12-04-2013, 05:28 PM | #1 |
Rep 81
Best LED Choice for Turn Signals
Some updates on my turn signal LED swap : since I had to order a couple of other LEDs for the rear (PY21W/BAU15S for the front and P21W/BA15s for the back), I tried another type and what a positive difference ! While there was nothing wrong with the previous ones, those new ones definitely look better, even surpassing the brightness of the original bulbs, but not in an overwhelming way. So, those new ones are CREE 30W XB-D5 LED. There are many CREE LEDs out there but only the latest ones, XB-D5, produce a lot more light per Watt used (in that respect, if available, only pay attention to the lumen rating of the LED, not the power alone as it can always be wasted in heat or wrongly focused). Please note that I also used amber LEDs for the back even though the rear bulbs were originally white (unlike in the front). Using white LEDs for the rear would have resulted in having too much light cut-off by the casing : it is best to spend all power on a wavelength that goes through.
Here is a video of my car featuring those new CREE LEDs : The car looks so much better... why isn't BMW mounting LED by default For reference, I also attach a picture of how those LEDs are advertised here in Japan. |
12-06-2013, 09:48 AM | #3 |
Rep 1,573
i too would love to know where we can get this in the US
did you need to do anything from keeping it from hyper blinking? does it flicker every minute like the other LEDs do?
2015i Cadillac Escalade ESV
12-06-2013, 11:35 AM | #4 | |
Rep 1,170
Great work benoa!
F36 435i * MINERAL GREY * ///M Performance | G01 X3 * PHYTONIC BLUE * ///M40i
12-06-2013, 05:46 PM | #5 |
Rep 81
02-22-2014, 03:15 PM | #6 |
Rep 68
Can you PM me the link to purchase the rear ones. I found the ones for the front but can't find the right type for the rear turn signals. Different bulb from the front.
02-22-2014, 05:48 PM | #7 | |
Rep 10
02-24-2014, 07:53 AM | #8 | |
Rep 1,232
so they do blink when the lights are just on without coding? |
03-07-2014, 10:21 PM | #11 |
Rep 906
I installed the Weisslicht blubs on front and rear as well (amber). The rear bulbs are SUPER bright, to the point that it hurts my eyes. Otherwise, no complaints.
2017 328d xDrive Sports Wagon: Estoril Blue, Black Sensatec, M-Sport Pkg
2020 i3 Rex: Capparis White, Giga World |
03-19-2014, 11:36 AM | #12 |
Rep 1,649
03-19-2014, 08:28 PM | #13 |
_________
Rep 216
03-20-2014, 09:30 AM | #14 |
Rep 1,573
even after coding to disable the system checks every minute....theres no way to disable the check that it makes every 5 minutes? or am i wrong
03-20-2014, 01:02 PM | #15 |
Rep 906
There's no way to get around the flicker w/o coding. These will flicker every 5 minutes or so, but it's less of a flicker and more of one short, low intensity, pulse. So not as intrusive as some are led to believe. No errors w/ or w/o coding.
I coded the front and back to LED-mode using these instructions. This will disable the cold check (on start) and warm check (every 5-minutes). http://blog.benoa.net/2013/12/f30-f3...n-signals.html
03-24-2014, 11:02 AM | #18 |
Rep 41
Not exactly,
If u dont want the flicker, u have to keep the LED turn on. Like, if your headlight is on auto mode, in the day(Only angle eyes turn on), flicker, in the night, no flicker if u dont want flicker at all, u have to code the computer |
02-26-2016, 03:01 PM | #20 |
A family of bimmers
2748
Rep 7,742
these look great. have there been any improvements in LED turn signals for the F30? i cant believe this car doesnt have led turns signals front and rear yet my e90 lci did. also, how can i get these turned off when the headlights are on. i want just the angel eyes and xenon headlights on.
02-26-2016, 03:07 PM | #21 | |
Rep 1,067
I do like the Weisslicht bulbs from Bimmian, Amber in the rear especially. Coding will help take care of turning them off when not being used. |
