06-27-2019, 06:54 AM | #1 |
Rep 162
EGR delete, for a friend ;)
Asking what the tuner of choice is for an EGR delete. I could handle the physical removal but need a hand with the coding/tune aspect of the delete. I was a bit dumfounded when Malone quoted me $750 for an EGR tune but if that's the going rate, so be it. Just looking for alternates 1st.
Thx. |
06-27-2019, 11:09 AM | #2 |
Rep 8,496
Why not just have it coded out (closed) ?
Can be easily done as part of a remap, for example.
06-28-2019, 05:01 AM | #5 |
Rep 162
That I get. I just didn't expect to have to pay $750 to have this done and I'm looking for other providers of this service, be it a known tuner or highschooler with a laptop.
K |
09-05-2019, 05:59 AM | #7 |
Rep 724
09-06-2019, 04:48 PM | #8 | |
Rep 364
The coder that did mine said he could have done but costs the same as having a remap so I opted for the remap. Once the novelty wore off of having more usable power down low, economy is definitely improved, at least an improvement of +4mpg per tankful, calculated brim to brim. |
APJ245.00 |
09-07-2019, 02:35 PM | #9 | |
Rep 724
09-10-2019, 04:20 AM | #10 | |
Rep 364
Why bother with removing it and making it more obvious?! Was coded out in February along with remap, have since also passed emissions/MOT with no issues |
09-10-2019, 02:09 PM | #11 | |
Rep 724
Wasn't worried about mot to be honest. Every blue moon i get power loss when i'm having a little bit of fun, which i can only think is overfueling, so is it caused by the map or egr valve, i'm not sure !, i don't have any black smoke and the exhaust tips are not black either, so have i answered my own question. Just can't decide whether to go ahead, bloke who did the map charges 80 quid to delete, so its not extortionate. |
09-11-2019, 12:17 PM | #12 |
Rep 424
Wondering if I should get a tune here sooner now that my commute went down to 6 minutes where the card doesn't even get hot. Big change from my 45 minute commute prior.
Would tuning the EGR out be beneficial to help protect the car from short drive issues between long drives? |
09-11-2019, 03:50 PM | #13 |
Rep 1,803
For short drives EGR on (or a dynamic EGR, if your tuner knows how) is best.
EGR is good for engine warmup. There's less metal and bearing wear when oil is warm. Coldstarts are where engines wear the most.
09-12-2019, 08:26 AM | #14 |
Rep 424
Good info, makes sense. Just worried about my d now. She is used to 45 minute 70-80 mph drives twice a day, 5 days a week. Now she will be getting 10 minute city drives.
09-13-2019, 04:35 PM | #15 |
Rep 468
Highly recommend an EGR delete, it does so much good for the engine. Been running mine in my 335d F30 and all of my previous cars. Even with DPF intact, the regens are less frequent due to less soot build up.
The only problem is finding a guy that you can trust. To code it out fully its not easy, as most so called tuners only blank then them or unplug them and then just delete the associated DTC's and the job is done.. But thats not the proper way. |
09-15-2019, 03:02 PM | #16 | |
Rep 8,496
Modern synthetic oils have excellent cold performance, and a good quality friction modifier can improve things further. People with 2-3 year PCPs may not be bothered about the downsides of OEM EGR operation, or notice the difference, but some of us with keepers take a different view.
09-17-2019, 12:07 PM | #17 | |
Rep 424
10-11-2019, 04:56 PM | #19 |
Rep 364
10-14-2019, 02:16 PM | #20 |
Rep 105
10-15-2019, 01:45 PM | #21 |
Rep 364
04-01-2021, 01:29 AM | #22 | |
Rep 37
How do you know it’s closed once codes?
