BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Coolant leak 335d f31
      03-06-2024, 12:28 PM   #1
sl13
Drives: 335d xdrive Msport
Hi all,
I've come back from 2000 mile round trip to the alps and noticed my breather hose had disintegrated (i'd fixed it twice already), but I also noticed coolant level was lower than when I left.
I cannot find any sign of fluid or staining. There's some tarnishing of the oil cooler which has a coolant hose sitting on top of it, but other than that I cannot see anything. I've checked the hose running from the larger coolant hose, across the front of the engine bay and into the coolant reservoir, but other than that I am at a loss.
I've had both EGR recalls done.
New water pump about a year ago.
Any ideas or places that I can dig further?
TA
      03-06-2024, 12:52 PM   #2
bishbosh
Drives: F30 335d
2014 BMW 335d  [0.00]
The rigid plastic coolant pipe above the oil cooler can fail. However this failing usually results in rapid coolant loss.
Do you have a low coolant warning? Any coolant in the oil?
The oil cooler gasket can fail too, resulting in either or both the oil and coolant leaking.
      03-06-2024, 01:09 PM   #3
bobby-six-killer
Drives: 340i Touring
If that ever happens to me I’m going to buy a new reservoir cap and see if that fixes it as a first attempt. Assuming nothing else obvious of course.
      03-06-2024, 01:17 PM   #4
sl13
no warnings and no coolant in oil from what I can see.
I'll look at the cooler gasket and see if there is any loss. I'll clean it all off and see what happens over the week.
