04-03-2019, 10:49 PM | #1 |
Rep 5,392
Question For You If You Have Replaced Your Downpipe?
Question For You If You Have Replaced Your Downpipe? Did you replace any related parts during your installation such as a gasket, 0-ring, clamps, nuts, bolts, etc? I usually replace parts like this especially if they are under harsh conditions like the exhaust system. Please let me know your experience so that I can buy parts to have ready during my downpipe installation? Any advice is greatly appreciated!
Here's the related parts list from top (engine) to bottom (midpipe): 1) Pre-Converter O-Ring (metal gasket) 18-30-7-553-601 $17.72 2) Pre-Converter Clamp 11-65-7-620-508 $20.32 NEW DOWNPIPE- with two welded brackets that each have a bolt hole Nuts & Bolts?- There are two brackets on the downpipe, each with a hole. There is a bracket with matching holes, called the Converter & Pipe Bracket (18-32-7-643-425 $39.73) that the downpipe must bolt to. A dealer told me that the nut is an M8 (18307525607 $1.27) but I haven't been able to determine what the bolts are. Any ideas? I assume these nuts and bolts might have to be replaced and I don't know what size/part# bolts to order. 4) Converter & Pipe Retainer Ring (Bottom Clamp) 18-30-7-620-349 $26.70 A dealer tech told me that these bottom clamps often don't come off and go back on very well so he makes sure that he has a replacement handy. |
04-03-2019, 11:32 PM | #2 |
Rep 190,805
We recommend replacing the gaskets with downpipes, most will be fine re-using the stock gaskets if they are still in good condition
04-04-2019, 08:39 AM | #3 |
Rep 5,457
You need one gasket and two clamps to do it properly. Looks like you linked the proper ones.
As Mike said, you may find that your clamps or gaskets come off easy and are in good, reusable condition - like mine were. But you have no way of knowing until its two late. |
04-04-2019, 09:05 AM | #4 | ||
Rep 5,392
04-04-2019, 09:10 AM | #5 |
Rep 5,457
I did not need any additional bolts or nuts at all. My down pipe came with brackets and bolts in the exact same position as OEM. I re used factory nuts so I cannot comment on size.
Someone else may be able to but I dont want to steer you wrong. |
04-04-2019, 09:21 AM | #6 | |
Rep 5,392
sspade2464.50 |
04-04-2019, 10:56 AM | #7 | |
not good, but bad
333
Rep 361
They are spelled BRAKES not breaks!!!! Oh FFS, not another spark plug thread!
BreadsBMW on Youtube |
04-04-2019, 02:35 PM | #9 |
Rep 775
Replace gaskets as a minimum imho. i did gaskets and clamps. May as well just do it right since you're in there. PLUS you're in NJ, the roads are horribly dirty.
Enjoy the Drive,
Steven 2014 435i M-Opt, M LSD, Dinan CAI/IC/BTurbo/Stage 4, ER TIC/CP, GFB DV+, Fabspeed HJS cat DP & Mich PS4S. |
04-04-2019, 02:49 PM | #10 | ||
Rep 5,392
All the Fabspeed photos I've seen just have holes. I was told by dealer that the nuts are M8. So I'm trying to find out how long of a bolt I should buy. Just stopped at Lowes and they have stainless steel M8 bolts in 20mm long and 30mm long. (25.4mm= 1 inch). Do you think one of those two sizes will work? How do you like your Fabspeed catted? What differences did you notice? |
04-04-2019, 02:56 PM | #11 |
Rep 775
i forget, it was so long ago. Do remember i had the stock clamps and gasket and so we needed nothing else. You should be fine. As for feel, etc., it was the very last thing done to the car, which already had all the other stuff you see in my sig. Easily felt the added push so well worth it imho plus no CEL and no smell either.
Oh yeah, no drone, kept the stock pipes downward. Car is relatively quiet and fast. Louder is not always faster... plus i love sleeper cars.
Enjoy the Drive,
04-04-2019, 03:37 PM | #12 | ||
Rep 5,392
Outside the car looks stock but stealth because of subtle changes. 2015 335i xDrive M-Sport with blacked out trim and front grill in Sapphire Black Metallic with color matched front fender and rear bumper reflectors. BMW emblems hood, trunk & wheels all carbon fiber black/white. Sport black diffuser under rear bumper. Slightly lowered with Eibach spring kit. Stock silver 400M wheels but with 245/40-18 Michelin Pilot Sport 4S. Brakes upgraded to M Sport but with gloss black calipers with white Brembo logos. Just ordered smoked lenses for the turn signals on the side mirrors, a very subtle change! Fun stuff!!! |
04-04-2019, 05:37 PM | #13 |
Rep 5,457
In case it helps....
This is exactly what I bought in addition to the actual down pipe for my N26. Nothing more, nothing less. Edit: pic not loading? |
04-04-2019, 05:49 PM | #14 | ||
Rep 5,392
Man, I love the spring when the sun comes out, flowers sprout up and new car stuff gets delivered almost every day! You can hear the turbos whine and almost smell the burnt rubber in the mornings. Life is good! |
12-02-2019, 11:34 PM | #15 | |
Rep 7,606
These are the correct parts for 2015 335i EWG RWD 8AT? I have seen these posted on several other threads. |
12-03-2019, 12:23 AM | #16 | ||
Rep 5,392
You can doublecheck the part numbers by giving your VIN number to GetBMWParts dot com where I ordered my parts. And you can also check on realoem dot com. Good luck! |
12-03-2019, 12:45 PM | #17 | |
Rep 7,606
https://f30.bimmerpost.com/forums/sh...ht=18307606136 VRSF also shows that 18307606136 is for the 4'' clamp which differs from what you said. https://www.vr-speed.com/vrsf-4-turb...8-n20-n55.html At this point i am just going to go with the other threads that show 18307606136 for the 4'' EWG turbo to DP clamp and 18307581970 for the corresponding gasket. Those are also discussed here: https://f30.bimmerpost.com/forums/sh...ht=18307606136 |
12-03-2019, 12:50 PM | #18 |
Rep 821
Drives: Bmw 335i f30 N55 ( sold)
When I replaced my stock downpipe with a vrsf catless I really used the oem gaskets and everything and it was good.
2012 bmw 335i sedan
VRSF catless DP VRSF 5? HD IC Stock intake(had open before and was sick of noise) BMS CP 550i 351m rims with 275/245 set up. No tune as of yet. |
12-03-2019, 01:02 PM | #19 |
Rep 7,606
