BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Guide to Upgrade 6.5" Screen to 8.8" Screen HU_ENTRYNAV
      02-18-2024, 04:03 PM   #1101
WadBike
Drives: BMW M140i
Originally Posted by Homersbud View Post
without the shorten vin (7 characters), there is no way for anyone to help.
provide vin.
My bad. Vin is 5G99812. Thanks for your help
      02-18-2024, 04:46 PM   #1102
Homersbud
Drives: BMW X1
65509387548 looks good - that’s the one i’d purchase.
      02-22-2024, 01:55 PM   #1103
wembleyhill
Drives: f20
nbt 8.8 to 6.5 downgrade
hi i need to downgrade screen from 8.8 to 6.5 tried to code
HU_NBT > 3000 HMI > DISPLAY_SIZE_RESOLUTION = 6.5_800x480
HU_NBT > 3001 EXBOX > DISPLAY_VARIANTE = schmales_display
but all i get is black screen
      02-24-2024, 06:53 AM   #1104
LikeNo1
Drives: 2017 F25 X3 LCI x20d Msport
1st why?
2nd wrong 6.5 screen: as you can read it's an apix2 instead of apix1 managed by your head unit.
I think you won't have any trouble making an exchange from another member of the forum.
      02-25-2024, 06:12 AM   #1105
wembleyhill
Drives: f20
Originally Posted by LikeNo1 View Post
1st why?
Ok thanks original is damaged and owner dont want to spend
      02-25-2024, 12:55 PM   #1106
Abbo1967
England
Drives: BMW F22 228I
I have just done this to my F22 2016 using the 65509292248 screen, coded it and it works great. I also didn't need to do anything for the split screen, it works fine
      02-25-2024, 12:56 PM   #1107
Abbo1967
England
Originally Posted by TePee View Post
The LCI 8,8" screen won't work with your HU Entrynav! It uses different voltage. You have to install the pre LCI screen.
Normally when you code 8,8" screen and broad display everything will work in proper way, including split screen etc.
The question is whether this is the case or not when you have Integrated Navigation?
      03-10-2024, 01:09 PM   #1108
HamDiddy
Drives: BMW 435i
For those who had issues with 1/3 of the screen being black when upgrading from 6.5 to 8.8" screen...
I have 2016 F33 with HU_ENTRYNAV, 6.5" screen with no navigation. I was able to successfully upgrade to 8.8" using part #65509387453.
Reviewing previous posts I saw many say it was not possible, but that is incorrect. The key is (what a few others called out) using E-Sys to code. I had attempted to change the screen resolution and display variate to brietes_display using both BimmerCode and BimmerUtility multiple times. It always resulted in 1/3 of the screen being black. Using BU but coding using E-Sys, it worked on the first try by just changing the screen resolution and display variate (only two entries to change for HU_ENTRYNAV). Hope this saves someone the frustration.
Homersbud202.00
      03-12-2024, 11:42 AM   #1109
darkexodus
Drives: BMW f30 318d lci
Hi.
I would like to ask for some help with choosing of the right CID for my car.
At the moment I have 6.5" with business nav and would like to install 8.8"
Over the bimmercode I can see that I have hu_nbt_evo and current screen is Apix2.
My VIN nr is A084495.
Hope I gave right info.
      03-12-2024, 12:44 PM   #1110
Homersbud
Drives: BMW X1
Originally Posted by darkexodus View Post
Hi.
looks like you can do touch & either of these wouldve came from factory, so buy one of these - 65508709338/65508709339
https://www.realoem.com/bmw/enUS/sho...diagId=65_2356
      03-12-2024, 12:49 PM   #1111
LikeNo1
Hi.
According to your vin you should install the 8709338 cid that is touch, hard to find.
As I know you can install the last of “non touch” cid 6822626 that is an APIX2.
      03-29-2024, 01:14 PM   #1112
avtosegment
Drives: bmw f30
yes - see many replies above for same issue. you need to use esys to code in change. very common problem for some using bimmercode - fix is esys.
good luck.
Hello everyone! Everything turned out exactly through ESYS. Bimmercode cannot encode the resolution. Thank you all!!!
