BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > 440i xdrive bm3 ots e30 s2 tune - dragy results 0-60 and 1/4 mile
      06-22-2019, 10:35 PM   #1
SoCalCarGuy
Drives: 2019 440ix cpe + 2018 x4 m40i
s2 bm3, decat, res delete, stock catback, afe filter, .020 stock plugs. full tank of gas, tune adapted for about 8-10 miles before run - Driver 220lbs. This was my first and only pass and it was done on launch control.
tires are Michelin PS 4S 255/35/19 and 225/40/19 on replica m4 comp wheels (weigh less than stock, not sure how much) and car is lowered on H&R sport with dinan shockware. -1.7 rear camber and -.8 front camber. car hooks and goes. wish we could launch 800-1000rpm higher if its safe. awd launch control should be cutting 1.6-1.7 60' all day. I used to run a 1.8-1.9 60' on my bone stock 2003 cobra on shit tires back in the day.
      06-22-2019, 10:38 PM   #2
SoCalCarGuy
91 octane 1/8 mile pass.
kern4174445.00
      06-22-2019, 11:17 PM   #3
GT500R
Drives: BMW X3M
Thanks for posting, so are you AWD?
X3M Alpine White - SOLD
Fastest Tune Only Record - Mission Performance
10.84@127.43 / +1912 DA NH Dragway |
10.6@130 Dragy / +820 DA The Streets |
NOW: Tesla Model Y Performance
      06-22-2019, 11:21 PM   #4
SoCalCarGuy
yes
      06-22-2019, 11:24 PM   #5
SoCalCarGuy
here's the 0-60 on the 1/4 run.
I would imagine I could get this down as well as the 1/4 when I can make some passes on a different 'track'.
      06-22-2019, 11:40 PM   #6
GT500R
Drives: BMW X3M
Agree on raising the launch rpm... not sure what the differences are between the AWD systems in each B58 equipped car
      06-23-2019, 03:37 PM   #7
B58togo
Drives: M240i
Impressive. More or less identical to my best times (3.95 and 7.79) on Stage 2 93. I'm carrying a couple more MPH, due to RWD and a bit lighter weight. I'd love to do e30, but none available within an hour. I am getting the LSD installed shortly and flashing the TCU, so hoping to maybe pick up another tenth or two.
2017 M240i/ ZF8 Pure Drivetrain Solutions Stage 1 & torque converter/xHP/ Pure 800 cast/ DS2/ E40 Doug Newton tuned/ ER catless DP/ Remus axle back/ BMS intake/ FTP CP/ M Performance LSD
      06-23-2019, 07:54 PM   #8
amw896
amw896's Avatar
Drives: 2015 BMW M235i
2015 BMW M235i  [10.00]
Bit unrelated but careful with that staggered setup. I'm not sure what rolling diameter difference you are on but you're risking grenading the transfer case.
      06-24-2019, 07:34 AM   #9
SoCalCarGuy
Those are the original Bmw tire sizes. But thanks for the warning.
      06-30-2019, 07:15 PM   #10
bsas340i
bsas340i's Avatar
Drives: 2022 BMW M5 Comp
2021 BMW X5  [0.00]
2022 BMW M5  [9.50]
2004 BMW K1200RS  [10.00]
My 0-60 mph according to the M laptimer app.
RWD with Michelin PS4S, mods listed on the sig.
2022 M5: MBB/Aragon Ext Leather/ZCP/ZEC/789M' Wheels/Alu Carbon Struct Dark Trim/Red Calipers
2021 X5 sDr40i: Jet Black/Ivory White Ext
Merino Leather/ZP2/ZPK/20'' Wheels (738)/Multi-Contour seats, Htd seats/armrests/steering wheel
      07-01-2019, 08:31 PM   #11
mike@x-ph.com
mike@x-ph.com's Avatar
Drives: 07-335/12-328/18-M4/21-M4CP
Nice!
https://x-ph.com/sale/
Phone number 702-494-9435
      07-01-2019, 09:02 PM   #12
awilki0101
awilki0101's Avatar
519
Drives: 2016 340i xDrive
My best so far. Lifted before full 1/4 mile but still pretty happy with it
bsas340i106.00
      07-01-2019, 10:46 PM   #13
SoCalCarGuy
Mods?
      07-01-2019, 11:48 PM   #14
GT500R
Drives: BMW X3M
I pull pretty similar times w/mods in sig, AWD 👍🏼. can you show the graph to see DA and other info etc?
      07-02-2019, 03:48 AM   #15
F80DXB
United Arab Emirates
Drives: 2017 YMB F80 M3 ZCP
Any idea what your HP to wheels is with your current setup and those figures?
      07-02-2019, 07:03 AM   #16
awilki0101
awilki0101's Avatar
519
Mods?
MG Flasher stg2, ER catless downpipe, FTP charge pipe and intake pipe.
      07-02-2019, 07:05 AM   #17
awilki0101
awilki0101's Avatar
519
Here it is
      07-02-2019, 08:01 AM   #18
janea1207
Drives: BMW 340i
mg flasher
any info about 100-200km/h time???
      07-02-2019, 05:08 PM   #19
GT500R
Drives: BMW X3M
Here it is
No DA, update the app if you can do it shows DA on 0-60/1/4 mile runs. I can only assume +2000
      07-02-2019, 09:04 PM   #20
awilki0101
awilki0101's Avatar
519
Here it is
That was in previous post. 2431.
      07-03-2019, 07:51 AM   #21
SoCalCarGuy
Made 380whp on 91 octane. I didn't Dyno on e30 tune unfortunately.
      07-03-2019, 08:02 AM   #22
lens
lens's Avatar
2070
Drives: 2018 340i xDrive
On 6MT, my friend could dump the clutch at 4500rpm, but the clutch or xfer case did not like it at all. Reason why we're not able to go past 3500rpm some cases is because any higher on 8at and you risk blowing up something in the trans or other stuff.
