07-21-2019, 02:37 AM | #1 |
Rep 21
Hi. I've buyed the Carlinkit CarPlay module... and I'm not really happy with it... It is sold as NBT/NBTevo/6,5'/8.8'/10.2' compatible...
https://s.click.aliexpress.com/e/ciKWNznS After having tried all dip switches settings to match my 8.8' nbt evo screen, I can say that the image quality / resolution of the CarPlay interface is really bad on NBT-EVO... it's like displaying a low resolution image on a HD monitor... You see pixels on icons corners and fonts. The image seems to be stretched (CarPlay home icon is not round, but oval)... Colors seems to be washed (Like when you put brightness to full on a screen...). Text is unreadable in Waze (because of small fonts) The internal microphone Works but there is a lot or garbage noise when you try to make/answer a call ... Siri didn't recognize what you say... I've tried to use external mic and it is worst... I wanna say that the only thing that works is the audio part... Maybe that my module is defect... I want to know if you experienced those kind of problems with your CarPlay module (joyeauto/carlinkit or other brand...) on nbt-evo 8.8' wide screen? Thanks |
07-21-2019, 08:44 AM | #2 |
Rep 1,687
Drives: 2014 428i and 2018 X5
Why would you buy it when the reviews on the link provided above are terrible?
You can either return it or contact Carlinkt support.
07-21-2019, 12:43 PM | #3 |
Rep 45
That’s disappointing because I was very interested in this unit. It looks like some people have been able to get a firmware update to fix the screen issues. How does it work otherwise? Is it wired or wireless or both? Can you play audio via Bluetooth in I drive while still getting CarPlay video like other units? Does airplay work? Did you install the backup camera?
07-21-2019, 07:35 PM | #4 | |
Rep 21
07-21-2019, 07:40 PM | #5 |
Rep 21
Reviews from buyers seems to be fixed by update... but the update fixes in fact the Color scheme in google maps... no more... Contact with the seller is very bad... He didn't answer to my requests...
07-21-2019, 11:55 PM | #6 | |
Rep 45
07-25-2019, 12:00 PM | #7 |
Rep 1,055
Drives: 2016 340i M Sport 6MT+RWD
I'd stay far away from this brand's module.
I saw this unit a while back and kept any eye on the reviews for a few months - decided against it myself. The pictures posted by buyers clearly showed the color was off and the unit doesn't run in the native resolution of the iDrive display, that's why it looks blurry. 8.8" and non-touch 10.2" iDrive screens have a 1280x480 resolution but this unit outputs in a weird resolution contrary to what their chart on the unit says. Because of the odd resolution, the content is actually stretched vertically a bit (square app icons looked slightly rectangular to me in reviews).
2016 Estoril Blue II 340i M Sport | ///MPPSK | 6MT | RWD | Fully Loaded
BM3 Stage 2+ 93 | B58TU HPFP | VRSF v2 Catted Downpipe | 550i Clutch |
07-26-2019, 12:22 AM | #8 |
Rep 45
07-29-2019, 09:19 AM | #9 | ||
Rep 766
The carlinkit audio was as good as I would expect it to be (I had the previous gen wired version) - would expect the new one to similar as is also using the aux port... Quote:
07-29-2019, 11:09 AM | #10 | |
Rep 45
x-m4n148.00 |
07-29-2019, 01:41 PM | #11 |
Rep 1,055
I doubt it; if the unit was capable of doing the native resolution, I'd think they would have released it with it. I suspect the processor isn't capable of delivering the 1280x480 resolution without performance impact, due to overheating or whatever other reason. Looks like a inferior product/solution to me.
x-m4n148.00 |
07-30-2019, 10:16 AM | #12 |
Rep 21
I'm not an audio expert... But IMO the audio quality seems to be good... No cracking noise, no distortion... I've put the AUX level to 8 just to test, but for now I've put it to zero as I cannot see real difference when playing with the AUX volume (except that the volume is higher or lower ;-)
x-m4n148.00 |
07-30-2019, 10:17 AM | #13 | |
Rep 21
07-30-2019, 10:26 AM | #15 | |
Rep 21
You say that the unit is as good as it is expected to be... Which kind of screen do you have? Do you experience the same problems as me? (weird resolution/pictures strectched?) Thanks |
07-30-2019, 10:30 AM | #16 |
Rep 21
For users of other Carplay modules (Joyeauto/UniqueAD...):
Do you experience problems with bad resolution? With pictures/icons stretched? If not, I'll seriously consider selling this unit to a NBT 6,5" owner and buy another one with better quality... Thanks |
07-30-2019, 10:31 AM | #17 |
Rep 766
I was talking about the Carlinkit AUDIO being as good as I would expect it to be - (I had the previous gen Carlinkit version which was showing Carplay in only "half" of the BMW screen but in the correct sharp resolution).
I see you are also reporting good audio with the new widescreen version. Following this thread with interest. Last edited by x-m4n; 07-30-2019 at 10:39 AM.. |
07-31-2019, 03:25 AM | #18 | |
Rep 102
x-m4n148.00 |
07-31-2019, 05:09 AM | #19 | |
Rep 43
Pros: same audio quality with the original evo and same resolution (6.5"), the processor is fine it works good not slow not get stucked, connection is great actually this was the notorius side what i was fearing of... Cons: audio uses aux, when you want to go back to original evo interface it can be stucked and there is no way to reset the device this is really ridicilous, the seller from aliexpress did not help me with this issue |
x-m4n148.00 |
08-01-2019, 04:02 AM | #20 | |
Rep 21
08-01-2019, 04:03 AM | #21 | |
Rep 21
08-01-2019, 06:46 AM | #22 | ||
Rep 43