Homersbud202.00
      03-30-2024, 09:35 AM   #1113
inigoale
Drives: bmw f30 328d 150cv lci
Hello, where do you buy the 8.8" screen? What price is good to buy?
      03-30-2024, 09:49 AM   #1114
Homersbud
Drives: BMW X1
ebay - junk yards - fb marketplace.
no one knows a good price as each one is different. i paid $300 US for my 8.8 a few yrs ago from ebay.
      04-07-2024, 05:37 PM   #1115
ADHD
ADHD's Avatar
Drives: F30 328i
21 M540i  [0.00]
07 e90 335  [0.00]
Originally Posted by kromix View Post
No.
HU_ENTRY = can't be done.
If your car has HU_ENTRYNAV (Introduced 7/14) then you can do it.
I tried anyway and Failed...Still incompatible with HU_CIC all i got was NO SIGNAL a few times. Guess ill have to swap the HU as well to get a bigger screen. I do not have "DISPLAY SIZE RESOLUTION" in the coding files. I do have the Brietes display option but it doesnt do anything at all. i tried every way possible.
Looks like im on the hunt for a NBT HU now that i got the screen but im Currently lost on realoem at what HU to get???
F436311
      04-07-2024, 08:46 PM   #1116
Homersbud
Drives: BMW X1
F436311
start at realoem.com and use the p/n you got for the 8.8 cid and from there, you can see what cars have that 8.8 cid and just pick one and grab the p/n for the HU listed.
      04-07-2024, 08:51 PM   #1117
ADHD
ADHD's Avatar
Drives: F30 328i
21 M540i  [0.00]
07 e90 335  [0.00]
i just cant seem to find even the exact HU on there that i have to compare to the others... Theres few dif categories on the HU the options are just confusing to look at. Re reading the thread I think this NBT headunit is what i need:
https://www.ebay.com/itm/14564700522...Bk9SR5bHk7bXYw
or wait ur saying search the CID part number?? This is the screen pn real oem lists. 65509292248 I tried searching the part just shows superexceeding parts etc...
      04-07-2024, 09:06 PM   #1118
Homersbud
Drives: BMW X1
there are two HU options that came fitted from factory for your car - 65129270375 or 65129270373.
The one from ebay looks like it should work.
https://www.realoem.com/bmw/enUS/sho...diagId=65_2360
ADHD195.50
      04-07-2024, 09:21 PM   #1119
ADHD
ADHD's Avatar
Drives: F30 328i
21 M540i  [0.00]
07 e90 335  [0.00]
THANK YOU. yup thats the long list thanks for making sense of that for me. Appreciate it. Just wanted to confirm before i threw another hundo at it.
      04-07-2024, 09:23 PM   #1120
Homersbud
Drives: BMW X1
good luck. make sure you are ready to code the HU to your car as it’s not an easy task. might be better to pay someone to help you out with that.
      04-07-2024, 09:35 PM   #1121
ADHD
ADHD's Avatar
Drives: F30 328i
21 M540i  [0.00]
07 e90 335  [0.00]
ive got ESYS installed finally got the psdzdata file to extract and connect to the program just waiting on a ethernet to usb adaptor now. Ive done everything else on bimmercode the -auto/start -disclaimer removal- ledlights- tpms-. So going to Esys is def a Task that i think i can handle after reading some posts and threads ill just need to find a correct SOP. Psdzdata LITE is 16gb. had to setup an external usb disk cause the cheap pc laptop i have is only 32gb Kept saying internal error and file has no end etc etc.. what a headache that was...So i already know its not going to be easy..
Being that i have the MMI installed and working now and have the 8' screen im not stopping now......
      04-10-2024, 11:30 AM   #1122
Jezz
Drives: BMW F31 2019 330d
Hi, I bought the f31 2019 vin AE87498, head_unit ENAVEVO. w/o navigation.
I'm really missing CarPlay and reverse backup camera, what's my best option(s).
Looked on AliExpress but there's so much, very confusing.
Upgrading the iDriver controller would also be great as I only have 3 buttons.
Thanks
Jezz
