BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > delete
      02-03-2019, 01:57 PM   #1
Ace320
Ace320's Avatar
Italy
128
Drives: F31 M Sport, 6MT, Alpine White
delete
      02-19-2019, 04:11 PM   #2
gizmo1908
Netherlands
Drives: F30 320i
Originally Posted by Ace320 View Post
Hello, I have 2013 F30 M Sport but without lightning package.
I have purchased front and rear LED head lamps from 2016 F30 and i have realised that i need wiring harness too.
Unfortunately, BMW doesn't sell wiring harness for this kind of mod/retrofit.
I have found on Russian site that one guy retrofitted to F20 this LED head lamps, but i don't understand Russian.
https://www.drive2.ru/l/4792741/
So, does anybody know where I can find wiring harness for LED head lamps or how to create one?
You have rain/lightsensor?
I have done this myself so i can help you
      02-21-2019, 07:40 AM   #3
kobluna
Drives: 320i
I would be interested as well. I too have base light now but have rain sensor. I have not yet purchased parts because I was afraid that it would be difficult job because of missing wiring harness.
      02-21-2019, 08:55 AM   #4
gizmo1908
Netherlands
Drives: F30 320i
i will see tonight if i have time to make a how to. i am at work now and no acces to rheingold.
it isnt that hard. i dit the lightning package and ambilight center console. cool mod
      02-21-2019, 09:04 AM   #5
gizmo1908
Netherlands
Drives: F30 320i
      02-25-2019, 03:59 AM   #6
kobluna
Drives: 320i
I have also done center console ambilight upgrade by changing trim piece to LCI one. It was easy enough but does dome light need new harness and should that new harness be connected to FEM? If yes, I guess it's not that easy.
      02-25-2019, 04:03 AM   #7
gizmo1908
Netherlands
Drives: F30 320i
Like i said in an earlier post. If you have rain/light sensor than every wire is there
You need +12v and k-line. Take them from the rain sensor. Wire 21 from FEM is already in the base domelight. Gnd to. Just needs repinning. So no it isnt difficult
If you retrofit rear dome to you need to make a wiring harnes from front to rear. Not hard cause its a straight line. You would need 1 wire from fem. There is a unused wire in the base light that can be used for rear. Just repin in FEM
      02-25-2019, 06:55 AM   #8
kobluna
Drives: 320i
Ahh, got it. Thank you, when weather gets warmer here I will look into this
      03-14-2019, 03:33 PM   #9
Ace320
Ace320's Avatar
Italy
128
Hi, sry for the late respond. Yes I have rain sensor, i heard that you can myke Y cable, same one like with the AC trim cover, but i don't know where is rain sensor cable, where to find it.
      03-14-2019, 05:40 PM   #10
gizmo1908
Netherlands
Drives: F30 320i
Yes you can make ycable. Remove the plastic trim around the mirror base. Where its is glued on the window. Bad bad english sorry. There you can find the cable for the sensor. Pull it back from the dome light in to the roof. Wire the ycable back to the rain sensor. And voila you have +12v and k-lin
      03-21-2019, 03:38 PM   #11
Ace320
Ace320's Avatar
Italy
128
Okay, so i disconnect cable from the rain sensor, make a Y cable, and that Y cable connect to the dome light? Do i need something else? How to connect rear dome light?
      03-22-2019, 02:26 AM   #12
Mikesmith2939
Drives: 2013 320i xdrive
I would also like to know how this is done.
      03-22-2019, 04:38 AM   #13
gizmo1908
Netherlands
Drives: F30 320i
Everything is in the topic. Just read.
      03-22-2019, 04:39 AM   #14
gizmo1908
Netherlands
Drives: F30 320i
I will make a how to this weekend.
      03-22-2019, 12:39 PM   #15
Mikesmith2939
Thank you
      03-25-2019, 02:51 PM   #16
Ace320
Ace320's Avatar
Italy
128
Okay, let me know when you have done it.
      03-26-2019, 11:39 AM   #17
gizmo1908
Netherlands
Drives: F30 320i
Yes i will. But i am a little busy these days. I will begin soon and upload it.
      03-26-2019, 02:59 PM   #18
Ace320
Ace320's Avatar
Italy
128
Okay, no problem man. Can you at least tell me, do I need to buy some materials for this project? So I can order them from BMW. If you have codes that would be great.
      03-27-2019, 01:53 PM   #19
gizmo1908
Netherlands
Drives: F30 320i
of course.
4 6pin connectors: 61130406869
the right pins. 24: 61130005197
Front dome light: 61319312496
rear dome light: 61319277932
couple of mtrs of wire .35 mm2, dont know the awg...
and you will need to make a ycable for the rain/light sensor. i think its a 3 pin connector but cant be sure. buy a male and a female. with the pins. or you can splice the wires and solder them directly on the wires that go to the rain/light sensor. you will need power and k-lin.
i started the diy i hope i finish it this week.
      03-27-2019, 04:45 PM   #20
Ace320
Ace320's Avatar
Italy
128
of course.
For the 6 pin connector, it says that has been discounted from factory. (
View post on imgur.com
Are you sure you have bought that connectors, using that exact same code?
Also, pin connectors (24 pcs), am little bit confused, when I type that code in google, there is only short cable with female pin?
Isn't there supposed to be only pins, without cables?
      03-27-2019, 08:02 PM   #21
gizmo1908
Netherlands
Drives: F30 320i
of course.
For the connector check the number on realoem. They change numbers quite often. I added a photo with the new number.
For the pins i bought them on ebay with that number and it comes with wire. I found it easy as i dont have a shrink tool. I solderd wires to it and used shrinktube.
      03-27-2019, 08:03 PM   #22
gizmo1908
Netherlands
Drives: F30 320i
