write FA FP, expert mode coding, then read, activate fa, code ecus. I'm pretty sure this is how I did it already anyway.
      08-31-2019, 05:01 PM   #267
atzebmw
Normally it is impossible that the VO is changing itself.
You can write the VO into the car or you can leave it.
Important is only that the VO with 2TB was loaded before coding.
      09-09-2019, 04:14 AM   #268
CalBadda
Drives: BMW F31
Coded 2TB into a mid-2013 F31 and took it out for first drive yesterday - I feel like the rev counter is not reflecting the actual revs of the engine - stays below 2k for example when I can hear the engine revving up, and the fuel consumption gauge goes off the scale.
Switching to manual mode seems to "reset" the counter and it reflects actual revs, but then putting it back in either drive or S-auto and after a while the same thing happens.
Only thing I did was accidentally code the individual CAFDs rather than the whole ECU the first time around - then recoded the full ECU afterwards. No errors showing in the car other than the need to reset date/time.
Is this a known issue at all, or perfectly normal (unlikely)? Or should I revert to factory 205 setting and try again? Vin is F665538 if that helps.
Thanks!
      09-23-2019, 08:39 AM   #269
CalBadda
Drives: BMW F31
Thanks!
Working fine now, must have sorted itself out after a couple of drives cause I didn't change anything!
      10-08-2019, 02:26 AM   #270
RokasLTU
RokasLTU's Avatar
Drives: Volvo V50, BMW 318d
Hello,
My car already has Sport+, menus, and in D/S mode it shows S1, S1 and so on.
But checking the vin, it shows 205 Automatic transmission instead of 2TB.
Maybe previuos owner had coded it?
How to know which transmission do I have without editing.
My esys cable is still coming.
      10-08-2019, 06:13 AM   #271
Vortex8
Drives: BMW GT 328xi
If you have M-Sport package you can have 205. I have 3GT M-sport and I've had Sport+ and in Sport mode it showed S1 S2... I've coded the 2TB and the difference was significant. I think that with 2TB option you also get the shift paddles.
      11-08-2019, 04:44 AM   #272
dzudzar.vladimir
Drives: BMW F30 320d 2013
Question
Hello, I today coded sport+ mode, launch control, sport transmission. When I put car into sport + mode, shifter to the left it shows S1, S2 and when I step on it shifts pretty hard, I get hard kicks when changing gears. Is that good?
