BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Sport automatic -- 2TB do it!
      01-21-2018, 07:59 AM   #177
ak-x-34
Drives: BMW 1M
Thanks for feedback. Today I try to FDL-Code the EGS but I can't read the current coding from this modul. There is no green dot in the list of EGS (CAFD Line is missing). Do you have an idea?
      01-21-2018, 08:08 AM   #178
atzebmw
Drives: BMW 335XD F30 LCI
CAF zu SWE ermitteln
If you have created the new CAFD you should be able to code or FDL code.
      01-21-2018, 08:39 AM   #179
ak-x-34
Drives: BMW 1M
Hey thanks a lot for information. Which steps have I to do to "CAF zu SWE ermitteln" I have never done this.
I hope that you can help me.
Edit:
I found a instruction ... and it works thanks a lot for your help. Now I could code the EGS with 2TB. But unfortunately the paddles don't work. Tomorrow I will chef if the wire to the FEM is installed or not.
      01-21-2018, 09:12 AM   #180
atzebmw
Great...
      01-21-2018, 10:20 AM   #181
ak-x-34
Drives: BMW 1M
Great...
Due to the fact that I am very impatient, a few minutes ago I have checked if the wire from FEM to the steering wheel is in place. And the wire is allrady installed at the FEM.
Now I really don't know why the paddles didn't work.
I change 205 to 2TB in VO write new VO to the car and code EGS / Kombi and ICM.
Is it nessacary to code FEM_Body too?
      01-21-2018, 10:31 AM   #182
atzebmw
Yes, of course.
      01-21-2018, 10:54 AM   #183
ak-x-34
Drives: BMW 1M
Yes, of course.
Oh ok ... now it works ... Thanks a lot for your support!
In the past I retrofitted a lot at my F20 (609 ...) but I'm not really a specialist and I'm verry happy of the frindy support here in the forum.
Have a nice sunday ;-)
      01-22-2018, 09:14 AM   #184
sspade
sspade's Avatar
Drives: F30
2014 BMW 328i  [5.00]
Can sport automatic be coded with BimmerCode?
BMW 328i FBO, Bootmod3 Stage 1
      01-29-2018, 03:08 PM   #185
goin_nutz
Drives: m140i
does anyone know if the gearstick is plug and play? i bought one on eBay off a breakers, from RHD and it won't work when i plugged it in and screwed it down. cam up with unable to change transmission error on dash. it also feels like it's maybe from a lad as the ergonomics of it feel wrong. my old car had the sports transmission, same gearstick and it felt different ergonomically.
      01-31-2018, 05:04 PM   #186
cempamuk
cempamuk's Avatar
Drives: 2014 bmw 328i
Originally Posted by Almaretto View Post
PM'd step-by-step pictorial guides. Let me know if you still have questions after looking over material.
Hi! I do have 2014 f30 328i I have Bimmercode app but I couldn’t find how to do sport+ mode code transmission on expert mode do you know how to code or do you have any instructions about it. I will truly appreciate for this
      01-31-2018, 07:00 PM   #187
Almaretto
Almaretto's Avatar
Drives: Test Vehicles
No. I just know how to do it with E-sys. I never use phone apps.
      02-01-2018, 04:26 PM   #188
sspade
sspade's Avatar
Drives: F30
I have been asking this question for literally four months and have never gotten a response.
      02-11-2018, 04:01 PM   #189
DriveS
Drives: F30 335d
I did the FDL coding for this quite a while back. Tomorrow I am VO coding EBT. Is it worth VO coding the gearbox mod, or not necessary?
      02-12-2018, 01:08 AM   #190
Almaretto
Almaretto's Avatar
EBT has nothing to do with gearbox.
      02-12-2018, 01:41 PM   #191
DriveS
Drives: F30 335d
Yes I know that. I will re-phrase -
As I have my laptop connected (doing the EBT), is it worth VO coding the gearbox mod. OR as I have already FDL coded it with the options below, is there no point?
EGS/3000 Applikation -> Sportschalter_alt -> aktiv
EGS/3000 Applikation -> Sportschalter -> aktiv
EGS/3000 Applikation -> LC -> aktiv
      02-12-2018, 11:10 PM   #192
Almaretto
Almaretto's Avatar
FDL coding can accomplish everything and have same result as VO coding.
I use VO coding when adding or removing factory options as well as let E-sys figure out the details and do the work.
If already coded, there is no advantage to re-doing other than practice.
I never write FA changes to VCM, so VO appears factory at dealership.
      03-02-2018, 04:19 AM   #193
analizer
analizer's Avatar
Greece
Drives: BMW F30 318d 150HP 2016
Hi All,
Some questions from my end.
I have an F30 (2016) with the automatic transmition (not the sport one) and I DO NOT have the paddles! But I have Sport+ already enabled in my car from the manufacturer without 2TB in my FA.
Now. I am in the process of adding myself the Paddles but I was thinking to enable the Sport Transmition before paddles.
So if I have read through the thread correctly, I wont need to do any FA/VO coding and only do FDL coding:
And once I install the paddles I will also have to add: FEM_BODY => PADDLES_VERBAUT = aktiv
My questions:
1. I do not have the 2TB. I looked through my FA and I have the ​205 instead of 2TB. Should I add it as I already have Sport+?
2. If I add the Sport transition is there any change of doing any mechanical damage or long term harm? or is it just a software change?
3. My BMW is a diesel one. Not sure if makes any difference.
Thanks
      03-02-2018, 06:32 PM   #194
Aekdbrich
Grand Poobah
Drives: 2014 328i XDrive (F30)
Hi! I do have 2014 f30 328i I have Bimmercode app but I couldnÂ’t find how to do sport+ mode code transmission on expert mode do you know how to code or do you have any instructions about it. I will truly appreciate for this
just saw this. I don't know the true answer, but I can try. I don't think that it can be done via Bimmercode. I don't use the app myself. Not that I don't want to, just that I don't have it. 2TB needs to be VO Coded and Bimmercode only does FDL. I could be wrong though.
2014 328i XDrive N26 (F30), bootmod3 Stage 2 AGG, VRSF Catless Downpipe, K&N Drop In Filter
      03-02-2018, 08:11 PM   #195
sspade
sspade's Avatar
Drives: F30
Thanks for the response. BimmerCode does have an Expert Mode which is where I was thinking it could be possible. Not saying it can, just saying I believe you can create and alter actual code in Expert Mode. Just not sure if anyone has tried or confirmed one way or the other...
Aekdbrich152.00
      03-02-2018, 08:15 PM   #196
Almaretto
Almaretto's Avatar
It could be done in Expert Mode, but you would have to know changes that E-sys makes for you with VO coding.
Aekdbrich152.00
      03-02-2018, 08:46 PM   #197
Aekdbrich
Grand Poobah
I kind of want to buy the interface just to mess with it now!
      03-07-2018, 09:24 AM   #198
iAlexander
Drives: 320i
Glad I found this thread. No more worrying about my engine blowing up when it should just change the gear already! Always hated how it likes to rev for a long time before shifting but now it’s so smooth it feels like a normal car.
